Coolant leak - Lexus IS Forum
post #1 of 3 (permalink) Old 01-13-2018, 04:52 PM Thread Starter
Previously did a post about a fluid found on my water pump. Figured out itís coolant. I canít figure out where itís leaking from. From the over flow and all the way to the right, my radiator is soaked top to bottom. While the left half of my radiator is bone dry. Is there any specific spots or hoses to check? Iíve looked everywhere not sure if Iím missing something. My radiator had a hair line crack but itís sealed and not leaking from there at all or around the cap. Also my coolant is full which is also strange. But itís leaking from somewhere causing steam to roll from under my hood from the radiator. Any help is greatly appreciated!!
ALSO, my coolant was completely gone the other day when I first noticed the steam. But my car didnít over heat at all which was really strange. Today itís 100% full.
post #2 of 3 (permalink) Old 01-19-2018, 02:14 PM
Quoted: 34 Post(s)
based on it being by the water pump - i would say the water pump..
maybe the gasket ... or one of the connections to the water pump.. if i recall the water bypass is right around there.. and thermostat is in that area as well..
its been a couple of years when i replaced the water pump - but i remember there being a few o-rings/ and gasket connections
so the level in the coolant tank is full.. and in the expansion tank is full too?
chunktwo is offline
post #3 of 3 (permalink) Old 01-21-2018, 01:45 AM
Quoted: 126 Post(s)
Sounds to me that you have a good place to start. Any patch you apply is a temporary fix, if it has split the plastic has perished to a point where is has lost its integrity. It has to contain a hot fluid pressurized to 16psi, any small gap will be exploited. The only way to fix properly it is to replace the tank, then i would start looking at the parts around the pump and hoses.
2001 Altezza Gita JCE10
Pnut00 is offline
Transmission leak? (W55) Teheggy Basic Help & Repair 2 11-08-2017 12:19 PM
Coolant line routing for turbo-new comp oiless turbo puertorico Go Faster 1 04-11-2017 08:10 AM
2006 IS350 Oil Leak. Help! wjenkins88 General Discussion 0 03-21-2016 11:22 AM
coolant leak behind cylinder head... VEHEMENCE General Discussion 2 02-09-2016 06:18 PM
Oil leak :/ DarK StaR General Discussion 7 12-13-2015 02:32 AM
