CEL Code Database - Ask Question's Here - Lexus IS Forum
post #1 of 181 (permalink) Old 03-04-2009, 01:58 PM Thread Starter
Ninja?
First, check your problem codes here:
OBD-II Check Engine Light Trouble Codes
Then, ask your question (if you have any) and members will answer them to the best of their ability.
Thanks
©2006 my.IS
2015 F32 w/ N55 Alpine White
DO SUSPENSION FIRST!
kayotik is offline
post #2 of 181 (permalink) Old 03-04-2009, 03:02 PM
acumenhokie's Avatar
IS300 Alumni
acumenhokie is offline
post #3 of 181 (permalink) Old 03-04-2009, 05:47 PM
Quoted: 219 Post(s)
Great idea. This should be helpful for the numerous CEL threads we get every week.
rvalero is offline
post #4 of 181 (permalink) Old 03-08-2009, 03:14 PM
I might as well start then lol...I just pulled the codes from my car and I get the codes p0110 and p0430. Would this be the o2 sensor or am I looking at the cat as well?
'02 Black Onyx E-Shift
Tokico Illuminas | Tanabe NF210 | K&N Filter | PowerSlots | EBC GreenStuff
Back to stock rims for me ^^
krnlight is offline
post #5 of 181 (permalink) Old 03-08-2009, 03:31 PM Thread Starter
Ninja?
PO110 seems to be your Air Fuel Metering.. that would point me (i would think) to the MAF sensor. You may have to clean that out, and the worst case would be to replace it ($150)
PO430 is catalytic convertor failure.. which means you'll probably have to get a new cat.
©2006 my.IS
kayotik is offline
post #6 of 181 (permalink) Old 03-17-2009, 02:06 PM
Thanks for the assist, I found out that besides my MAF sensor being dirty, my alternator gave out so I replaced it too and it seems to have gotten rid of my CEL codes period. I have a feeling though I'm going to have to replace the battery as well since it is getting up there in age.
krnlight is offline
post #7 of 181 (permalink) Old 03-20-2009, 06:31 PM
Help, I failed emissions!
I have an 2004 IS with 80k miles and I have 4!!! error codes! I am in a slump right now and don't can't afford a high bill to get all of these fixed. I need a good solution on the best steps to approach to get this fixed, asap. Do I need to go to a shop and pay them to run a scan? please help guys
Error Codes
P0154- no circuit activity detected
P0430- catalyst efficiency below threshold-bank 2
P2127- AF sensor signal stuck lean 21
P0153- circuit slow response
SnIS300 is offline
post #8 of 181 (permalink) Old 03-29-2009, 06:10 PM
got a check engine light, checked the code
came up p0141, heater circuit malfunction
appears to be faulty 02 sensor, how do i know which one? and where the best place to buy one?
chicotunner07 is offline
post #9 of 181 (permalink) Old 03-30-2009, 06:56 PM
is there a manual way of finding the codes without a scanner?
f4tman is offline
post #10 of 181 (permalink) Old 03-30-2009, 07:00 PM Thread Starter
Ninja?
no.
©2006 my.IS
kayotik is offline
post #11 of 181 (permalink) Old 03-30-2009, 07:04 PM
Just noticed it James. Great sticky.
- Greg '03 BO SD 5-spd.
Originally Posted by EricK
I'm a f#$%&r then
MrGregski is offline
post #12 of 181 (permalink) Old 04-22-2009, 10:44 AM
hey,i plugged the scanner in and got p0171 and p0174 i also got the same numbers with a p and d....any ideas? the scanner says its system too lean any help is appreciated thanks.
i am a person.
DaRealone is offline
post #13 of 181 (permalink) Old 04-22-2009, 10:47 AM
Start here:
https://my.is/forums/f87/two-codes-po171-po174-265993/
https://my.is/forums/f87/check-engine-light-316394/
https://my.is/forums/f87/help-p0171-p0174-255303/
IS300 Alumni
post #14 of 181 (permalink) Old 07-15-2009, 04:53 PM
p1349 code mechanic trouble
hi, ive got an 02 IS auto
i had error code p1349, took the car to the mechanic and they told me my vvt solenoid needed to be replaced so i had them do that along with some other work (timing belt, water pump)
picked the car up and 20 miles later the same code came up
took the car back in and they said they had put the solenoid in incorrectly which took them all day to fix and then they took half of the next day to fix the timing
picked the car up and 2 miles later the same code came up
took the car back and they have it now and are still working on it
Are there other areas they should be checking out for p1349?
Could the CEL be malfunctioning and should they be able to figure that out easily?
Any help is appreciated and let me know if I should provide more info. thanks
goinbacktokali is offline
post #15 of 181 (permalink) Old 07-15-2009, 05:05 PM
first of all how do you put a vvt actuator in backwards? and fix the timing? this is an INTERFERENCE motor, if the timings off you got bent valves, sometimes if your oil does not show up on the dipstick or your motor is sludged your vvt actuator wont work because its not getting oil pressure,
did it idle rough?
natodog is offline
