A/c only works for 20 min! HELP it’s hot in Florida - Lexus IS Forum
post #1 of 13 (permalink) Old 08-14-2018, 06:06 AM Thread Starter
Hi! New to the forms this is my second is300 and my 4th Lexus
So having problems with the a/c my cars a/c has been working flawless since I had the car. It was broke down for about a month or 2 and sat outside half the time then in the shop at my work the other half.
Now the a/c only wants to work for like 20 minutes when I first start up every now and then. The pressures when I evac and recharge are -> low side : 60-70 high side 145
I know these are no where near where they are suppose to be but it always works for about 20-30 minutes after recharging.
The other day I checked the presssures on a cold start up and the a/c was blowing cold
I put a pic of the pressure readings
Recently put a new used ecu in (why my car was broke down) and brand new condenser and brand new denso compressor not re man and a pressure sensor / switch from Napa
Any help appretiated thanks!
Lukeb is offline
post #2 of 13 (permalink) Old 08-14-2018, 01:23 PM
Quoted: 339 Post(s)
When you recharged it. Did you just add more or did you open the system and let the coolant out. Just looking the low side is high. Depending on if the compressor is running or not.
post #3 of 13 (permalink) Old 08-14-2018, 08:19 PM Thread Starter
Yes I evacuated the system before I recharged it. The picture I added the low side pressure was no where near the 70psi that it was at the other day when I recharged the system
Lukeb is offline
post #4 of 13 (permalink) Old 08-15-2018, 02:43 PM
Quoted: 595 Post(s)
So, is it like, it cools and cools and cools until it gets down to the right temperature, and then starts to cycle and doesn't work anymore? That's what mine did, RIP compressor , still doesn't work
post #5 of 13 (permalink) Old 08-15-2018, 03:09 PM
Quoted: 339 Post(s)
So you vacuumed it down? Or just opened the valve?
post #6 of 13 (permalink) Old 08-15-2018, 03:52 PM Thread Starter
No it’s a brand new compressor and gets cold within a couple min 60-40 Degrees F
Then all of a sudden after about 20-30 min later the compressor stops clicking on I’m going to take a pressure reading when the a/c stops working and post it up.
Lukeb is offline
post #7 of 13 (permalink) Old 08-15-2018, 03:53 PM Thread Starter
No it’s a brand new compressor and gets cold within a couple min 60-40 Degrees F Then all of a sudden after about 20-30 min later the compressor stops clicking on I’m going to take a pressure reading when the a/c stops working and post it up.
Lukeb is offline
post #8 of 13 (permalink) Old 08-15-2018, 03:53 PM Thread Starter
Lukeb is offline
post #9 of 13 (permalink) Old 08-15-2018, 04:31 PM Thread Starter
Readings after a/c stops workin
Lukeb is offline
post #10 of 13 (permalink) Old 08-16-2018, 05:52 AM
Quoted: 339 Post(s)
Sense you did not say you vacuumed it down. That is your problem. You have air in the system.
post #11 of 13 (permalink) Old 08-16-2018, 03:21 PM Thread Starter
No I vaccum it down
Lukeb is offline
post #12 of 13 (permalink) Old 08-16-2018, 07:18 PM
Quoted: 339 Post(s)
No I vaccum it down
Okay, Then I would lower the levels a bit and see if that changes the working time. If it still persists with no change. I would check the controller next.
post #13 of 13 (permalink) Old 08-16-2018, 07:53 PM Thread Starter
No I vaccum it down
Okay thanks I’ll be trying that tomrorow after work
Lukeb is offline
A/C Issues - Blowing Hot Air bigkahuna2187 General Discussion 8 08-20-2017 06:53 PM
A/C Issues - Blowing Hot Air bigkahuna2187 Basic Help & Repair 1 08-13-2017 01:35 PM
A/C Works, but No Heat hidinginthelight General Discussion 0 02-13-2016 01:23 PM
