Car Works, then Doesn't!! Help! - Lexus IS Forum
  • 1 Post By Hodgdon Extreme
post #1 of 4 (permalink) Old 05-16-2019, 09:40 AM Thread Starter
Hey,
My 2008 Is 250 was working fine. At my condo we had to move the car out of the garage for maintenance. I moved it 3 days ago. I went to start it:
1. All electronics work fine, but...
2. It will not start!
I did the old undo the negative terminal and tighten the gas cap stuff to try to right the problem (it worked before when the VHC thingie happened). No use!
Might I have a dead battery or, what?
Also the brake feels tight when I push on it to start the car.
Any ideas will help. Thanks!
Cheers,
HF
pv146 is offline
post #2 of 4 (permalink) Old 05-16-2019, 01:49 PM
Quoted: 321 Post(s)
Brake problem and not starting may be a hose off. Causing a big vacuum leak.
Careful & Consistent
post #3 of 4 (permalink) Old 05-16-2019, 04:21 PM
Quoted: 48 Post(s)
Mathieu Bernier likes this.
Hodgdon Extreme is offline
post #4 of 4 (permalink) Old 05-17-2019, 03:34 AM
Quoted: 36 Post(s)
They are very picky when battery voltage drops below 11V they refuse to start. Brake pedal is stiff because you've pushed on the brake pedal while you've tried to start it. ( i guess you've tried a couple of times, so the brake system is pressurised) When you'll have a jumper pack connected to it and car will start, brake pedal will go back to normal feel.
Color: Cromax YR580M
TRD Carbon Fiber Shifter Ball
Fidanza Exhaust Cam Gear
SPC Rear Camber Kit
Continental ProContact Tires
Mathieu Bernier is offline
My love for IS300's jesuspuppy General Discussion 8 04-08-2019 03:54 PM
Choosing the right Outdoor Car Cover nipaarovi New Member Introductions 0 10-26-2016 11:36 PM
Wet Sanding works on car paint and headlight scratches & oxidation Cheez General Discussion 0 10-15-2016 10:49 PM
