Manual transmission & differential gear oil suggestions - Lexus IS Forum
post #1 of 4 (permalink) Old 11-27-2018, 09:52 PM Thread Starter
Hey guys new to the forum. Always been a DIYer. I have an 07 is250 RWD w/ manual transmission. I feel some slippage & know that I'm probably beyond overdue to change gear oil in the tranny & differential. Owners manual suggests using "Toyota genuine manual transmission gear oil API GL-5" 75W-90 gear oil, says if using any other gear oil, there's a risk of gear noise & other issues.
Do you guys stick with this manual tranny gear oil? If not, what do you use? & Have you run into any issues?
Same question for differential oil, you guys use the recommended, "Toyota genuine differential LT 75W-85 GL-5 only? Or other stuff? Any issues?
THA TRE is offline
post #2 of 4 (permalink) Old 11-27-2018, 10:27 PM
Quoted: 32 Post(s)
I've used Redline's products for gear oil for the w55 tranny and is3 diff, no issues whatsoever
DH_71631 is offline
post #3 of 4 (permalink) Old 12-03-2018, 02:59 PM
Quoted: 141 Post(s)
I only use Redline fluids for Toyota manual transmissions too. The diff isn't so important since I use a clutch type lsd, I just run regular 75W90 fluid in there.
Piggity is online now
post #4 of 4 (permalink) Old 12-03-2018, 05:57 PM
Quoted: 36 Post(s)
Yep 75w90 is the way to go. I work at Toyota and our official Oil Supllier is Mobil1, Gear oil, engine oil, ATF oil all from mobil1
Color: Cromax YR580M
TRD Carbon Fiber Shifter Ball
Fidanza Exhaust Cam Gear
SPC Rear Camber Kit
Continental ProContact Tires
Mathieu Bernier is offline
Auto to Manual Swap, Wiring, Ecu, CC, NSS, CLSW, Trac, Snow, now smogged in CA! Curran Go Fast Stuff 186 01-05-2019 10:11 AM
2003 Lexus IS300 Manual Transmission Question alamau01 General Discussion 1 04-15-2018 07:07 AM
White 2003 Lexus IS300 Build Thread **HD Pix** White2003Lexus General Discussion 188 07-04-2017 11:24 AM
Using an air compressor to pump the gear lube into the differential IM QUIKR General Discussion 10 01-31-2017 09:14 AM
