Car starts but no power....HELP!!! - Lexus IS Forum
post #1 of 10 (permalink) Old 03-25-2009, 12:31 PM Thread Starter
hey wassup....im in a jam here. I just recently swapped my battery and when starting the car the engine starts, but then there's no power to anything besides the headlights. There's no power to instrument panel, radio, climate control, windows, locks, brake lights,and cant even put the car in drive....etc. ....i've already tried resetting the ecu by disconnecting the neg cable...any help is appreciated.
future781 is offline
post #2 of 10 (permalink) Old 03-25-2009, 12:37 PM
Ninja?
Go back and tighten your neg. cable some more. It has to be VERY tight.
©2006 my.IS
2015 F32 w/ N55 Alpine White
DO SUSPENSION FIRST!
kayotik is offline
post #3 of 10 (permalink) Old 07-31-2009, 12:47 PM
anything else that could be causing this? i tried to start my car yesterday and the starter motor didn't even turn so i got a jump start and the car started right up with all the electricals working
i got out of my driveway and the car started acting weird. trac light was flashing along and the radio kept turning on and off by itself. when i pressed the brakes the battery light would turn on momentarily and turn off. when accelerating the car felt like it was turning on and off and misfiring. however after about a minute of this the car felt perfectly fine so i just thought the ecu was resetting. i drove about 15 miles driving on the freeway and back locally and after about idling about 2 stoplights on the 3rd stoplight and car turned off and again the starter motor wasn't turning when i tried to start it.
someone finally pulled over to give me another jump start but this time when i turned the car on none of the electricals turned on. rpms, gas gauge, temperature gauge, radio, none of it was working. however the security light and dome lights would turn on even w/o the engine on. now assuming it was the alternator i just replaced it and now the engine starts up fine, however the electricals still won't turn back on
HELP!
2004 MSM IS300
| Tein HA | JoeZ | Blitz | Project | Work | HKS | Xerd | GROM iPod |
3 Steps to Fit your Wheels
jon4862 is offline
post #4 of 10 (permalink) Old 07-31-2009, 01:22 PM
Quoted: 60 Post(s)
get a fuse tester and test all your fuses. You could have blown a fuse when you started your car with the new battery.
DemonIs300 is offline
post #5 of 10 (permalink) Old 07-31-2009, 01:50 PM
^Yep, though I think you can visually determine whether a fuse is blown when you pull it out. This was the case when I had a fuse blown after getting my old drained battery jumped a couple times. My radio wasn't working after I got my battery changed and it was a simple fix. Hopefully yours is as well
02 IBP IS300
thomasjyang is offline
post #6 of 10 (permalink) Old 07-31-2009, 04:58 PM
it was the main electrical fuse (if there is even one "main" electrical fuse), that's what the guy at the shop told me. now i don't have a car until sunday bc no one has the fuse and it has to be ordered in ..anyone know how much these run?
2004 MSM IS300
jon4862 is offline
post #7 of 10 (permalink) Old 07-31-2009, 11:03 PM
Quoted: 60 Post(s)
Did they pull out the fuse and show it to you? Cuz usually, when shops figure out what is wrong with your car, they will show you what is broken or blown. If they didn't, they could be pulling your strings to make you pay more then you have to. If you trust the people that is working on your car right now, then it's your money .
post #8 of 10 (permalink) Old 08-01-2009, 09:33 AM
Wow, you took it to a shop already? You can just pull the fuse cover off and check the 30 and 40 amp fuses with a flashlight. And by the way, it couldn't be the "main" fuse because thats the 100 amp one that if its blown, your car wouldn't start and NOTHING would have any power whatsoever. That fuse only blows when you hook the battey wrong or jump start it backwords.
nautox is offline
post #9 of 10 (permalink) Old 05-29-2014, 02:08 AM
Bump. Having this same issue. Help.
airwalk1616 is offline
post #10 of 10 (permalink) Old 11-30-2018, 02:56 AM
Just had the same problem! Tighten the cables!!! They were loose!
Randen is offline
Engine starts but no power to anything...HELP!!! future781 IS300 Owner's Forum 2 03-25-2009 03:51 PM
Car starts then shuts off BlueIS5 Basic Help & Repair 2 09-29-2008 12:34 PM
Please Help!!!!! Car starts when shifting into Park, Neutral JBAKER Go Faster 15 04-18-2006 04:34 PM
50ish mph and car starts to rattel **UPDATE** ISpimpin Wheels and Tires 12 11-09-2005 01:08 PM
