New to Forced Induction? All answers inside! - Page 7 - Lexus IS Forum
post #91 of 115 (permalink) Old 03-03-2012, 02:45 PM
Quoted: 47 Post(s)
What do you think of this turbo kit?
My buddy found this on ebay and is thinking of buying it. Any Input?
Custom IS300 Turbo kit (Garrett gt35r) | eBay
02 Sportcross, 08 ISF
My Sportcross Build : https://my.is/forums/f219/sportcross-...e-more-567122/
lexusboy718 is offline
post #92 of 115 (permalink) Old 03-03-2012, 10:29 PM
that looks like a pretty sweet deal
aww-shiet is offline
post #93 of 115 (permalink) Old 03-04-2012, 07:14 AM
Quoted: 47 Post(s)
for the price i think its worth it
post #94 of 115 (permalink) Old 03-27-2012, 11:09 PM
so i got that garrett turbo and took it apart. heres more specs on it.
Garrett turbo or supposedly garrett.
.50 compressor a/r
.84 turbine a/r
3" inlet 2" out
t4 divided flange
compressor inducer mm - 42
compressor exducer mm - 60
turbine inducer mm - 53
turbine exducer mm - 63
to me looks like a 400hp max turbo. might need some upgrades.
post #95 of 115 (permalink) Old 05-03-2012, 12:27 PM
Supercharger Vs Turbo what are the Pro's & Con's of both???
Can you put GTE parts on ur car if ur not turbo'd or sc'd yet??
LucciLou is offline
post #96 of 115 (permalink) Old 05-03-2012, 01:08 PM
Quoted: 9 Post(s)
You can but it won't benefit performance at all. You can install the GTE headgasket , rods and pistons and it will be ready for turbo.
01' IS300 2JZ-GTE Aristo Stock Twins (for now)~ Current
01' MSM IS300 NA-T [email protected]~ Sold
joney3jonez is offline
post #97 of 115 (permalink) Old 05-03-2012, 09:27 PM
Supercharger - instant spool, to change psi you have to change a pulley, for the price not worth it because your limited to hp. You will probably never see over 450hp
Turbo - some lag depending on size of exhaust housing. You could make so much hp and set it what psi you want it that day just by turning up a knob. More reliable less maintenance
Yes you can but your going to loose power. I think the vvti non-turbo engine has 10.1 cr while the gte has like 8.8 or 9.0 somewhere around there.
post #98 of 115 (permalink) Old 10-09-2012, 05:02 PM
Lexus11is's Avatar
I'm wondering if these infos can be.emailed
Is250 AWD "Auto" Stock
Is300 RWD "Manual" Going under major surgery
Lexus11is is offline
post #99 of 115 (permalink) Old 10-09-2012, 05:04 PM
Why do you need it emailed?
Sent from my iPhone using AG Free
Jerm__ is offline
post #100 of 115 (permalink) Old 10-09-2012, 05:23 PM
Lexus11is's Avatar
So I can use it to memorize these... I'm on my phone often and the internet is too slow... If I had a print out you know?
post #101 of 115 (permalink) Old 10-09-2012, 05:25 PM
Lexus11is's Avatar
If its a hassle is fine... I use Mac and its hard to print stuff out.... Just recently switched so clueless loll
post #102 of 115 (permalink) Old 10-09-2012, 05:34 PM
You could just print it when you get to your computer. Send yourself the web pages and then print them
Jerm__ is offline
post #103 of 115 (permalink) Old 10-09-2012, 05:58 PM
Lexus11is's Avatar
Works same way with Mac?..
post #104 of 115 (permalink) Old 10-09-2012, 06:28 PM
I would assume you can print web pages from a MAC...
Jerm__ is offline
post #105 of 115 (permalink) Old 10-26-2013, 10:52 PM
I have had my IS for a little over a year now and I have been itching for boost since I started looking for one. I've been reading a lot but I know I need to do much much more research on going f/i. The biggest thing I can make out of all of these threads is that this is going to take $$$$$$$$.
I am still in the learning process, but I just wanted some feedback as to what path I'm currently considering for the future. (I figured I should start researching more now so that when I come into the money I'll have a better idea of what to do with it.
I have a 03 e-shift with 133k miles and probably won't be starting this project till much further down the road so the mileage will be higher. I am planning on piecing together a kit on my own to reach a goal of around 300whp until I get comfortable w/ the power and get a better understanding of boost.
My rough plans are:
Transmission: Upgraded valve body, sprag gears, and cooling (Upgraded torque converter?).
Engine:
Compression & leakdown testing to get an idea of what shape my current engine is in
GTE pistons, rods & head gasket
I need to do a ton more research on turbos, ems & tuning. I bought a couple of books, "How to Tune and Modify Engine Management Systems" as well as "Maximum Boost" although I have yet to read them all the way through.
Once I get used to the setup and comfortable with working with boost. I will most likely go for around 400whp maybe 500. At this point I will consider a 6spd.
ANY feedback would be extremely appreciated. Am I going about this all wrong?
Sorry for the long thread I tried to include everything I could think of atm.
I know I need to do more research I just want a push in the right direction.
STILL looking for a 5-speed...
2jzTaters96 is offline
Forced Induction??? Messenga IS350 Owner's Forum 12 09-28-2006 07:55 AM
Best way to forced induction pgb777 Go Faster 5 07-02-2004 12:03 PM
Forced Induction...which to go with ISsard22CU Go Fast Stuff 89 01-11-2002 11:43 AM
Forced Induction Anyone???? BigJoeD General Discussion 0 05-22-2001 06:26 PM
