4 codes for throttle sensor. BTC if you can solve it - Lexus IS Forum
post #1 of 11 (permalink) Old 01-23-2018, 11:29 PM Thread Starter
My 05 auto is300 was running perfect. Valve cover gaskets were leaking on gte, so I replaced them. After re-assembling rpm idles around 2100-2300 with 4 cel codes. Throttle responds perfectly raising rpm from 2100, then once released it goes back to 2100.
1. Put in new spark plugs with the same iridium ones that were in there. (So shouldn’t make a difference)
2. Throttle body had really bad deposits, so I used a toothbrush and simple green to get rid of it all. After I removed all the black deposits, there was some space between the side walls and metal valve when it was fully closed. (Metal circle valve must have eroded away on the top and bottom edge after 230k miles?)
3. Sprayed engine bay down with simple green and hosed off everything while throttle body was fully removed (just plugged hole in the Y-pipe.). Maybe water got into one of the three throttle body connectors and shorted it?
4, Three codes were P2138 P2134 P0122 P0222
Danfom is offline
post #2 of 11 (permalink) Old 01-24-2018, 05:59 AM
Quoted: 339 Post(s)
Both TPS and TLP sensors are bad.
post #3 of 11 (permalink) Old 01-24-2018, 07:07 AM Thread Starter
What exactly is the TLP? Are you referring to the throttle body lever sensor which attaches to the throttle cable? I’ll try those out first this this morning.
ALSO I have a voltage meter along with a decent obd2 scanner w/live readings if that helps
Danfom is offline
post #4 of 11 (permalink) Old 01-24-2018, 02:37 PM
Quoted: 339 Post(s)
Yes The throttle lever position is the one with a cable attached. The Throttle position is the other one.
post #5 of 11 (permalink) Old 01-24-2018, 08:46 PM Thread Starter
Just an update. Put in a new TPS sensor in and the four codes went away. Another code popped up, so I have a new Throttle Body Lever sensor coming in on Saturday. Dealer wanted $430, amazon $143.
Danfom is offline
post #6 of 11 (permalink) Old 01-27-2018, 08:12 PM Thread Starter
Replaced both sensors. When I press the gas, it falls to floor with little to no response. Here’s my live Idle readings
Danfom is offline
post #7 of 11 (permalink) Old 01-28-2018, 05:34 AM
Quoted: 339 Post(s)
Sounds like something is not right. If there is no resistance. I would recheck the lever position sensor install.
post #8 of 11 (permalink) Old 01-28-2018, 08:34 AM
Quoted: 66 Post(s)
just FYI it's supposed to be like 3 degrees open or something.. You can find the details somewhere in the FSM. That's normal
lessthanjakejohn is offline
post #9 of 11 (permalink) Old 01-28-2018, 07:35 PM Thread Starter
UPDATE! The only problem all along was just the tps sensor.
-It was initially damaged (probably water shorted it when I pressure washed the engine bay)
-then when I installed the new tps from Autozone it was jacked up as well. Figured that out after testing the resistance. So I exchanged it and calibrated it to 14% via live Obd II readings. Runs perfect again. Gonna return the $143 throttle lever sensor.
Danfom is offline
post #10 of 11 (permalink) Old 01-29-2018, 11:58 AM
Quoted: 233 Post(s)
im glad you fixed your issue, but be careful when spraying the bay with a pressure washer. I have heard stories about used car dealers spraying cars' bays with a pressure washer then running into issues because some of the sensors under the hood went bad (presumably due to pressure washing). atleast the bay was clean so someone could work on it. LOL
Lucy; 04 manual sportdesign
mesooohoppy is offline
post #11 of 11 (permalink) Old 01-29-2018, 12:22 PM Thread Starter
I worked detail at an Audi dealership in 2012 and we pressure washed every single engine bay that ever came through. New or used ????. Now I know
Danfom is offline
A/C Codes My3EZ General Discussion 5 11-22-2017 05:01 PM
First post... Changed hub bearing and now getting ABS codes BeigeLexIS Basic Help & Repair 4 05-12-2016 02:14 PM
Engine throwing codes - Help... rijn_in General Discussion 1 04-14-2016 07:12 PM
error codes no sh*t DarK StaR Basic Help & Repair 8 12-13-2015 05:11 AM
Help solving these codes please arunanlogen General Discussion 2 12-12-2015 08:08 PM
