'06 IS350 motor mounts (video) - Lexus IS Forum
post #1 of 4 (permalink) Old 11-20-2018, 07:25 PM Thread Starter
I've started having occasional hard shifts, and there is some vibration when cruising down the highway. Not a lot of vibration, just enough to sometimes rattle the coffee cup a little in the center console.
So I'm wondering about the motor mounts and transmission mount.
Here's a video of powerbraking it in drive, reving to about 2,000 RPMs. The engine moves a little more than I would have expected, but I don't know if this is an abnormal amount.
Any experts care to comment?
Its a 2006 IS350, 144,000 miles.
ksJoe is offline
post #2 of 4 (permalink) Old 12-04-2018, 09:04 AM
Quoted: 34 Post(s)
if you suspect the mounts - take a peak at them and see if the rubber is rotted/torn. at 144k miles its not unheard of for the mounts to be shot.
chunktwo is offline
post #3 of 4 (permalink) Old 01-03-2019, 05:08 PM Thread Starter
I ended up not replacing the two front engine mounts.
Crawling under it, I was surprised how much I could shake the rear of the transmission and the driveshaft at the center support bearing. The rubber in the both the transmission mount and the center bearing looked great though.
So I replaced the transmission mount and center support bearing. Even after removing them, the rubber looked great.
Since replacing them, the coffee cup has not rattled at all. I haven't noticed a hard shift either, but that one was very intermittent anyway.
So just an FYI - even if the rubber looks great, if you can shake the transmission and drive shaft, replacement will help.
BTW, from what I've read, there are a lot of warnings about the low budget engine/transmission/carrier bearings. They're either too hard and transmit vibration, or they're too soft and break quickly. So I went with OEM transmission mount (around $45 online), and I got an SKF drive shaft bearing from RockAuto.
ksJoe is offline
post #4 of 4 (permalink) Old 01-19-2019, 07:11 PM
Did you do this by yourself If so do you have a video on how to?
250is is offline
Lexus IS Fog Light LED Bulbs! Install Video! Luxeon LED Replacement Housings! New SLF Diode Dynamics Diode Dynamics 12 06-21-2018 04:28 PM
strange occasional noise in IS350 after cold starts HEAP General Discussion 3 04-29-2016 08:35 AM
