IS200 Front upper balljoint fitting (old one is broken) - Lexus IS Forum
post #1 of 5 (permalink) Old 05-14-2019, 10:04 AM Thread Starter
Hi, I have done some research online and this forum keeps popping up so thought I would join.
On my 02 IS200 I need to replace the front upper balljoint, it was really crusty due to salt/bad weather over the years and the car has relatively low miles so probably still the original. When removing it managed to snap in half, so now I have a bit stuck in the top control arm, and a bit stuck in the hub
1. Can the ball joint be changed without having to remove the front arm?
2. I have tried my best to tap part of old balljoint up and out of the hub part but it simply is not moving or going anywhere. I dont think this is threaded? Has this happened anyone before and what can be done to get it out
Thanks in advance
DMCC is offline
post #2 of 5 (permalink) Old 05-14-2019, 01:07 PM
Quoted: 140 Post(s)
You can buy the ball joint separately thru Figs Engineering:
https://www.shopfigs.com/v3/IS300BJ-...20ball%20joint
I doubt you can replace the ball joint without taking the control arm out. You might need heat to expand the metal around the ball joint then hammer it out.
Piggity is offline
post #3 of 5 (permalink) Old 05-14-2019, 04:04 PM
Quoted: 322 Post(s)
Most parts stores sell and rent a ball joint separator.
Careful & Consistent
post #4 of 5 (permalink) Old 05-15-2019, 07:56 AM
Probably easier to take the arm out and use a press
Lexyaaaas is offline
post #5 of 5 (permalink) Old 05-15-2019, 08:01 AM
He said they rent the tool.... relax son.
Also Rocar sells the ball joint itself. No name aftermarket exist too if you do some research, cross referencing IS200 stuff.
I'd personally get Figs cause I love his stuff.
wrong, figs is the only one that sells the ball joint by itself. If you want to buy the entire upper control arm then yes, the parts store can help you.
theraflu is offline
white_is build thread! (Bumper back on... 1/1 white_is Member Build Threads - Lexus IS only 1869 04-14-2019 07:57 AM
Cheap IS300 front upper arm? VegasIS3 Stop, Drop and Roll 3 03-14-2019 04:49 PM
Rocar front upper ball joint jeddyminit Stop, Drop and Roll 4 02-04-2017 03:50 PM
Front Upper Strut Tower Bar Fit w/ Engine Cover Posh469 General Discussion 9 08-17-2016 03:41 PM
Figs front upper ball joint replacement DIY thekingofchina DIY/tutorial forum 6 06-23-2016 08:19 PM
