Passing Emissions Turboed - Lexus IS Forum
post #1 of 8 (permalink) Old 02-07-2016, 09:34 PM Thread Starter
Quoted: 47 Post(s)
As some of you may have already read I have embarked on a Sportcross turbo project and plan to do it 100% cel free to pass Illinois OBD2 emissions.
Here is the list of item I will be using.
XS Power New 2016 Turbo kit
Emanage Ultimate
440CC Denso injectors (From 02-05 WRX) These are 100% plug and play you just have to remove the 3 plastic spacers on the injector rail
255 Fuel Pump
Obviously the tune will have a major role in achieving that and once its perfect I will share it for everyone to use.
The trick here is to keep things as much stock as possible mechanical wise though and Im going to start with the o2 sensor placement. Now the general practice is to place B1S1 in the first spot on the down-pipe and splice it with B2S1. I have read mixed things about this and would rather give OEM placement a go before I have to go to that. Once B1S1 and B2S1 are in the manifold i will place B1S2 in the second spot on the down-pipe with o2 fouler and B2S2 in the mid-pipe with o2 fouler as well. This should work considering everyone does it with headers and works perfect. Since both banks read a bit different and the ECU looks for this it will be better in the manifold
Below are my ideas for the o2 sensor placement. Since so many of us started with headers im gonna try to keep the same idea with the tubular manifold. Also back in 2009 I was using a turbonetics kit with the log manifold which the o2 sensor were on the top, never had a single cel so I know this can work.I have mocked up how the kit will go into the car on my engine stand while my engine is at the machine shop getting the GTE treatment. This gives me a 98% idea how the down pipe and turbo will be clocked.
Option 1:
Option 2:
Now please be patient with me through this as it will more than likely be at lease a month and a half before I get to putting it in the car due to my engine builder being so jammed with work. But I promise I will make this happen and will share every detail. I just know alot are asking about the XS Power kit so I figure this would help others.
lexusboy718 is offline
post #2 of 8 (permalink) Old 02-09-2016, 06:05 PM
Quoted: 16 Post(s)
I just passed emissions test with a single turbo GTE swap.
Stock is300 Ecu
jdm 440cc gte injectors
primary O2's spliced together about 16" from turbo
token solutions O2 sim
MAF ~stock distance from Throttle body
Used this to scale the MAF signal to prevent Bank 1 & 2 Rich Codes.
I still have the OEM fuel pump running full voltage from battery via a relay.
External AEM FPR running at a static ~32psi. (just for emissions....)
Only an OBD2 readiness test here. Can only have one monitor no ready, my evap wasn't ready, must be too cold.
02 1C0 5spd
Megomaniac is offline
post #3 of 8 (permalink) Old 02-09-2016, 06:45 PM Thread Starter
Quoted: 47 Post(s)
DAMN!!!!!
I was told id never pass with a swap! Oh well already in to deep turbo kit it shall be
Good info!
02 Sportcross, 08 ISF
My Sportcross Build : https://my.is/forums/f219/sportcross-...e-more-567122/
post #4 of 8 (permalink) Old 02-09-2016, 07:57 PM
Quoted: 136 Post(s)
Passing an OBD only emissions test is rather easy.
I know here in Maryland they could sniff if they suspect OBD doesn't suffice but that's up to the inspectors and with every compliant vehicle going through every 2 years they don't care.
So I guess you could say it depends on where you live but in general; no lights no problem.
cleansleeper is offline
post #5 of 8 (permalink) Old 02-18-2016, 01:28 PM
Quoted: 10 Post(s)
Don't they do visual inspection too when smog in CA? How are they not going see that turbo... or am I wrong and they don't do inspection anymore
Redline SER is offline
post #6 of 8 (permalink) Old 02-18-2016, 01:58 PM
Quoted: 16 Post(s)
Depends where you live. They didn't even open my hood.
Just plugged in the obd2 thing.
02 1C0 5spd
post #7 of 8 (permalink) Old 02-22-2016, 02:22 PM
Quoted: 42 Post(s)
Yes, and the guys in here are from other states.
<--- Doesn't believe in stock vehicles
2002 IS300 VVTi GTE v161 Built single - TeCKis300's old car
1995 240sx - NASA PTD trim
Hardrvin is offline
post #8 of 8 (permalink) Old 04-18-2017, 07:34 PM
Quoted: 195 Post(s)
This looks cool. Ill be watching for sure!
Edit: Wait did this project get abandoned??
VEHEMENCE is offline
