Need help setting up IACV in Aem 30-6050 - Lexus IS Forum
post #1 of 3 (permalink) Old 04-12-2019, 04:22 PM Thread Starter
Quoted: 11 Post(s)
I have been confused about how to set up the wiring and configure everything within the aem software.
I have a 2 wire ford IACV that I am trying to connect.
From the info I found on this site was saying to pin out b23 PW1 on the ECU and it needed 12v switch power.
Can I use the 12v switch off the Ecu for this too? I pinned out b25 for the 12v switched.
Is the PW1 sending signal or grounding?
So I have two wires running from the ecu at b23 and b25 currently
How do you enable these functions?
I feel like this should be very simple but I am new to this also so any advice would be appreciated
ShiftnGears is offline
post #2 of 3 (permalink) Old 04-12-2019, 04:50 PM
Quoted: 139 Post(s)
The iacv needs a switched 12v like you said, and the ground is typically the pwm wire. You will need to set the frequency and duty cycle. I don’t know what the current draw is on the iacv, so I can’t say if if you can use the same switched 12v wire the V2 is on.
https://www.powerhouseracing.com/pro...it-for-2jz-gte
https://www.aemelectronics.com/forum...-30-6101-supra
https://www.supraforums.com/forum/sh...1060345?page=2
You should be able to sort it out with those links. Note that they aren’t the exact AEM you have and the cars are supras but everything should be similar enough to make it work. You’ve got this far, right?
Kris OK is online now
post #3 of 3 (permalink) Old 04-14-2019, 11:15 AM Thread Starter
Quoted: 11 Post(s)
thanks! that last link was very helpful
I am going to have to give it another whirl.
aem v1 questions. Silver_is300t Go Faster 2 01-29-2019 05:48 PM
AEM Series 2 - boost solenoid help ShiftnGears General Discussion 0 02-16-2018 08:15 AM
Dezod AEM V2 paired with 2jzgte volcomcy Go Faster 11 08-24-2017 09:10 AM
Dezod AEM V2 to AEM Infinity 6 Conversion for IS300 02-05/ Base Cal Included joelpr1234 Go Faster 30 06-24-2016 11:23 PM
