Is300 Part Numbers Spreadsheet (toyota) - Page 6 - Lexus IS Forum
post #76 of 111 (permalink) Old 09-01-2009, 06:21 AM
FYI: 31230-22100 changes to 31230-22101, nobody stocks it but it is available.
'02 Silver IS300, stick, K&N drop in filter, 5-way Tokicos, Eibach sways, spare track day wheels, Dunlop 03G set
My4door86 is offline
post #77 of 111 (permalink) Old 09-24-2009, 06:23 AM
shark7's Avatar
i have one to add / exhaust gasket
Ok so i see these listed for exhaust gaskets..
EXHAUST GASKTS 17173-46050 - 2 of them. LEXUS ONLY
EXHAUST GASKET 17451-0D050 28.87 DOH-NUT
REAR EXH GSKT 17420-74060 - LEXUS ONLY
but i don't see the one that I just bought from Lexus parts.. I have...
90080-43033 gasket, exhaust ($9.xx)
""Knowledge is power." Francis Bacon."
shark7 is offline
post #78 of 111 (permalink) Old 11-06-2009, 03:37 PM
Quoted: 38 Post(s)
Try this:
ToyoDIY.com
EStoIS is offline
post #79 of 111 (permalink) Old 11-06-2009, 05:35 PM
^^ Good site, if only for looking up parts.
So I was playing around with my fog lights again, the exact part number is 90987-02020, but the rest of the 4 pin relays in the car are 90987-02012 (horn, rear lamp, efi, etc etc etc). DIY tells me LHD Altezza's used the 02012, and what do you know it works just fine.
02020 is $70, 02012 is $25, hard to argue with that.
Alternative part numbers for 90987-02012 are: 90080-87010, 90080-87015, 90084-98031.
If you are really in a pinch, this relay is also a GM part# 30013237, and AC Delco #212-360. For geo metros, chevy S10s and trackers, late models with fuel injection (think junkyard finds here).
So there you go, alternative relay part numbers for horn, fog lights, tail lights, radiator fans (all 3 relays), mirror defrost, ac clutch, and power windows. I might be missing some, but if its a 4 pin relay, 2 copper, 2 silver, then it's probably a 02012.
npChaos is offline
post #80 of 111 (permalink) Old 12-04-2009, 02:28 PM
Hey i have been looking for a while for a Stock 2002 lexus is300 rear diff dose anybody know how much they would cost or even where i could get one or should i just go to a Junk yard and pick one up off a junker.
FujitaIs300 is offline
post #81 of 111 (permalink) Old 01-12-2010, 02:54 PM
Anyone have the cross over to toyota parts for the clutch...
Or asking it another way does the Supra 94-97 NA clutch fit?
I know about the sprung hub vs un-sprung.
2003 Pathfinder SE 4WD
IanH is offline
post #82 of 111 (permalink) Old 01-31-2010, 06:38 PM
Hey i looked over your post but have a few questions.
I need to buy front upper and lower control arms with the spindles. Did these only come on the is300 or are these parts interchangeable with other lexus/toyota models.
Lastly i need the dimensions for under the hood. I cant understand what measurement the catalog is using. My car will be in the frame shop next week and i would like to check their work.
thxs
jmk063 is offline
post #83 of 111 (permalink) Old 02-04-2010, 11:52 AM
Would it be possible for me to get a hold of the headlight lenses instead of having to buy a whole headlight housing, i just need to replace mine for regular wear and tear.
AlOShA360 is offline
post #84 of 111 (permalink) Old 02-21-2010, 09:38 PM
anyone have a part number for the orings in the a/c system?
02 IBP soon to be fed on a diet of corn juice and corvette
MX99204 is offline
post #85 of 111 (permalink) Old 04-12-2010, 05:39 PM Thread Starter
Here's another good website to use also, and it has some pics:
http://www.sewellpartsonline.com/category2.asp?cat=ENG
It has a lot of other Lexus cars on it too. They are a huge Lexus dealer so they
are allowed to display the images, unlike ToyoDIY.
Good Luck.
nautox is offline
post #86 of 111 (permalink) Old 05-10-2010, 03:00 PM
This is a great resource. Thanks for sharing.
Has anyone tried the Supra Flywheel? Does that work? I seem to recall the cost of the dual mass flywheel at Lexus was > $1000.
-Scott
SLIS is offline
post #87 of 111 (permalink) Old 05-10-2010, 03:07 PM
-Scott
I am replacing my clutch so researched this issue.
Yes the Supra NA (and SC300 is same) flywheel fits, you also need the flywheel attaching bolts, they are a different length, and are a replace each time part anyway, and a clutch pushrod, its a different length.
part numbers are in the forum, I found them easily.
note you cant use the sprung hub clutch center plate with the stock sprung flywheel, the hub hits the flywheel bolts.
But you must use the sprung hub with the Supra NA or SC300 or Fidenza flywheels.
hope that helps.
IanH is offline
post #88 of 111 (permalink) Old 05-10-2010, 03:14 PM
Just buy a metric O ring set for 134A systems I dont believe there is anything special, maybe ask your local A/C parts or shop?
you can look up one by one in the part webs sites but these will be Lexus prices.
IanH is offline
post #89 of 111 (permalink) Old 05-22-2010, 09:22 PM
Take a look at the part numbers list I am hosting
It's under is300 owners manual and repair guides.
Or email me at [email protected]
1st Time IS Owner (2002) IS 300 {32,029 Original Miles!)
golfntyme is offline
post #90 of 111 (permalink) Old 10-18-2010, 12:40 PM
quick question will the Supra front motor mounts work on a stock auto IS300 motor?
XTCAT8K is offline
TRD parts list for the IS300!!! DtEW Stop, Drop and Roll 38 02-12-2013 08:08 PM
TRD parts list for the IS300!!! IS300 Owner's Forum 11 03-12-2011 12:32 AM
TRD parts list for the IS300!!! Showroom 7 05-12-2002 05:11 AM
TRD parts list for the IS300!!! General Discussion 4 11-11-2000 12:23 PM
TRD parts list for the IS300!!! Go Fast Stuff 1 11-10-2000 10:58 PM
