CEL Code Database - Ask Question's Here - Page 3 - Lexus IS Forum
post #31 of 181 (permalink) Old 08-26-2009, 11:54 AM
I've fixed my P0037 code by jumping the wires from my working O2 sensor.
But, I still have the P0016 code (Crankshaft position - camshaft position correlation bank 1 sensor A)
I checked the resistances for the sensors and got 1.0 K Ohms for the Camshaft Position sensor and 2.1 K Ohms for the Crankshaft position sensor.
Can someone confirm these readings are correct. Both were taken with a cold engine.
P-townLex is offline
post #32 of 181 (permalink) Old 09-06-2009, 01:23 PM
So it turns out I had just installed one of the sensors backwards. A simple flip fixed my problems.
03 GGP Sport Design
Greddy CF Front Lip + AAC CCFL 8k Halo Headlights
Greddy Evo II Cat-Back + SRT Intake + R-ECU
Ghazali_GTE is offline
post #33 of 181 (permalink) Old 09-24-2009, 12:40 PM
Hi im looking to buy this 2002 IS300, but the check engine light is on and it says 02 sensor is bad, and the abs sensor is shot since it gives a vibrating feeling on the brake when u apply it. please im looking for advice or a way to fix this problem.
JohnnyBgood is offline
post #34 of 181 (permalink) Old 09-24-2009, 01:26 PM
acumenhokie's Avatar
Obviously you're going to need to replace both. You can view this thread for a location to buy the parts:
https://my.is/forums/f87/lexus-parts-...ce-oem-317041/
and this thread has the repair manual if you're looking to do it yourself:
https://my.is/forums/f138/here-you-go...manual-386133/
IS300 Alumni
acumenhokie is offline
post #35 of 181 (permalink) Old 09-27-2009, 10:48 AM
quick question if you have to replace one bad O2 sensor should you replace all at the same time? I just got all of them replaced due to the technician telling me its better all get replaced once one has bit the dust. So I bit the bullet and got them all replaced. My engine light went off and the trac light as well. Which was good but now its 4 days since i got that fixed and behold today when i turned on the car there were my two friends the CEL and Trac light both on. I am so pissed. I will be going back to the shop but have to wait till tuesday since tommorow is a jewish holiday.
Update when to my sears auto center, could not wait till tuesday. The code was P0453= Evap emission control to high. Well they took of the code and the CEL and Trac light went off. hopefully they stay off. Still going to take it in back tot he shop and see what they tell me. Anyone ever got that code before?
Raverx17 is offline
post #36 of 181 (permalink) Old 09-27-2009, 06:15 PM
Code P0453!!
Hey guys my CEL light and trac came on. I went to get the code read and it gave out P0453 (Evap Emission control to high) Does anyone know what this might be. The shop took off the code, it has yest to return but I'm hoping it does not. Also I recently changed 02 sensors. Any feedback would be helpful.
Raverx17 is offline
post #37 of 181 (permalink) Old 09-28-2009, 07:25 AM
post #38 of 181 (permalink) Old 09-29-2009, 07:11 AM
Thanks, Well the CEL and trac just came back on today. Have to take it to the shop and see what they have to do to fix this problem. I hope is not to expensive.
Raverx17 is offline
post #39 of 181 (permalink) Old 10-05-2009, 12:54 AM
just ran my is300 and got..
p0430..p0442..p0446..and p0430...can u guys tell me what i need 2 do to fix this?
pearl_IS is offline
post #40 of 181 (permalink) Old 10-05-2009, 02:14 PM
Why would this O2 sensor go bad so quickly? At least to me I replaced my O2 sensor about three years ago and I just got the check engine and trac off light again. I know I have to get the code once again but I'm guessing that it is the O2 sensor again.
wmatos is offline
post #41 of 181 (permalink) Old 10-07-2009, 10:20 AM
I just got this code (P1349) right after changing the timing belt a fixing an oil leak coming out of a seal (right above the oil tank). Replaced the whole thing and did an oil change as well. The engine runs fine. Just the check engine and trac off light.
wmatos is offline
post #42 of 181 (permalink) Old 10-07-2009, 10:51 AM
I have code P1349. I had a mechanic do some repair and I got the code P1349 a few minutes after I drove off. They fixed and oil leak coming out of one of the seals, change the timing belt, oil change...etc. What could be the problem? Eminence mentioned about being the VVTI solenoid! Where is this located? I could do this work myself. I changed the spark plugs and cable thinking it was this, although I needed to do them anyways. The car runs great. The only thing is the lights, Check Engine and Trac Off.
wmatos is offline
post #43 of 181 (permalink) Old 10-07-2009, 07:11 PM
Hi
I got an CEL and a scan showed code P0174. System too Lean Bank 2
Question: Since only the bank 2 error is popping up, would that mean the error is solely in the B2S1 O2 sensor? or could the problem still be somewhere with fuel injectors/MAFS/fuel pressure/other O2 sensors?
Spedmen is offline
post #44 of 181 (permalink) Old 10-07-2009, 07:29 PM
driving with P0174
I got a P0174 Code, but no p0171, I cleaned the MAFS but CEL still on. I got to drive from san diego to LA and back tomorrow. will the car be fine or should I rent?
Spedmen is offline
post #45 of 181 (permalink) Old 10-07-2009, 09:43 PM
Clean your MAF it takes 10 minutes. I'd say you'll be OK.
IS300 Alumni
