02 is300, driveshaft options?? - Lexus IS Forum
post #1 of 6 (permalink) Old 11-15-2018, 06:17 PM Thread Starter
I've recently had a vibration around 50mph, and 65+mph. Also finally determined this to be my u joints beginning to fail, as the front u joint has a rough spot in both directions, and the rear has a very rough spot, although no play in them yet. They are not serviceable u joints (thanks Toyota) so it seems replacing the whole driveshaft is my only option at this point.
If anyone else has been through this, who/what shaft did you order? I found this one piece for sale and seems like an ok deal, but pictures do not show a slip joint. Although it's most likely just a stock photo I want to be sure before placing the order.
https://frsport.com/driveshaft-shop-...us-is300-98-05
Other suggestions are welcome. Also not opposed to having one made, I feel that would be more expensive however.
The car is a stock drivetrain 2002, factory transmission and rear, manual yransmission.
Thanks.
Timothy_juniorr is offline
post #2 of 6 (permalink) Old 11-16-2018, 09:09 AM
Quoted: 229 Post(s)
it looks like its a stock photo. go here:
The Driveshaft Shop | IS300 - Toyota - Import Driveshafts
unless you can find a good deal on a used one, i believe this is your only other option.
Lucy; 04 manual sportdesign
mesooohoppy is offline
post #3 of 6 (permalink) Old 11-16-2018, 01:32 PM Thread Starter
That's the same part number, so I'm going to assume it's the same part. Seems like it's just a different supplier. Will most likely wind up going this route when Christmas is done and over with.
post #4 of 6 (permalink) Old 11-16-2018, 02:41 PM
Quoted: 229 Post(s)
They are both made by DSS. The link i provided is buying directly from DSS. FR Sport in this case is just acting as a middle man. i would go with the pic on DSS' website as the more accurate one. if you want to confirm, id call them.
post #5 of 6 (permalink) Old 11-17-2018, 06:26 AM
Quoted: 338 Post(s)
Thanks.
Just go to a local driveshaft shop. Easy to make a one piece shaft.
post #6 of 6 (permalink) Old 11-21-2018, 03:19 PM
Quoted: 141 Post(s)
Just make sure that they build it with rebuildable and greaseable GM u-joints. This makes it way easier to service, or to replace a u-joint in the future.
Piggity is offline
LS400 BBK Caliper Adapter Options for IS300 Brake Upgrade gita Stop, Drop and Roll 24 11-28-2018 06:14 PM
IS300 auto driveshaft options? Funistobewith General Discussion 5 10-15-2018 01:32 PM
what size diameter should the custom driveshaft be to fit is300? huntsman General Discussion 29 10-14-2018 08:35 AM
IS300 AR5 Driveshaft Solution.. boostdreams Go Faster 16 08-16-2018 09:18 AM
IS300: A650e > R154 Swap > Driveshaft options GeeEss General Discussion 2 02-22-2018 10:51 AM
