HELP! Newbie -- P0440 - Lexus IS Forum
post #1 of 13 (permalink) Old 03-09-2011, 10:32 PM Thread Starter
Hi all, I'm a newbie here on the Lexus Forum. I just bought a 2001 Lexus IS with 60k miles. I am getting an EVAP code P0440. What I noticed happening is, everytime I fill the tank (full) and drive about 80 miles, the check engine light would come on. I know I have a leak somewhere coming from the rear of the car because I can smell fuel after I drive the car and park it inside the garage. Seems to be coming from the Right rear wheel well. Wierd thing is, when I fill the tank only 3/4 full, and drive, the check engine light won't turn on. I can keep filling it only 3/4 full and No check engine light. Once I do a full tank, guaranteed check engine light after about 80 miles.
Any ideas? maybe one of the check/vent valves? Anyone have this problem before? Thanks in advance!
Ric
recaro18 is offline
post #2 of 13 (permalink) Old 03-10-2011, 03:14 AM
when your fillinng your tank the whole way, the EVAP vent is is getting stuck closed, thus giving you a CEL. the Vent is located in the tank. Its like a buildup of pressure if im correct.
post #3 of 13 (permalink) Old 03-10-2011, 02:31 PM Thread Starter
so do I have to drop the tank to get access to the EVAP vent valve? or can it be accessed by removing the rear bottom seat?
recaro18 is offline
post #4 of 13 (permalink) Old 03-10-2011, 04:02 PM
fathorsejr is offline
post #5 of 13 (permalink) Old 03-10-2011, 04:05 PM
From the rear seat...but I wouldn't jump to conclusions yet. This is a list for that code;
P0440 (evap emission control sys malfunction). Troubled areas:
Hose cracked, holed, damage or loose seal.
Fuel tank cap not installed properly, cracked or damage.
Vac hose cracked, holed, blocked, damage or disconnected.
Fuel tank cracked, holed or damage.
Charcoal canister cracked, holed or damage.
Open or short in vapor pressure sensor circuit.
Vapor pressure sensor.
Fuel tank over fill check valve cranked or damage.
ECM
I know our cars don't like to be completely filled with gas, especially past the point to where the gas pump automatically stops. The purge EVAP valve can get stuck. Honestly what I would do since you didn't pull any of the other codes, is to make sure the gas cap seal is good and that it is on there good and tight(few clicks). The IS300 picks up on a loose/bad cap very good. Then I would drive it a bit to use maybe an 1/8 of a tank. Then the code will either go away on its own or you can pull the negative off your battery for a few minutes to reset the code. If the code comes back then you may have to look at getting to the charcoal canister to check the vent. I don't know if you did/do, but I would always stop refueling when it stops itself. I would wait and see what happens.
post #6 of 13 (permalink) Old 03-10-2011, 05:29 PM
Definately replace the Gas cap no matter what. Toyota or Lexus dealer
part number(s) 77300-53010 or 77300-08010.
If that doesn't do it, the cannister is probably bad (from the previous owner
over-filling / topping off the tank)
nautox is offline
post #7 of 13 (permalink) Old 03-11-2011, 02:11 PM Thread Starter
yep...gas cap from the dealer was the first thing i did....still throwing a P0440
recaro18 is offline
post #8 of 13 (permalink) Old 03-11-2011, 02:14 PM
Have you tried to clear the code as I mentioned to see if it comes back. The code may just be stuck.
post #9 of 13 (permalink) Old 03-14-2011, 02:49 PM
Damn I am having the same exact problem! I hope we can figure it out! Mine keeps coming back. I'll try driving for a few hours until I am almost empty then fill up half way later today. Hopefully I just overfilled!
mattscar is offline
post #10 of 13 (permalink) Old 03-14-2011, 04:38 PM
You are pulling a P0440 code and it won't clear?
post #11 of 13 (permalink) Old 07-24-2011, 04:28 PM
hate to bump this but i have the same issue.... anyone have updates?
01 MSM Wald front, sides, l-tune rear
pogodamonkey112 is offline
post #12 of 13 (permalink) Old 07-27-2011, 01:41 PM
+1 for updates... I checked the gas cap hoses and then used a OBDII scanner tool and erased the code which worked and then it came back after 2500 miles, might have to just take it to the dealer.
mattbeeezy is offline
post #13 of 13 (permalink) Old 07-30-2011, 10:35 AM
Im going to go with Charcoal cannister, my IS is giving all the symptoms indicated above. I replaced the gas cap and did NOT fill the tank up so no CEL yet, however I can still smell the fuel vapors near the right rear wheel.
cel p0440 x2, p0446.. wat do i do? phucmang Basic Help & Repair 7 10-09-2015 10:06 PM
CODE P0440 EVAP Emission shenmecar Basic Help & Repair 3 02-09-2010 08:49 AM
C.E.L Code P0440 dr.tran Basic Help & Repair 2 01-05-2007 07:33 AM
CEL Codes P0440 and P0446 m4ha7m4 Basic Help & Repair 7 09-26-2006 03:50 PM
new toyo header and P0440 code eaglet25 Go Fast Stuff 20 04-17-2006 10:16 AM
