Dome light, door locks and remote not working - Lexus IS Forum
post #1 of 13 (permalink) Old 10-14-2011, 01:04 PM Thread Starter
Hi guys, I've got a 2001 IS300 base model (no roof or fogs and 16" wheels) Ever since I got the car the remote, door locks and dome light haven't worked. The locks will work when the car is running with the button on the door. I have been a mechanic for 16 years and specialise in the electronics but have no access to wiring diagrams for Lexus. I have checked ALL my fuses, even replaced my 7.5A dome light fuse and my 10A MPX-B. I have no power to the dome light connector on the light assm. I have tried reprograming my remote but since the locks dont work with the key out I cant begin the procedure. I believe I have an open wire somewhere because everyone else seems to have the 7.5 or 10A fuse blown. I currently have the battery disconnected trying to reset the computer. Any help would be appreciated.
Dan
baxterdan is offline
post #2 of 13 (permalink) Old 10-14-2011, 02:48 PM
Dan
The 7.5A Dome and 10A MPX-B fuses should always have battery power(+12 volts) to ground even when the car is off. But before the battery feeds those fuses, it goes through the 20A ECU-B1 fuse, which is located by the battery. I would double check inside that relay/fuse box before determining there is an open feed wire.
post #3 of 13 (permalink) Old 10-15-2011, 07:56 PM Thread Starter
WOW!!! jason you rock! Turns out someone had pulled that fuse (ECU_B1) and placed it in the "spare" location beside it! So as I was testing each fuse it passed my continuity test. Installed it in the correct location and everything came to life!! Thank-you so much, my friend who has Mitchel on demand was helping me over the phone but since he's not to good with the electronics we didn't get to far. As for the double post, I'm sorry, I'm still trying to figure out how to use the forum, Still don't know the difference between a post and a thread yet but I'm learning. Thanks again, that made my day. Now off to Walmart late night to get a battery for my remote and soon Ill have keyless entry too!
Dan.
post #4 of 13 (permalink) Old 10-15-2011, 07:59 PM
glad to hear that's all it was. not sure why they would've done that though. If I recall correctly, you'll need a CR1616 battery for the key fob.
post #5 of 13 (permalink) Old 10-15-2011, 08:31 PM Thread Starter
Yup you are bang on with that battery number! Just got back, installed the battery and the remote works! Didn't even need programing. You are quite the IS expert, thanks for all the help.
Dan.
post #6 of 13 (permalink) Old 12-20-2012, 06:40 PM
so all my doors lock but not my drivers side should i check the fuse box as well?
foxhound705 is offline
post #7 of 13 (permalink) Old 12-20-2012, 07:12 PM
If there's no activity from the master key fob then check the 10A MPX-B and 7.5A Dome fuses in kick panels(this is providing the key starts the car and battery is confirmed good). If it's just one door then try it with the button. It may be an actuator or linkage issue, there's a few tutorials on how to remove the panel and actuator.
post #8 of 13 (permalink) Old 02-13-2014, 02:45 PM
I've got the exact same problem as thread poster, but my 20A ECU-B1 fuse is okey, any ideas?
I also noticed the clock starts on 1.00 every time I turn on the ignition.
this problem happened when I had the AC panel out to change some bulbs...
Morten B is offline
post #9 of 13 (permalink) Old 02-13-2014, 05:16 PM
Sounds like you shorted a constant positive out and you have a bad fuse, which is why the clock resets. Make sure to check both kick panels and fuses near the battery for one you may have missed. If not, post back.
post #10 of 13 (permalink) Old 02-28-2014, 04:02 PM
it was that MPX-B fuse that was blown.
where can I find a map that tells me what fuse i for what?
what does MPX-B stand for? dont understand all those shortened words...
my other cars it says witch is what on the fuse box with words, and in the instruction manual ( have one in Deutsch but I don't speak german, but ether way, cant find a chart in there..
Morten B is offline
post #11 of 13 (permalink) Old 02-28-2014, 04:25 PM
That fuse means the Multiplex Communication System. T he 10A MPX-B feeds a number of things, mainly the body module and communication system within the car. There is a layout of the fuses, what they feed and what they are for in the diagnostic manual, which is a sticky thread in a few forums.
post #12 of 13 (permalink) Old 03-03-2014, 06:15 PM
Dome fuses in passenger fuse box
2001 IS300 E-shift Sun Burnt Orange _K&N Intake _Easten Headers _Greddy Exhuast
NoPantsChance is offline
post #13 of 13 (permalink) Old 07-19-2017, 08:07 PM
Remote doesn't work with car either does dome lights & other interior lights. What can be the problem? Any parts website for parts dealing with steering & transmission ?
Odainee is offline
Door locks do not work, nor does key remote.....Lextech?! *FIXED* tsopranoMB Showroom 34 10-14-2011 04:20 PM
Map light and Dome light on when you open the door? haiimbrian Showroom 28 05-04-2010 08:54 PM
Dealextreme:White LED Cabin/Dome/Door/Glove Box Light turboa Showroom 12 11-07-2008 08:44 AM
Help! Interior map and dome light are not working! dirtyylicous Showroom 6 07-04-2007 10:25 AM
Help! Dome light stays on when door shut dirtyylicous Showroom 14 06-25-2007 04:34 PM
