Is300 Part Numbers Spreadsheet (toyota) - Lexus IS Forum
post #1 of 111 (permalink) Old 01-29-2007, 07:01 PM Thread Starter
So here is a parts list I threw together of common Repair / Maintainance items for the IS300 that you can get from you local Toyota Dealer. I also added the TOYOTA MSRP prices as well. I work in Toyota parts so I don't know what Lexus charges for some of this stuff, but I'm sure its more
RED is stuff you can't get.
GREEN means you can't use the Lexus Number, but I found a Toyota one that works.
BLUE items are the ones you can easily walk in to a TOYOTA Parts department, give them the Part Number, and be on your way.
Dont forget to mention the "MR2 club, or Supra club" discount, you will usually save an addition 10%-20% under MSRP.
Enjoy. Please let me know of any wrong info, or numbers you want to add. I will happily include them.
-nautox
UPDATE:
Im listing the parts below so when people are doing searches on particular Part Numbers, this
post will show up. And also when non-members are surfing the web, they may find our site.
The original Color pics are still here, just as a click-able thumbnail. Enjoy!
DESCRIPTION PART NUMBER MSRP NOTES
AIR FILTER 17801-46080 N/A LEXUS ONLY
DOME LIGHT 90981-12014 3.97 TORPEDO STYLE
BULB; KEY 90981-11018 2.43 TYPE 74 STYLE Key Illumination
BUMPER CLIPS 90467-07138 1.87 $12 CHEAPER THAN LEXUS
Bypass Hose #1 16261-46020 12.99 Engine Rear
Bypass Hose #2 16264-46041 9.22 Engine Rear
CABIN AIR FILT 87139-48020-83 20.00 MANY TOYOTA'S
CAM SEAL 90311-40020 6.80 94-98 SUPRA 2JZGE x2
Clutch Bearing 90363-12002-77 9.85 MT / Input Shaft Bearing
Clutch Bearing 31230-22100 84.09 MT Release Bearing
COIL 90919-02216 123.77 94-98 SUPRA
CAM SEAL 90311-40020 6.94 TAKES 2
CRANK SEAL 90311-46001 13.26 94-98 SUPRA 2JZGE
DIFF PLUG; REAR 90341-18035 3.77 REAR END
ENGINE COOLANT 00272-1LLAC 16.19 LONG LIFE (RED)
EXHAUST GASKTS 17173-46050 - 2 of them. LEXUS ONLY
EXHAUST GASKET 17451-0D050 28.87 DOH-NUT
HEAD GASKET 11115-46045 88.75
REAR EXH GSKT 17420-74060 - LEXUS ONLY
FIPG - ENGINE 00295-00103 12.78 BLACK
FIPG - TRANS 00295-01281 20.38 RED
MAF Screw 90099-00289 0.63 x2-I lose them when cleaning MAF
FLYWHEEL 32101-22050 201.46 94-98 SUPRA
INTAKE TANK GAS 17176-46020 11.72
INTAKE HEAD GAS 17177-46060 9.99
FR ROTOR 43512-50100 N/A LEXUS ONLY
FR SHOCKS 48510-59315 N/A Can use KYB 341262 x2
FRONT PADS 04465-22311 N/A USE 04465-14081
FRONT PADS 04465-14081 50.95 93-98 SUPRA 2JZGE
Front Seal 90311-48013 7.56 X2 Front Left & Right Wheel
FUEL DOOR Sring 77360-12080 3.92 Clip Spring that opens Gas door
FUEL FILTER 23217-46090 8.92 INSIDE TANK
Fuel Injector 23209-46090 155.27 98 Supra; IS300. 3 Coils on Car
FUEL PUMP 23221-46120 N/A LEXUS ONLY
GAS CAP 77300-53010 16.88 ECHO YARIS XA XB SPYDER
HEADLIGHT TAPE 90950-06073 2.13 TSB BO002-01 MOISTURE x2
IDLER Pulley 13505-46041 80.54 94-98 SUPRA 2JZGE
Ign Coil Pack 90919-02216 123.77 98 Supra; IS300. 3 Coils on Car
INJECTOR 23209-46090 155.27 94-98 SUPRA
KNOCK SENSOR 89615-12090 165.10 00 CEL; 1MZFE;
MAF SENSOR 22204-0D030 146.36 03 COR; 05 TUN; 05 TAC ;
OIL FILTER 90915-YZZD1/D3 5.95 SUPRA LANDCRUISER V8
OIL Pickup Gskt 90950-06073 2.49 TACOMA; TUNDRA
OIL PR SW DENSO 83530-AA011 23.75 MANY TOYOTA'S
OIL PR SW YAZU 83530-60020 30.32 MANY TOYOTA'S
O-Ring Oil Pan 96721-24031 2.63 SUPRA; TUNDRA
OXY 1 (FRONT) 89465-53140 N/A BEFORE CAT, CYL 1-2-3
OXY 1 (FRONT) 89465-06010 139.35 98-01 CAMRY use 89465-06010
OXY 2 (FRONT) 89465-53110 N/A BEFORE CAT, CYL 4-5-6
OXY 3 (REAR) 89465-53120 N/A AFTER CAT, CYL 4-5-6
OXY 3 (REAR) 89465-06020 139.35 97-01 CAMRY use 89465-06020
PCV VALVE 12204-46030 8.16 94-98 SUPRA
PCV Grommet 90480-18001 4.40 Available at Toyota Dealers
RADIATOR CAP 16401-62100 13.12 82 Degrees Celcius
Upper Rad Hose 16571-46310 xx.xx Lexus Only
Lower Rad Hose 16572-46290 xx.xx Lexus Only
REAR MAIN 90311-90006 39.04 94-98 SUPRA 2JZGE
REAR PADS 04466-30161 N/A LEXUS ONLY
RR ROTOR 42431-30260 N/A LEXUS ONLY
RR SHOCKS 48530-59355 N/A Can use KYB 341263 x2
SERP BELT 90916-A2007 71.98 94-98 SUPRA 1 BELT RUNS ALL
Serepentine Tens 16620-0W025 186.31 Available at Toyota Dealers
SPARK PLUGS 90919-01219 10.37 Irridium; SK16R-P11
Spark Wire #1 90919-15456 16.89 For Plug 1, connects to 3rd Coil
Spark Wire #3 90919-15317 16.09 For Plug 3, connects to 2nd Coil
Spark Wire #5 90919-15457 16.57 For Plug 5, connects to 1st Coil
TENSIONER 13540-46030 67.10 94-98 SUPRA 2JZGE
THERMOSTAT 90916-03093 16.72 ECHO YARIS XA XB TACOMA
Thermost Gasket 16325-62010 5.00 MANY TOYOTA'S
Throttle Body 22271-46070 37.38 Gasket 98 SUPRA 2JZGE
T-Body Con Gskt 17849-46020 6.63
Throt Pos Sensor 89452-30150 83.88
Timing BELT 13568-49036 33.00 94-98 SUPRA 2JZGE
Timing Tension 13505-46041 78.82 94-98 SUPRA 2JZGE
Timing tensioner 13540-46030 68.53 Available at Toyota Dealers
Tim Cover Lower 11302-46031 52.02 94-98 SUPRA 2JZGE
Tim Cover Mid 11303-46040 48.59 94-98 SUPRA 2JZGE
Tim Cover Fr 11304-46060 75.45 94-98 SUPRA 2JZGE
Tim Cover Up Rr 11325-46042 34.67 94-98 SUPRA 2JZGE
Valve Cvr Gsk exh 11214-46011 13.65 94-98 SUPRA 2JZGE
Valve Cvr Gsk inta 11213-46030 11.97 94-98 SUPRA 2JZGE
WATER PUMP 16100-49876 N/A GS/IS LEXUS ONLY
O-Ring; Pump 96761-24022 2.63 Need 2 when doing Water Pump
O-Ring; Pump 96761-24028 2.63 Need 1 when doing Water Pump
WATER TEMP 89428-20110 88.00 ECHO; RAV4 01+
Wiper Insert L 85214-0E020 7.74 Graphite Impregnated; G550 mm
Wiper Insert R 85214-24050 4.45 Graphite Impregnated; B500 mm
Of the Parts Listed above; the following you CANNOT get from TOYOTA:
Hope this helps.
-Nautox
nautox is offline
post #2 of 111 (permalink) Old 01-30-2007, 11:47 AM
Crester's Avatar
In Canada you can get an air filter from Toyota dealers... I just got one! Even if they don't stock a Lexus part... most will be glad to order one in for you. And often times they sell it cheaper than Lexus dealers.
Crester is offline
post #3 of 111 (permalink) Old 01-30-2007, 01:26 PM
Toyota does have part manuals for any of the IS300 models, however, there are hundreds of interchangable parts that you could get from Toyota for your IS, but you would need to get the part no. for the part, otherwise they won't know if it will work.
We have already established the fact that the same parts from Lexus could be bought at Toyota for a little bid less.
Eminence is offline
post #4 of 111 (permalink) Old 01-30-2007, 01:32 PM
Crester's Avatar
Oh... when I read some of your statement... (especially the RED one)... I thought you were saying those were parts you cannot order thru Toyota.
Crester is offline
post #5 of 111 (permalink) Old 01-30-2007, 01:52 PM
sweet! is that the dual mass fly wheel for manuals?
SRT Intake | L-Tuned Exhaust | Clutch Masters FX100 | Fidanaza Aluminum FW | Ralco RZ Short Shifter | Pioneer Avic D3 | Pioneer Bluetooth | Pioneer Ipod |STANCE GR+ | Altezza Front Grill | Fog Light mod | Hotchkis Sways | BMW X5 Headrest with 7" screens | 15% Tint back 25% Fronts | Megan Y-pipe | Work Euroline DH 18x8.5, 18x9.5+5! | Wald Widebody | L-tuned sides and rear | Wald front | Flashtech LED |
quixs1lver is offline
post #6 of 111 (permalink) Old 01-30-2007, 02:47 PM
Thought I would add a few
O-Ring between upper pan and shortblock for oil port
Part No. 96721-24031 List - $4.87
Gasket Between Oil Pickup Screen and upper pan
Part No. 15147-AD010 List - $4.61
Eminence is offline
post #7 of 111 (permalink) Old 01-31-2007, 12:25 AM Thread Starter
I will add these numbers soon. Thanks.
nautox is offline
post #8 of 111 (permalink) Old 01-31-2007, 07:00 AM
I have alot more for, o-rings and gaskets just got to dig for them. Also, you know what would be good a part no. for the FIPG, I know lexus sell them for 20 bucks a tube, where toyota sells be them at 12 bucks. Alot of the go faster guys use em.
Eminence is offline
post #9 of 111 (permalink) Old 02-14-2007, 11:39 AM Thread Starter
Actually, the 96721-24031 is only $2.63 each and the 15147-AD010 is only $2.49 each.
nautox is offline
post #10 of 111 (permalink) Old 03-28-2007, 05:00 PM Thread Starter
Added bumper clips and fuel door spring. Any more?
nautox is offline
post #11 of 111 (permalink) Old 03-28-2007, 06:43 PM
heres a couple I linked today:
exhaust gasket: 17451-0D050
rear differential drain plug: 90341-18035
interior dome bulb: 90981-12014
key ring bulb: 90010-01044
SexusinmyLexus is online now
post #12 of 111 (permalink) Old 03-28-2007, 06:59 PM
Can you cross referance these cars to make sure they take the same Oil Filter?
03 IS300
04 Toyota Sienna
01 Toyota Avalon.
I use the same Toyota Oil Filter on all three
03 TCM Sportdesign
Bilstein Lsportline / Eibach Pro / FIGs Toe Control
Hankook V12 w/ Enkei EVO5 18"x7.5"-45et
SRT intake
Nunzie is offline
post #13 of 111 (permalink) Old 03-29-2007, 08:59 PM
No need to cross reference them. Toyota Parts only have 3 size/type of oil filters. All 6 cylinders use the same filter. All 8 cylinders use the same filter. And more recent vehicles IS250/350, GS, LS, LX, etc uses the paper style filters.
So to answer your question yes all those vehicles should be using the same oil filter.
Eminence is offline
post #14 of 111 (permalink) Old 03-30-2007, 01:25 AM
Ninja?
does anyone know the part numbers for the 3 gaskets that go on the y-pipe?
thank you in advance.
©2006 my.IS
2015 F32 w/ N55 Alpine White
DO SUSPENSION FIRST!
kayotik is offline
post #15 of 111 (permalink) Old 03-30-2007, 09:23 AM
Manufacturer of Pipes
Joe Z's Avatar
Nice work on the list...
I'm not too sure about some of these part numbers..
Just be sure to verify numbers and cross check with Lexus / Toyota before you buy any parts..
Example on the Spark plugs:
Below is what I bought & its exactly what it says on the red & white Genuine Toyota Parts Box.
This is the part # that came up on the Toyota/Lexus Parts computer for a 2001 IS300
Toyota Part # 90919-01219
DENSO SK16R-P11 - Iridium Plug
The above Denso part # is the same exact part # on the plugs that I pulled out of my 2001 IS300 with 88k miles.. (orignal owner)
Another FYI - Toyota rates the SK16R-P11 plugs "good" till 120K Miles..
While Lexus rates the same exact plug "good" till 90Kmiles..
Thanks
Joe Z
Five Axis Design R5:F Wheels on Continental Extreme DW
ALL MY MODS are For Sale here: Joe Zís Super Garage Sale
Joe Z is offline
TRD parts list for the IS300!!! DtEW Stop, Drop and Roll 38 02-12-2013 08:08 PM
TRD parts list for the IS300!!! IS300 Owner's Forum 11 03-12-2011 12:32 AM
TRD parts list for the IS300!!! Showroom 7 05-12-2002 05:11 AM
TRD parts list for the IS300!!! General Discussion 4 11-11-2000 12:23 PM
TRD parts list for the IS300!!! Go Fast Stuff 1 11-10-2000 10:58 PM
