How to make your IS300 OEM Aristo Powered! - Page 4 - Lexus IS Forum
 2Likes
post #46 of 98 (permalink) Old 05-02-2013, 12:42 AM
Originally Posted by Pho King View Post
Trying to get this straight... The reason why you guys cut the heatercore pipes, is because clearance of stock twins...? Also. Does anyone know the thread pitch size bolt you guys used to put the engine (Aristo motor) on the engine stand? (bellhousing bolts) If you guys still remember... Sorry if it's off topic.
Are you planning on going GTE?
01 GGP E-Shift - SRT Intake, Sunroofless :) - SOLD
03 MSM 5-Speed w/ LSD
bmxrush is offline
post #47 of 98 (permalink) Old 05-02-2013, 01:02 AM
Yes. Bought my engine already. Just got my engine stand. Need to know thread pitch and size for bellhousing -> engine, so that I could throw it on when I go pick up the engine. Haha
Pho King is offline
post #48 of 98 (permalink) Old 05-05-2013, 01:15 PM
M12 x 1.25 ........
Pho King is offline
post #49 of 98 (permalink) Old 05-26-2013, 12:30 PM
I have read that the stock Aristo boost level is .7 - .8 bar (10-11.5 psi) and that opening up the intake and exhaust raises it to 1 bar (14.5 psi.) I have opened up my intake and exhaust and it seems in lower gears at full throttle my car is staying around .5 bar. It is only on the highway in 4th or 5th gear under high load conditions that it hits 1 bar. Is there an issue with the secondary turbo being actuated or the wastegate? Would adding a boost controler help this? Also, at what point will I need to be concerened with bosst/fuel cut and what method is used to fool the ecu or remove this on the stock Aristo ECU? I have read it is not as simple as getting a FCD becasue of the MAF. Thanks in advance.
2003 TCM Sport Design IS300 MT LSD with gte vvt-i
turbovr41991 is offline
post #50 of 98 (permalink) Old 06-17-2013, 09:19 PM
Quoted: 167 Post(s)
You should be able to build full boost in 1st,2nd, 3rd, etc. Check that you have everything electrically wired and pneumatically tubed properly. Check IACV first then EGCV..
If you have 3" exhaust and no cat... once it's fixed you should have problems controlling max boost and boost controller will do little to help you.
You will know boost cut over 15psi when it hits a wall and shuts down ignition/fuel.
whatthe is offline
post #51 of 98 (permalink) Old 06-18-2013, 07:59 AM
Technical Poseur
Quoted: 31 Post(s)
So, out of curiosity, what about the 98 Supra manual ECU for cars with manual transmissions? What would prevent that from being used? Also it would have OBDII compatibility for people in emission controlled states...
-Tom- is offline
post #52 of 98 (permalink) Old 06-18-2013, 10:13 AM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
Yea what he said. Sounds like you have a boost leak in a line or actuator. I can build full boost in any gear.
You in theory can use any engine and ECU so long as they go together....well to make the swap easier. The supra ECU won't control VVTi as GTE's here didn't come with it. I suppose you could probably run them in parallel, but in that case, you might as well run the Supra ECU with the IS ECU instead.
Looking to do an Aristo swap?
Aristo Swap with IS ECU
Aristo Swap with Aristo ECU
wingzero is offline
post #53 of 98 (permalink) Old 06-28-2013, 10:01 AM
so in order to be able to pass state emissions and still have a " decent " tuning capability the best would be to run OEM IS300 ecu in parallel with a standalone.
or is there a better solution ? ( while keeping OBD2 port working )
Culpable04 is offline
post #54 of 98 (permalink) Old 09-13-2013, 01:29 PM
Wingzero said he was running with the stock IS300 ECU (i believe with no other EMS). So sounds like if you are worried about emissions you can just go back to the stock ECU for your emissions test and then run an Aristo/Supra/stand alone etc. the rest of the time, if im not mistaken?
Drewfus32 is offline
post #55 of 98 (permalink) Old 10-15-2013, 06:08 PM
Can you use the stock is300 tranny?
jris300 is offline
post #56 of 98 (permalink) Old 10-15-2013, 09:57 PM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
Decent tuning capabilities have nothing to do with the ECU really. If your using a piggy back its going to do just that, piggy back off the factory ECU. If your using a stand alone it doesn't matter what ECU you use as the stand alone will be controlling all the major components needed to ensure your engine runs.
Easier (although not dead simple) emissions = Stock IS ECU w/Piggyback
50/50 Emissions = Stock IS ECU w/stand alone
Forget about Emissions = JDM Aristo ECU (or any JDM ECU Really)
There is NO JDM Toyota ECU on the planet that will interface with the Inspections machine here in the US. Period.
As far as OBD working, your best bet is keeping the stock IS ECU...I've been working on a way to read the Aristo ECU via the OBDII port but in all honesty, its been progressing slooooooow as I don't have the time that i used to anymore and I'm waiting for the weather to cool down to get back in the car again.
you CANNOT use the IS transmission with the Aristo ECU (which is what this thread is utilizing)
If you guys are wanting to use the stock IS ECU or the stock IS transmission, you are looking at the wrong thread...look at the swap doc thread.
It sounds like you guys haven't read too much, I can't be too sure. But let me kindly warn you....PLEASE READ AS MUCH AS YOU CAN before you attempt this swap. There is TONS of information on this swap (although more information exists on using the IS ECU and transmission as that's what most people do) Read on which method works for you and talk to your tuner, then make a decision.
While I'm not going to sit here and guarantee your swap will come out flawless if you follow either of my methods, both threads are sort of base guidelines to get the job done. Everyone's swap is different. Again, I can't stress how important it is to READ READ READ and understand what you are doing.
wingzero is offline
post #57 of 98 (permalink) Old 12-13-2013, 07:02 AM
03 Is300 Manual. Running stock ecu, passes emissions. wideband reads 10.8 under boost at 13-15lbs. TTC mod, B2 sensors cloned to B1 O2 sensors. MAF moved to TB side as blow through located at frame rail 18" from TB. NO CEL'S
cashed350 is offline
post #58 of 98 (permalink) Old 12-20-2013, 05:46 AM
Is the Aristo 2JZ-GTE motor compatible with the IS stock e-shift transmission? I think that was more of the question.
LiuIS300 is offline
post #59 of 98 (permalink) Old 12-20-2013, 07:35 AM
Superb write up. Thank u
Dr.FRM is offline
post #60 of 98 (permalink) Old 12-20-2013, 11:46 AM
Yes, check out the swap doc as this was part of the first path wing went down.
12bravo is offline
My T88 Powered IS300 Kaiyin Go Faster 32 03-31-2008 09:48 PM
Finished Product Aristo Powered IS300 wingzero Go Faster 18 03-21-2008 10:13 AM
2JZ-GTE VVT-i, Aristo powered SportCross :) bradleyjpyle SportCross Owner's Forum 17 11-21-2007 12:39 PM
Anyone gone from non-powered seats(cloth) to powered? Chan Showroom 26 04-09-2006 03:55 PM
