Link g4 + PNP! - Lexus IS Forum
 3Likes
post #1 of 25 (permalink) Old 12-05-2018, 07:46 AM Thread Starter
https://xcessivemanufacturing.com/toyota/is300.html
I am currently running this kit on my car, it is by far the best and most economical kit availabl! We finally have the option to get rid of the oem ecu and still have full oem functionality
Link g4 + PNP!-bbebf581-42a8-4000-b8da-6f5215ce6b31_1544021399793.jpegLink g4 + PNP!-aacfca0b-4874-4558-9352-e7bd9f41d34d_1544021374866.jpeg
Piggity likes this.
CorollaCannon is offline
post #2 of 25 (permalink) Old 12-05-2018, 09:19 AM
Quoted: 234 Post(s)
that is good to know and the pricing doesnt seem too bad for what you are getting. i knew they were working on something, but i didnt know they released it.
Lucy; 04 manual sportdesign
mesooohoppy is offline
post #3 of 25 (permalink) Old 12-05-2018, 08:24 PM
Quoted: 144 Post(s)
That’s pretty bad ass. I read the description, and it states a “check engine light” function...does that mean it’s OBD2 compatible? My infinity can have a cel output but it’s not OBD2 by any means. If the Link speaks obd, then it will be a good choice for folks that live in states requiring emissions checks. Also, I didn’t see if traction control is supported. I’d assume yes, since it sounds like the Link does DBW, and the traction control torque reduction is via DBW.
Kris OK is offline
post #4 of 25 (permalink) Old 12-06-2018, 05:04 AM Thread Starter
Unfortunately doesn’t support obd2 but the CEL light can be used for a multitude of things depending on what parameters you set for it. Yes it’s capable of traction control but I don’t have mine setup. You can run your cruise control with it as well. I currently use the cruise control switch to arm my anti lag
post #5 of 25 (permalink) Old 12-06-2018, 08:28 PM
Quoted: 144 Post(s)
Still pretty cool and no wiring nightmares. Definitely would consider if I wasn’t already on standalone.
Kris OK is offline
post #6 of 25 (permalink) Old 12-06-2018, 10:04 PM
Quoted: 38 Post(s)
I contacted them, it's using the Link Extreme board
https://www.linkecu.com/products/wirein-ecus/g4-xtreme/
el_jefe is offline
post #7 of 25 (permalink) Old 12-07-2018, 06:50 AM Thread Starter
Ya it’s the extreme with a panic wire jumper harness making it plug and play. It also comes with the maf subharness that you use for the iat sensor. It all works good and is super simple
post #8 of 25 (permalink) Old 12-07-2018, 10:44 AM
Quoted: 38 Post(s)
Did the OEM gauges work out of the box, or did you have to program that in?
el_jefe is offline
post #9 of 25 (permalink) Old 12-07-2018, 06:34 PM
Quoted: 209 Post(s)
We're using this setup on my friend's 1jz swapped drift car and it works great. Alot of nice features and very stealth. It comes in the stock ecu casing and fits into the stock ecu box. Has a built in MAP sensor and completely eliminates the stock ecu.
It also works with the stock muliplex system so a/c, fan relays and gauges all work. You can even program each indicator light on your cluster to do whatever you want. For example you can turn your CEL into a shift light if you wanted to.
Great standalone for the price, and has alot of nice features. Only downside is that it only works for manual transmission, so if you have a auto transmission you're out of luck. I'd say this is probably the best standalone for the IS300 just because you can completely eliminate the stock ecu.
Piggity likes this.
blkaltezza is offline
post #10 of 25 (permalink) Old 12-10-2018, 08:59 PM
Virgin Magnet
somguy2u's Avatar
Quoted: 72 Post(s)
i'm intrigued
TUI
Motorsports
Own the dream
LC SSI 006
SWTEA Talon
somguy2u is offline
post #11 of 25 (permalink) Old 01-30-2019, 04:36 AM
Do you mind sharing the manual?
How does it do CAN to MPX? The Link Altezza plugin has a CAN to MPX convertor on the logic board itself. Is it using the same board but different IO?
If there a AUX connector for unused IO? 2nd CAN?
Would really like to see the IO assignment.
Edit, did some digging. Looks like it IS the Altezza PnP but with a patch loom and reassigned IO in the Link..
Interesting..
wastegate is offline
post #12 of 25 (permalink) Old 02-18-2019, 05:17 PM
I have it, it's flawless.
akarilo is offline
post #13 of 25 (permalink) Old 02-26-2019, 11:10 PM
No alarm system then I take it?
Oregon_Ducks is offline
post #14 of 25 (permalink) Old 03-02-2019, 06:46 PM
Quoted: 58 Post(s)
says auto ecu is for auto chassis with manual swap but not for auto chassis still with factory auto trans?
"alcohol, the cause of and solution to all of life's problems"
braintumor is offline
post #15 of 25 (permalink) Old 03-02-2019, 07:58 PM
Yes, no automatic transmission solution available with Link to my knowledge.
akarilo is offline
Link g4 + PNP ecu! CorollaCannon Go Fast Stuff 2 12-05-2018 07:12 PM
AEM Fic Boomslang PnP Edwinjay Go Faster 3 10-26-2016 10:44 PM
