Is300 Part Numbers Spreadsheet (toyota) - Page 2 - Lexus IS Forum
post #16 of 111 (permalink) Old 03-30-2007, 09:44 AM
Manufacturer of Pipes
Joe Z's Avatar
I'm pretty sure the IS300 Serpentine Belt part# is:
99366-D1930
I have a list at home with all my other parts, I'll cross check and post any differences.. (if any)
- Joe Z
Five Axis Design R5:F Wheels on Continental Extreme DW
ALL MY MODS are For Sale here: Joe Zís Super Garage Sale
Joe Z is offline
post #17 of 111 (permalink) Old 04-04-2007, 09:51 AM
Ok, I need 2 part numbers.
O= <--- Is what it looks like. It sits on the shocks in the rear and is metal tubing and the circle part is hard rubber. The metal tubing slides over the shock.
My foglight bulb melted the harness it sat in. I need the part of the wiring harness the goes from the foglight bulb to the clip in the wheel well.
I know its all pretty vague, my apologies.
+rep for help
Spooner is offline
post #18 of 111 (permalink) Old 04-21-2007, 04:52 PM Thread Starter
Ok, I updated / added some stuff, including:
The Plug part number I had before was the platinum, no the unobtanium one.
The 99366-D1930 Serp belt number is Lexus only, the 90919-A2007 is a good Toyota number.
The Key ring bulb # 90010-01044 is another Lexus number. Its a common Toyota bulb "74" style. One can go to Sylvania.com to get all the bulb applications there.
Thanks for the input guys!
nautox is offline
post #19 of 111 (permalink) Old 04-21-2007, 04:59 PM
How about the number for the fog relay on IS300
- Andrew
2003 MSM IS300 M/T w/ LSD
AAC | AEM | Alpine | GReddy | JDM | JIC | JL | Philips | Pioneer | SportDesign | Tanabe
Sale Items For Audio Newbies!
https://my.is/forums/f99/fs-useful-au...6/#post4953185
Ashhong is offline
post #20 of 111 (permalink) Old 04-27-2007, 11:41 AM
Ninja?
hey guys, anyone of the part numbers for the following?:
exhaust manifold (lexus part number: 17140-46080)
y-pipe 2 in front and 1 in rear. (lexus part number: 17510-46580)
thanks
©2006 my.IS
2015 F32 w/ N55 Alpine White
DO SUSPENSION FIRST!
kayotik is offline
post #21 of 111 (permalink) Old 05-04-2007, 09:25 PM
Thought, I would chime in a bid since I have been ordering OE parts left and right for the rebuild.
Camseals for the VVT-i heads are different. The part no listed (90311-40020)is for the exhaust side. I just ordered two of them yesterday and came to find out it doesn't work for the VVt-i shaft.
A few more parts I acquired
Lower Oil Pan Bolts - 90119-06624
Waterpump Bypass Pipe No1 Bolt - 90105-06164
O- Ring for No1 Bypass pipe to the head - 96761-24028
Coolant Outlet Pipe Gasket - 16343-46020
Crush Washer/Gasket Oil Pipe from Block to VVT-i Solenoid 90430-16012
Eminence is offline
post #22 of 111 (permalink) Old 05-13-2007, 07:29 PM
Thats some good info to know,
Got it book marked
-2002 Intensa Blue 'Sportcross'
bradleyjpyle is offline
post #23 of 111 (permalink) Old 05-14-2007, 02:40 AM
Location: 87.9 mi Ė about 1 hour 42 mins from east parking lot
Quoted: 50 Post(s)
subscribed. +rep. good info guys!
black86 is offline
post #24 of 111 (permalink) Old 05-24-2007, 10:15 AM
i got another oil filter number and price for ya. i finialy found out the differnce between these filters...
90915-YZZG1 - Oil filter - 7.57 list - 4.95 actual
the YZZD1 is supposed to be for internal use at dealerships only, the YZZG1 (so im told by the parts manager from Priority Toyota) is the filter they are told by toyota to sell over the counter. same filter, it just has applications stamped on the D1 filter that the G1 doesnt have, but its the exact same filter. i bought 3 of them yesterday heh
Originally Posted by Mazdaspeed View Post
unsuccessful troll is unsuccessful.
richter is offline
post #25 of 111 (permalink) Old 06-08-2007, 12:59 PM Thread Starter
"90915-YZZG1 - Oil filter - 7.57 list - 4.95 actual"
MSRP on the G1 is $5.41 Most dealers have a profit bump on their parts. We sell them for $7.57 also.
Yeah, the G1's are USA made and the D1's are made in Thailand. I heard that the D1's were for the Sienna a few years ago, maybe to address a sludge problem?. Now the book says to use G1's on Sienna. Anyways. G1,D1,D3,B9's -all the same. I think I got 1 B9 left (made in Japan)
nautox is offline
post #26 of 111 (permalink) Old 06-09-2007, 04:35 AM
All,
I noticed the part number for the timing belt tensioner below. Are you supposed to replace this as well when changing out the timing belt for your 90K service? Anything else to replace in that area other than the water pump?
Secondly, I had to replace the rear axle on my IS about 1K ago and I also replaced the clutch. Not knowing about the importance of replacing the flywheel, nor advised by the mechanic, I now have a irritating noise unless I push the clutch in about 2 inches. I have now driven on the new clutch about 1K. Will I need to replace a new clutch when purchasing a flywheel? That is assuming the noise is infact the flywheel.
Any comments or recommendations are greatly appreciated.
lexusngermany07 is offline
post #27 of 111 (permalink) Old 06-13-2007, 01:27 PM
Originally Posted by lexusngermany07 View Post
All,
that noise from what i'm told is perfectly normal (it's not the flywheel but the throwout bearing). i took my car into lexus like 3 times to try to have them fix it, but they basically told me if i didn't like it, to sell the car. bunch of a$$holes...
anyway... big thanks nautox, i'll be putting this list to use for my 90k svc. coming up too. +rep
THIS THREAD SHOULD BE STICKIED !
[NLC--MA #004][Find me @ ISFanatics][Walk Hard]
Vouch List: Hiroshima, redline814, mixtapeguru, asukadc, SexusinmyLexus, Sparky, IntensaBlu, TDLI, Velocity02, BLK_IS350, Phil, IS_Monster, 02LexIS300, Chado, LexIS307, ToyotaPete, jakes_is, ayoitsstevo, 03_IS, 04_IS, acumenhokie, FutureISdriver, and everyone else I missed.
can't forget about enjoico
Seven0Three is offline
post #28 of 111 (permalink) Old 06-24-2007, 11:59 AM
+1!!
Here are two more to add. I posted these up in another water pump related thread, but figured they'd be more relevant here:
O-rings for water pump:
9676124028
9676124022
2010 Jaguar XFR - Mina exhaust with powdercoated tips, custom X-pipe, Mina carbon fiber front diffusers, hood louvers, mirrors and side vents, powdercoated stock Nevis wheels
The PL: It's all politics.
WRXtranceformed is offline
post #29 of 111 (permalink) Old 07-31-2007, 06:37 PM Thread Starter
Thanks! added the water pump o-rings. I'll check on the 90311-40020 Cam #
nautox is offline
post #30 of 111 (permalink) Old 07-31-2007, 07:54 PM
Originally Posted by WRXtranceformed View Post
+1!!
9676124028
9676124022
good deal, thanks man. i'm gonna need those here soon. i just hit 87k!
TRD parts list for the IS300!!! DtEW Stop, Drop and Roll 38 02-12-2013 08:08 PM
TRD parts list for the IS300!!! IS300 Owner's Forum 11 03-12-2011 12:32 AM
TRD parts list for the IS300!!! Showroom 7 05-12-2002 05:11 AM
TRD parts list for the IS300!!! General Discussion 4 11-11-2000 12:23 PM
TRD parts list for the IS300!!! Go Fast Stuff 1 11-10-2000 10:58 PM
