R154 ? THE Ultimate Auto to Manual Swap Info Thread - Page 6 - Lexus IS Forum
post #76 of 275 (permalink) Old 03-09-2009, 09:46 AM
Nice Faq +rep
02 5 Speed Cibola Gold Altezza :)
Greddy Cat, Cross Drilled Rotors, KYB Shocks, Swift Springs, W58
PIRULODR22 is offline
post #77 of 275 (permalink) Old 03-10-2009, 03:34 PM
I see that you chose 1 piece aluminum driveshaft. What is the reason go with 1 piece custom driveshaft? Can I just extend and get balanced the original IS one? Or it will be to weak for turbo IS with r154 tranny? Do you know how many inches I need to extend the OEM one? You said that 1 piece is more responsive, Is it really that difference between 1 piece and stock 2 piece one?
crazystuntrider is offline
post #78 of 275 (permalink) Old 04-07-2009, 09:25 PM
I just got my ride back with the R154. Just like others have mentioned, its LOUD as hell!! I can barely hear my engine/new tubular manifold/boost. I'm sure the loudness is compounded since some of center console area was cut out and there is no sound barrier. I need to put some sort of noise barrier/sound dampening stuff very soon.
The gearing is pretty smooth but loud. The HKS gdmax twin plate feels great. chattering noise when clutch is disengaged is annoying but i try to avoid it when i can. Also, my speedo doesn't work but i read in another thread about the wiring to make it work. Hopefully its not that diffucult.
I just can't wait to really push it once its broken in and then see what i've been missing...
02 MSM/gte/ Garrett GTX3076R
MikeNice is offline
post #79 of 275 (permalink) Old 04-12-2009, 12:24 PM
hi guys nice write ups pros for both you guys. My Q&A is this I have a 01 auto with the aristo swap, aem ecu and single turbo setup that's pushing over 500rwd do I need to take it to get it tune over or can I do this swap and just drive everyday
luv2drift is offline
post #80 of 275 (permalink) Old 04-13-2009, 12:45 PM
I would have to say no, but maybe someone here can give you a definative answer.
2001 Lexus IS300- R154 w/LSD-2JZGTE VVTI-GT3788R (In the works!)
2012 Lexus CT200H F Sport
DC5ROY is offline
post #81 of 275 (permalink) Old 04-30-2009, 01:40 AM
Hey Leon! I found this thread at the perfect time. Its been almost year on the auto with the turbo and my 3rd gear just went out. It slips like crazy and it just happened all of a sudden with no warning. Now the question is do I repair it with upgraded parts or do I go with the swap? Decisions, decisions.
-Eric
"Dammit, where are my driving mocassins?!"
SOLD: '01 SY SRT 2.75
mixtnutz532 is offline
post #82 of 275 (permalink) Old 04-30-2009, 07:12 AM
That's a great write up and a clean setup. You make it seem so easy.
Fred.Smilek is offline
post #83 of 275 (permalink) Old 05-09-2009, 02:24 AM
Is there a removal/installation thread you guys used as a reference? I am pulling out my auto to ship of to PFS for a race build (cant afford the manual right now). I've never pulled a tranny and I'm using the lexus maintenance manual which is pretty vague.
Also, did you have to unbolt any of your exhaust LO? The manual says to actually remove the exhaust manifold but that is a little more difficult now with the turbo on there.
One more question, can the tranny be pulled on just jack stands or should I put it on a lift? I have both readily available but using the jack stands saves me money.
-Eric
post #84 of 275 (permalink) Old 05-09-2009, 12:43 PM
Bump, anybody? Doing this today.
-Eric
post #85 of 275 (permalink) Old 05-12-2009, 05:53 PM
Looks like I'm going r154. Thanks homie.
02 MSM 5 Speed IS300
Miami, FL
trdperformance300 is offline
post #86 of 275 (permalink) Old 05-12-2009, 10:33 PM
You pulled the tranny yet? If not hit me up. Txt me if you want for questions.
402-212-0923 (please keep in mind don't call me after 11pm midwest time zone)
The swap is very very very easy. If you have a lift use it. If you have access to a tranny jack, use that too. You will get your old tranny off in 30minutes easy.
What are you swapping back onto your Lex?
I pulled off my stock 5spd and put on a 6spd V160. Me and my friend had it done in literally 2hrs.
Well either txt me or PM me if you need any help. I could probably walk you though it.
Chris
o3' Graphite Grey Turbo IS300 w/ 6spd swap, ProEFi128, T6765 Billet, stock head
Going to throw a Supra tranny (V160) into your IS? Got questions? Feel free to ask me.
* * *TX2K9 & TX2K10* * *
KR4P11 is offline
post #87 of 275 (permalink) Old 05-13-2009, 07:21 AM
Ok guy's lets please stay on topic.
DC5ROY is offline
post #88 of 275 (permalink) Old 05-13-2009, 11:31 AM
so can some one please answer this because theres so many answers out there but for a r154 tranny and sc shifter
doed the shifter have to be extended, cut mid from the bushing and ball and rewelded or just leave everything as is ????
kingsrquan is offline
post #89 of 275 (permalink) Old 05-13-2009, 11:55 AM
I have the R154 and 92 SC300 shifter combo. The shifter does not need to be modified at all. It will line up right in the center. You do need to cut a piece of the tranny tunnel in order to bolt the shifter up.
Hope that helps.
DC5ROY is offline
post #90 of 275 (permalink) Old 05-13-2009, 12:50 PM
Just to clear my mind, how long should it normally take if a professional shop did this?
*01 Is300//1jz-gte//*
jesus954 is offline
Current users viewing this Thread: 6 (0 members and 6 guests)
need help with auto to manual swap mastro007 Go Fast Stuff 1 09-22-2008 12:50 AM
swap a manual SW for an auto SW..? MSM MT IS300 General Discussion 2 10-21-2003 06:23 PM
for the peeps who did a manual swap (r154, v160 etc...) tyson745 General Discussion 1 09-22-2003 08:05 AM
