Link g4 + PNP! - Page 2 - Lexus IS Forum
 5Likes
post #16 of 34 (permalink) Old 03-17-2019, 09:37 PM
Updates on this!??...
Jcjdm4life is offline
post #17 of 34 (permalink) Old 05-19-2019, 06:20 PM
For automatic control? Not from most ECU manufacturers. You will need to look at getting a manual valve body and shift it manual or look at getting a TCU like a Spitronics, PCS, Compushift etc to control the auto.
Personally I'm using the Spitronics Mercury 2 TCU to control the A343e but it also supports the A650e if you want to keep swapping gearboxes.
Sent from my Pixel 2 XL using Tapatalk
wastegate is offline
post #18 of 34 (permalink) Old 05-20-2019, 01:39 AM
Quoted: 32 Post(s)
are you running the OEM ECU or did you pin the Spitronics to the link ECU?
do you have any info about Dicktator TCU? are they standalone TCUs?
Arzon is offline
post #19 of 34 (permalink) Old 05-20-2019, 01:41 AM
Hi, OEM ecu is in the bin. Link controls the engine and BEAN network including gauge cluster, climate control. The Spitronics TCU is only controlling the auto.
Arzon likes this.
post #20 of 34 (permalink) Old 06-03-2019, 08:24 PM
Here's a quick video I made to shed some light into this!
Also, one thing to mention is that this ECU will NOT control the Auto Trans.
On their site, there is a listing for an 02-05 Auto IS300. That is for those cars that originally came equipped with the AT.
Anyhow, this ECU is the real deal. No more double ECUs, no more piggy backs, and YES to AC!
Knshro is offline
post #21 of 34 (permalink) Old 06-05-2019, 10:52 AM
Can i pass inspection with this? I really dont want to have to bribe an inspector for the next 10 years.
Spoonanator is offline
post #22 of 34 (permalink) Old 06-05-2019, 10:53 AM
Quoted: 79 Post(s)
Not if he hooks up a scan tool to your OBD2 port.
Hodgdon Extreme is offline
post #23 of 34 (permalink) Old 06-05-2019, 01:10 PM
Damn, thats exactly what they would do to me.
post #24 of 34 (permalink) Old 06-10-2019, 05:18 PM
This ECU kit is not meant to pass emissions tests and does not have emissions rediness protocalls.. From website
https://xcessivemanufacturing.com/to...e10-ecu-s.html
"I know that SOB is cheatin! Cause, I'm cheatin and he beat me"!
blackmenace is offline
post #25 of 34 (permalink) Old 06-10-2019, 05:25 PM
Quoted: 355 Post(s)
No standalone does that I am aware of.
Careful & Consistent
post #26 of 34 (permalink) Old 07-03-2019, 02:11 PM
Quoted: 63 Post(s)
I'm bringing my car to Xcessive this weekend and they are going to install and tune my car with the Link G4 unit with Panic Wire. I'll let you guys know how it works. The platform they are working with is a GTE swap Is300 with full 3inch straight pipe exhaust and an intake. Everything else is basically stock wired to the Aristo ECU.
Hodgdon Extreme likes this.
Wanna go faster? Press the gas pedal harder!
DemonIs300 is offline
post #27 of 34 (permalink) Old 07-03-2019, 02:24 PM
Quoted: 79 Post(s)
Cool and good luck!
Inquire about how the Link Thunder ecu system is coming along, too!
post #28 of 34 (permalink) Old 07-03-2019, 05:00 PM
Quoted: 22 Post(s)
Originally Posted by blkaltezza View Post
We're using this setup on my friend's 1jz swapped drift car and it works great. Alot of nice features and very stealth. It comes in the stock ecu casing and fits into the stock ecu box. Has a built in MAP sensor and completely eliminates the stock ecu.
It also works with the stock muliplex system so a/c, fan relays and gauges all work. You can even program each indicator light on your cluster to do whatever you want. For example you can turn your CEL into a shift light if you wanted to.
Great standalone for the price, and has alot of nice features. Only downside is that it only works for manual transmission, so if you have a auto transmission you're out of luck. I'd say this is probably the best standalone for the IS300 just because you can completely eliminate the stock ecu.
care to share some details? I'm thinking the upgraded turbo from driftmotion and this ECU will make for a pretty easy 400hp setup
Originally Posted by Hodgdon Extreme View Post
Cool and good luck!
Is that another ECU product in the works?
GGM_IS is offline
post #29 of 34 (permalink) Old 07-04-2019, 12:42 PM
Quoted: 79 Post(s)
The setup offered by Xcessive/Panic Wire is based on the Link G4+ "Xtreme" hardware. Link has another G4+ unit called "Thunder", which has some additional features. My understanding is they're working on a Thunder-based kit for the geeks and nerds that want more features.
The Xtreme is very powerful, but its input/output is close to maxed out the way Xcessive/Panic have it configured to work all the peripheral stuff on the IS300. The Thunder adds a bunch of I/O (plenty to run direct spark instead of waste spark) and adds two dedicated WBO2 controllers to the ecu board. The Xtreme requires an external WBO2 controller that sends a 0-5V signal to the ecu itself (consuming one of the analog-in channels).
The Xtreme is plenty for most purposes (plus you can use its canbus to daisy-chain more peripheral can devices), but the Thunder takes it up a solid notch.
GGM_IS likes this.
post #30 of 34 (permalink) Old 07-08-2019, 09:54 AM
Quoted: 63 Post(s)
So I talked to Guy from Xcessive this past weekend when I was there to drop off my car. I was inquiring about the Thunder and they said they are working on a kit for that but for the IS300, it's overkill. Even with the Xtreme, there are still many ports and options left untouched in it for users to configure what they want. This is for a daily driver, not track or anything. If you are doing track and drag where you would need more outputs, the thunder would probably be better. He also said the thunder is better for controlling cars with more cylinders. I get my car back in about 3 weeks and I'll let you guys know more.
« 2jzgte swap | -
Current users viewing this Thread: 3 (0 members and 3 guests)
Link g4 + PNP ecu! CorollaCannon Go Fast Stuff 2 12-05-2018 07:12 PM
AEM Fic Boomslang PnP Edwinjay Go Faster 3 10-26-2016 10:44 PM
