Is300 m/t random shut off in neutral - Lexus IS Forum
post #1 of 21 (permalink) Old 04-15-2019, 01:08 AM Thread Starter
So I 2 days ago I went to change my brake like because it was leaking and I had an oil catch can to put on also so I ended up doing both. Did the brake line added oil catch can and has the car running again I noticed if I go above 4K in third gear and just put it in neutral the car will just die this happened about 12 time after the catch can it’s the the car can it recover in rpms is drops down around 400-500 rpms and just dies. It starts up ever time I took of the catch can reset my ecu and it didn’t happen for a while then about 30-45 minutes in it starts recovering bad again and died. It only happens once after I disconnected ecu. Idk what can cause this I’m kind of confused and annoyed at this point just trying to make it run good again lol
Enix2jz is offline
post #2 of 21 (permalink) Old 04-15-2019, 02:56 PM
Quoted: 339 Post(s)
Sounds like you have ether a lose connection or a vacuum leak.
Careful & Consistent
post #3 of 21 (permalink) Old 04-15-2019, 04:55 PM Thread Starter
Connection as a bad ground? I’ve been looking for a vacuum leak and haven’t seen one I’ll continue to look for vacuum leaks and maybe a bad ground as I did loosen a ground to get to the brake line. It hasn’t done it today I only drove about 15 minutes but I’ll continue to keep checking up on it. After I reset ecu it only died once so hopefully it can stay alive
Enix2jz is offline
post #4 of 21 (permalink) Old 04-15-2019, 04:57 PM Thread Starter
Also thanks for the reply im going at this blind so it’s kind of annoying. always helps when people have some input! I could’ve have easily over looked something as I’ve done before.
Enix2jz is offline
post #5 of 21 (permalink) Old 04-15-2019, 07:05 PM
It sounds like a vacuum leak to me too. Does it happen continuously or is it more of an intermittent problem?
2002manualsportcross is offline
post #6 of 21 (permalink) Old 04-15-2019, 08:30 PM Thread Starter
I’ve checked it out ima look a lot more maybe I disconnected something in the process of running my new brake line it runs along the fire wall so there a lot of tiny vacuum hoses there.
Enix2jz is offline
post #7 of 21 (permalink) Old 04-16-2019, 10:19 AM Thread Starter
Still haven’t seen no vacuum leaks I was being told that it can be my tps? Can this cause this problem?
Enix2jz is offline
post #8 of 21 (permalink) Old 04-16-2019, 06:30 PM
Quoted: 339 Post(s)
Originally Posted by Enix2jz View Post
Still havenít seen no vacuum leaks I was being told that it can be my tps? Can this cause this problem?
If you are just looking at the lines you may not see it. Try spraying carb cleaner on them and listen for rpm change or a sucking sound. I know this may be hard with it not running right. So you may need to have someone to help.
post #9 of 21 (permalink) Old 04-16-2019, 08:05 PM
Quoted: 126 Post(s)
TPS can cause a similar issue, especially if you disconnected the battery and made the ECU have to relearn the settings. Try checking the TPS setting while you are under there and see if it is within specification.
2001 Altezza Gita JCE10
Pnut00 is offline
post #10 of 21 (permalink) Old 04-17-2019, 01:40 PM Thread Starter
I did disconnect the batter when replacing line I also reset ecu
Enix2jz is offline
post #11 of 21 (permalink) Old 04-17-2019, 01:40 PM Thread Starter
I check the tps yesterday 2 of them read 3.2 last one was around 5
Enix2jz is offline
post #12 of 21 (permalink) Old 04-17-2019, 06:21 PM
Quoted: 126 Post(s)
Pretty sure there are only 2, the TPS (throttle motor) and APS (accelerator cable side), what is the 3rd?
Pnut00 is offline
post #13 of 21 (permalink) Old 04-19-2019, 01:23 PM Thread Starter
Smoke tested it yesterday didn’t see no leaks anywhere going to try again today
Enix2jz is offline
post #14 of 21 (permalink) Old 04-19-2019, 01:24 PM Thread Starter
1 ground 3 power? Maybe I’m wrong will look again after work
Enix2jz is offline
post #15 of 21 (permalink) Old 04-19-2019, 11:25 PM
Quoted: 126 Post(s)
oh you mean the 3 wires on the TPS? :D
There are 2 sensors, one of the accelerator side and one on the throttle body motor side.
Anyway, it sounds about right according to the manual
Name:	throttle sensor check.JPG
Pnut00 is offline
My love for IS300's jesuspuppy General Discussion 8 04-08-2019 03:54 PM
01 is300 misfire, throttle bogging, and random shutdowns reooke General Discussion 5 10-22-2018 01:35 PM
2018 IS300 RWD 2.0L 4-cylinder turbo crazyhorse New Member Introductions 0 05-02-2018 11:23 PM
Random popping/jerking when in gear or neutral Blowenos Basic Help & Repair 4 11-04-2017 09:17 PM
M/t is300 aristo swap questions aj08g Go Faster 3 09-03-2016 08:31 AM
