How to make your IS300 OEM Aristo Powered! - Page 3 - Lexus IS Forum
 2Likes
post #31 of 98 (permalink) Old 02-06-2013, 07:09 AM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
Originally Posted by IS300_2jzgte View Post
I have the 5 speed automatic, I know its weak, but its holding up pretty well, I'm being extra cautious and soft on it.
anyhow, would it be better to get the Aristos ECU? or should I just go with a piggyback?
And which piggyback?
Stock Auto should EASILY hold the power from a stock GTE engine. No problems, provided you perform the VB upgrade and transmission cooler.
ECU is your personal choice, as is the Piggyback. AEM and E-Manage are probably the most popular though. If your car is running just like you want it, don't change the ECU. The only reason I went to Aristo ECU is cuz I just wasn't happy with the way it was running on the stock IS ECU.
Originally Posted by turbovr41991 View Post
Intake and Exhaust Camshaft Seals (903114002) Are you missing a number in this part ID?
I might be....I'll double check.
Looking to do an Aristo swap?
Aristo Swap with IS ECU
Aristo Swap with Aristo ECU
wingzero is offline
post #32 of 98 (permalink) Old 02-15-2013, 02:46 PM
Originally Posted by wingzero View Post
Rear Main Seal (1138146010)
Might need to doube check this on too. It looks like this is the seal retainer, not the seal itself. I found out the hard way...... :/
2003 TCM Sport Design IS300 MT LSD with gte vvt-i
turbovr41991 is offline
post #33 of 98 (permalink) Old 02-16-2013, 09:04 PM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
my bad bro, I'll definitely update that.
wingzero is offline
post #34 of 98 (permalink) Old 03-09-2013, 03:45 PM
Question... How much harder would it be to use the W55 instead of the auto?
usptwins is offline
post #35 of 98 (permalink) Old 03-09-2013, 04:54 PM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
I don't think it would be that much harder, obviously drive shaft part wouldn't irrelevant. Read up on Auto to Manual swap that's in the Go Faster section. That should give you an idea.
wingzero is offline
post #36 of 98 (permalink) Old 03-09-2013, 06:06 PM
Yea, i was, thanks man. Its just what your title said, so i was just wondering if everything would work like your plan was lol
usptwins is offline
post #37 of 98 (permalink) Old 04-10-2013, 10:13 AM
Wait you can run the stock ecu off the is300 ecu?
jris300 is offline
post #38 of 98 (permalink) Old 04-10-2013, 10:17 AM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
huh? what are you talking about?
wingzero is offline
post #39 of 98 (permalink) Old 04-10-2013, 10:34 AM
The ecu ...are you running both?
jris300 is offline
post #40 of 98 (permalink) Old 04-10-2013, 10:56 AM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
oh, no only Aristo ECU with NO piggy back. Pure OEM
wingzero is offline
post #41 of 98 (permalink) Old 04-22-2013, 12:04 AM
Some good info
konaboi808 is offline
post #42 of 98 (permalink) Old 04-25-2013, 08:36 PM
When running stock twins, does anyone have issues with the heater core lines rubbing on the turbo feed pipe? I have cut back the heater core lines over an inch and had the turbo inlet pipe and compresser housng machined down 5/8 of an inch and it still looks too tight for my liking.
post #43 of 98 (permalink) Old 04-26-2013, 07:30 AM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
You cut the pipe an inch or down to an inch....big difference there. I have had ZERO leak issues on my engine for over 5 years now. The lower hose is a Frankenstein'd line with rubber, aluminum, rubber and aluminum pieces on mine. That's just the way mine turned out, but I'm sure a better solution can be produced.
wingzero is offline
post #44 of 98 (permalink) Old 04-26-2013, 03:28 PM
They are right around 3/4 to and inch currently from the firewall. The heater core tubes themselves do not rub, but if I attach a hose to it they do. Just afraid the engine vibration will wear through the coolant lines over time. Do you have pictures of your current setup? Thanks.
post #45 of 98 (permalink) Old 05-02-2013, 12:18 AM
Trying to get this straight... The reason why you guys cut the heatercore pipes, is because clearance of stock twins...? Also. Does anyone know the thread pitch size bolt you guys used to put the engine (Aristo motor) on the engine stand? (bellhousing bolts) If you guys still remember... Sorry if it's off topic.
Pho King is offline
My T88 Powered IS300 Kaiyin Go Faster 32 03-31-2008 09:48 PM
Finished Product Aristo Powered IS300 wingzero Go Faster 18 03-21-2008 10:13 AM
2JZ-GTE VVT-i, Aristo powered SportCross :) bradleyjpyle SportCross Owner's Forum 17 11-21-2007 12:39 PM
Anyone gone from non-powered seats(cloth) to powered? Chan Showroom 26 04-09-2006 03:55 PM
