AC or Heat only after radio install - Lexus IS Forum
post #1 of 4 (permalink) Old 04-02-2014, 09:34 AM Thread Starter
Hi,
After radio install, at about 65degrees, AC switches to heat. Worked flawless before this; I know there are only 2 connections on the AC/Heater module (as I have done a dash replacement myself). In my last IS300 they by passed the cars amp as I had speakers replaced at the same time. On this IS the speakers are fine so they hooked the radio into the cars amp. Could this be caused some type of problem in the electrical system?
Installer willing to work with me, but not sure what the problem is...
thanks
tsp0596 is offline
post #2 of 4 (permalink) Old 04-04-2014, 01:52 AM
Is your ac set on auto?? Recheck all your connections
Thekanaka is offline
post #3 of 4 (permalink) Old 04-05-2014, 07:09 PM
It sounds like the interior temp sensor, on the left lower part of the dash is either unplugged, or the wires were compromised during the install. It's located pretty much right under the ignition, on the lower dash panel. Two wires plug into it, and a tube that runs back towards the rear of the heater/evaporator box. An open circuit there makes the car think it is -400 degrees inside, so any temp above max cold will cause it to start blowing hot air.
cline100 is offline
post #4 of 4 (permalink) Old 04-06-2014, 09:51 AM Thread Starter
Hi....all fixed; yes both the air tube and the sensor had not been reconnected. I just sent a feedback note to the Audio shop so they can improve their quality control. Turned the car back on with the HVAC on auto direct/auto temp (which I always use) and life is back to normal...Thanks
tsp0596 is offline
Radio install... Motorsports_3 Mobiletronics 24 04-02-2007 04:09 PM
PLP Heat Shield Install w/ Photos scottc25 Go Fast Stuff 7 02-25-2004 08:18 AM
PLP heat shield install HELP!! Rav4skyracer General Discussion 5 07-24-2003 08:34 PM
PLP heat shield install... AC556k Go Fast Stuff 4 06-17-2003 05:06 PM
Please help with PLP heat shield install on my bro's 2002 IS s4play General Discussion 2 05-15-2002 06:41 PM
