Car died on the way home, no spark - Page 2 - Lexus IS Forum
post #16 of 29 (permalink) Old 08-12-2012, 01:46 PM
Originally Posted by Is300wanted View Post
Charged the battery and the car fired right up, not really sure what caused the fuse to blow in the first place but im very happy right now that so far its been a free fix. Jason you have been very helpful this forum is very lucky to have you.
Glad i could help and the fuse is not blowing. If it does again, i can show you how to narrow it down to find the fault. Good luck
post #17 of 29 (permalink) Old 08-13-2012, 11:10 AM Thread Starter
Well just as I feared the fuse keeps blowing when I drive it, I can get around at 20-30 mph but if I speed up or get on it, pops immediately. I checked with my scanner and the only code I get is P0141, which ive been getting from my header install anyway, just a thought though when I did the plugs and wires not long ago I used dialectric grease on the harnesses that plug into the coil packs because the clips were broken, could it be shorting across through the grease?
Is300wanted is offline
post #18 of 29 (permalink) Old 08-13-2012, 11:29 AM
I would change B1S2 become you are throwing a heater malfunction for it and the EFI does feed all the heater circuits. I haven't heard of too many causes where a heater circuit blows the EFI, but there's definitely a problem there. The EFI also feeds the fuel pump. I would replace B1S2, inspect the wiring for that sensor, and see if it holds.
post #19 of 29 (permalink) Old 08-14-2012, 12:46 AM Thread Starter
I tried unplugging the 02 sensor and it changed nothing, I still blow the EFI fuse, so I dont suspect the short is coming from that, I looked wirring over in the engine bay and do not see anything out of place, pinched, burned, etc. I drove the car again and blew several fuses to try to narrow down what causes it. Doesnt matter if the car is hot or cold, doesnt matter if its hard acceleration or not, sometimes I am just coasting backwards out of the driveway other times its under heavy acceleration. So far I have not been able to pin point what causes it but the car can sit and idle forever without blowing the fuse, I can even rev it sitting still and not cause it to blow no matter how much or how long I do it.
post #20 of 29 (permalink) Old 08-14-2012, 03:36 AM
Are you still getting a heater code? It could very well be the fuel pump going bad. There's a number of things EFI feeds, mainly the pump and O2 sensor heaters.
post #21 of 29 (permalink) Old 08-14-2012, 07:39 AM Thread Starter
I think when it pops the fuse it resets the ECU, it doesnt immediately throw a code for heater circuit, if I unplug all 4 02 sensors the car will still run right? The fuel pump on the IS is accessible through the inside of the car right? is that the hump behind the ski shoot or is it under the back seat?
post #22 of 29 (permalink) Old 08-14-2012, 08:02 AM
The car will run pretty poor when the car is cold if you disconnect the heater circuit EFI feeds. Heater circuits are only used during open loop to fool the ECU into thinking the car is up to operating temperature. You will obviously throw faults and CEL with no heaters, just an fyi. The fuel pump is underneath the rear seat. Here's a tutorial on how to access it. Make sure the connections are good at pump and at the FP resistor(on driver strut tower).
https://my.is/forums/f221/diy-walbro-...s-alot-409785/
Resistance of the FP(terminals 4 and 5 at pump connector) should read 0.2-3.0 ohms and resistor should read around 0.3-0.35 ohms.
post #23 of 29 (permalink) Old 08-14-2012, 08:22 PM
If your EFI fuse blows randomly, you will have to track the black/red wire. Check it at idle and shake the wiring i guess. When the ignition closes, EFI feeds the heater circuits, four vsv's, and fuel pump. You will have to check to ground. Remember you will read through the coils unless you disconnect all of them. Negative is switched by ECU.
post #24 of 29 (permalink) Old 08-14-2012, 10:45 PM Thread Starter
Solved, it ended up being B1S1 02 sensor, its smashed up against my firewall due to the aftermarket header, it wasnt throwing a code because its wired into B2S1 at the ECU, but still plugged in so it had to run through the fuse, unplugged it and took it for a nice long drive with no blown fuse.
post #25 of 29 (permalink) Old 08-15-2012, 03:13 AM
Good find
I'd be willing it was a black heater wire that was grounding out and the reason why you're throwing a heater malfunction code for that sensor.
post #26 of 29 (permalink) Old 10-16-2012, 05:03 AM
Quoted: 22 Post(s)
Im having this same issue just wanted to know what you did to correct this problem?
'01 SY IS300 NA-T (Under Construction)
McLex01 is offline
post #27 of 29 (permalink) Old 10-16-2012, 05:14 AM
Look at the posts above ya
His sensor return or ground wire was compromised or smashed because he had aftermarket headers and the location of B2S1 allowed the wires to chaff or ground out at the firewall and mess up his bank 2 signal. He says B1S1, but have a feeling he meant B2S1, the one that is mentioned up against the firewall and commonly becomes an issue with some aftermarket headers. Maybe your problem is different.
post #28 of 29 (permalink) Old 05-21-2014, 09:28 AM
same problem ..
I have been having the same problem. I changed the fuel pump, changed the fuse that was blown and the fuel pump relay. Im all out of ideas. Today ill be checking the crank position sensor.
Underground300 is offline
post #29 of 29 (permalink) Old 05-21-2014, 09:33 AM
Have the same problem. Changed the fuel pump, the 25a fuse, the fuel pump relay and still nothing. Only code the CEL gives me is a MAF code which was pretty dirty. Cleaned it and reconnected it. My next option is a crank position sensor. Running out of ideas
Spark Plug wires and spark plugs shynebrite Go Fast Stuff 13 07-19-2007 12:13 PM
TRD Spark Plugs & Spark Plug Leads sherwing2000 Go Fast Stuff 3 12-18-2003 06:54 AM
Has anyone died... hurricane General Discussion 1 01-18-2001 09:16 PM
