01 is300 wont start... nothing but clicking sounds.. help my only car... - Lexus IS Forum
post #1 of 12 (permalink) Old 11-23-2007, 12:23 AM Thread Starter
my car wont start ... every time i turn the key it has a loud clicking sound... not just one click but a few... could this be my starter? car has 95k miles on it if that helps... any help would be great... this is my only car and need to fix this asap... thank you
TRD IS300 TRD is offline
post #2 of 12 (permalink) Old 11-23-2007, 01:44 AM
sounds like a dead battery to me. It makes a 'tat tat tat' sound?
'04 GGP
tamIS is offline
post #3 of 12 (permalink) Old 11-23-2007, 08:04 AM
Yup, as TamIS said.... put a new battery in it. You'll be fine.
Brian
2006 BMW 330i - 6spd, Sport
2001 Lexus IS300 - Auburn Sky Pearl (233k miles)
Brian_TII is offline
post #4 of 12 (permalink) Old 11-23-2007, 03:17 PM Thread Starter
i tried jumper cables.... no work... but ill be on my way to get a new batt... maybe a yellow top...
post #5 of 12 (permalink) Old 11-24-2007, 08:09 PM
Jumper cables don't always get a good enough connection to jump it off. Let us know how the new battery does for ya.
Brian
post #6 of 12 (permalink) Old 11-24-2007, 11:49 PM
get a jumper pack. In my mind i think you connected the jumper cables wrong.
01 GGP SSR SP1's 18x8F 18x8.5R
looney is offline
post #7 of 12 (permalink) Old 11-27-2007, 12:42 PM
Under House Arrest
ditto. thats usually the sound of a bad battery, occasionally a miscommunication between the grounding and/or power to the starter.. but most likely your battery.
let us know how a new battery works out for you.
URSMOKD is offline
post #8 of 12 (permalink) Old 11-28-2007, 12:02 PM
From time to time I get this on my '01 as well, a click when the key is turned but no crank. Then it starts fine a minute later, its not the battery in my case.
If you find the problem and its not the battery post the info, I'll be curious to know.
mrmonster is offline
post #9 of 12 (permalink) Old 11-28-2007, 01:22 PM
Under House Arrest
like i said.. could be a possible connection. trying cleaning your cables and posts? maybe check underneath to check the starter connections.
URSMOKD is offline
post #10 of 12 (permalink) Old 11-28-2007, 02:02 PM
yours sounds like either a bad/corroded cable or the switch side of the ignition has worn the contacts out. does it do it when you put the key in a certain position? as in it wont start with the first part of the spring pressure but it will if you turn it to the stop or wiggle the key?
the the OP check your battery cables for corrosion, not just on the terminal ends but in the wires themselves. the solenoid could be going bad in the starter, but the rapid clicking is usually a voltage problem
Originally Posted by Mazdaspeed View Post
unsuccessful troll is unsuccessful.
richter is offline
post #11 of 12 (permalink) Old 05-19-2014, 11:04 PM
Quoted: 10 Post(s)
Hey my is300 is making that clicking noise from the starter but nothing is starting. My car was in my garage for about 2-3 weeks with almost an empty tank of gas. Sometimes would start it up for 30 seconds and turn it off.
Last night I may have left the trunk open....like it's closed enough u can't tell it' open....but not the official clicking/locking noise....I was also working later the next day with the trunk open maybe for an hour thinking the battery would still be good...anyways...the car wont start now.
What are the chances it's just the battery? What's the chances are it's a bad fuel pump? I've put a few litres of gas inside thinking it was the problem at first.....is it okay if I mixed possibly a little unknown gasoline(most likely regular 81) with 91? I'm pretty sure this little can't do any harm.
All the electronics do seem fine atm......how do I check the battery voltage with the volt meter?
jwis300 is offline
post #12 of 12 (permalink) Old 05-20-2014, 01:45 PM
It is most likely your battery. You haven't driven it in 2-3 weeks and you also left your trunk was left open. Your lights probably drain more battery than you would think. I doubt it was your fuel problem since you were not driving it. Being idol does not take up much fuel. Turning on for 30 seconds wouldn't really charge much of your battery. You would need to let it idle for at least 1 hour. Driving it is when your battery gets the real charging done.
XxESKIMOxX is offline
Car won't start, just clicking. Any idea? buister Basic Help & Repair 7 03-23-2007 07:55 PM
Need Help.......car Wont Start fuzzyoner General Discussion 1 03-11-2007 11:43 AM
Car wont start! aemjr Basic Help & Repair 10 09-21-2006 06:57 AM
Help Car Wont Start 03sport Showroom 13 11-04-2005 08:05 PM
Help, car wont start. Spooner General Discussion 2 06-06-2004 02:58 PM
