Finally Going Boosted - Page 2 - Lexus IS Forum
 32Likes
post #16 of 89 (permalink) Old 07-23-2015, 03:15 PM
Quoted: 230 Post(s)
Originally Posted by phistration View Post
Well here is the latest update. The radiator, motor, transmission, driveshaft, and exhaust are out and the wide band and boost controller came in. The motor should be coming apart today.
Congratulations are in order!
2003 GGP | "You Can't See Me"
Hotchkis sway bars, LS400 bbk, Stance coilovers, Customwerks rear strut tower bar & trunk brace, Megan diff. brace & traction bars, OBX short-tube headers, Fidanza exhaust cam gear, GTE cams, NX wet kit, winter camo wrap 👀
The Nuke is offline
post #17 of 89 (permalink) Old 07-27-2015, 10:59 PM
Quoted: 184 Post(s)
+ Rep to OP! This is awesome!
White2003Lexus is offline
post #18 of 89 (permalink) Old 07-31-2015, 03:47 PM Thread Starter
Quoted: 10 Post(s)
Motor is apart and the block is being cleaned and decked. Valve seals being redone and head cleaned. The valve covers are off to the powdercoaters. Motor looked really good for 166,000+ miles. There were a few oil leaks but that is to be expected. Radiator, radiator hose, steel braided brake lines, and caliper rebuild kits are in. A new AC condenser is on order. The old one is on its last leg. Clutch and flywheel are in. Lots of pictures below.
03 IBP; Custom Audio/Video System; JIC TI Exhaust; Tein H Tech Springs, Tokico Shocks; 18" Axis Hiros, AAC Custom Headlights w/demon eyes, cleared fogs, soon to be added 200A alternator
Boost is on the way!
phistration is online now
post #19 of 89 (permalink) Old 07-31-2015, 03:53 PM
PANIC!!!'s Avatar
Quoted: 228 Post(s)
I love how there is not fkng around in this thread, straight to the build. I'm happy for you and continue with the updates!
Poke_IS300 likes this.
PANIC!!! is offline
post #20 of 89 (permalink) Old 08-01-2015, 03:46 PM Thread Starter
Quoted: 10 Post(s)
For some reason i can't post pictures. Maybe they are too big. I will have to find a way to resize them.
post #21 of 89 (permalink) Old 08-01-2015, 04:12 PM Thread Starter
Quoted: 10 Post(s)
OK maybe this will work..
ID:	81969   Click image for larger version
ID:	81977   Click image for larger version
ID:	81985   Click image for larger version
post #22 of 89 (permalink) Old 08-01-2015, 08:02 PM
Quoted: 7 Post(s)
Well put.
A lot of people play games, whereas op does not.
09 MSM ISF
RR | HP |
svtec is offline
post #23 of 89 (permalink) Old 08-02-2015, 03:13 PM Thread Starter
Quoted: 10 Post(s)
Originally Posted by svtec View Post
Well put.
Thanks guys. I am just turning a dream I have had for a while into reality. I would post more pictures but for some reason I can't. The block is supposed to be back from the machine shop Tuesday or Wednesday. I will try and figure out a way to post more pics. I think I have exceeded my maximum limit.
post #24 of 89 (permalink) Old 08-03-2015, 05:44 PM Thread Starter
Quoted: 10 Post(s)
Lets see if this works...
post #25 of 89 (permalink) Old 08-05-2015, 05:20 AM Thread Starter
Quoted: 10 Post(s)
Unfortunately the block has been delayed until Friday at the machine shop. On a good note the intake manifold has come in. I will post a pic of it a little later. I haven't seen it in person yet but from the picture it looks pretty good.
post #26 of 89 (permalink) Old 08-13-2015, 02:40 PM Thread Starter
Quoted: 10 Post(s)
It has been a little bit since I have posted an update because the block was at the machine shop. I am going to check on the car tomorrow. In the mean time I would like to know what air filter you boosted guys use besides K&N. I refuse to use them again.
Thanks.
post #27 of 89 (permalink) Old 08-14-2015, 02:55 PM
Quoted: 167 Post(s)
Thanks.
If you don't have a MAF sensor to worry about, there is really not much to worry about with K&Ns. I usually clean the K&N but don't oil them much or at all. It makes for a reduced efficiency catching particles, but haven't had a failure or notable damage on a teardown from it.
That said, I usually just go with AFE now as you can build the part number for the dimensions you need, and they come in either dry or oiled configuration.
Advanced FLOW Engineering
whatthe is offline
post #28 of 89 (permalink) Old 08-16-2015, 04:45 AM Thread Starter
Quoted: 10 Post(s)
Thanks for the suggestions. I am not interested in K & N not because it is oiled. I had a bad experience with them in the past. It allowed an unacceptable amount to dirt past the filter. Had one on the car and the bike. I removed both of them. I will look into the Advanced Flow Engineering filters. Any other suggestions? Keep them coming. I went to look at the block Friday but it still was not back from the machine shop. It is supposed to be ready by Monday. I am not holding my breath. At any rate either way on Monday I will post some more pics as more stuff has come in.
post #29 of 89 (permalink) Old 08-19-2015, 05:32 AM Thread Starter
Quoted: 10 Post(s)
Well unfortunately it will be a few more days before the block is ready. So far it has gone through 3 hot dips. Still needs to be blasted, however I was able to get a few pictures and one of my goodies that I have been waiting for finally came in!
post #30 of 89 (permalink) Old 08-26-2015, 04:16 PM Thread Starter
Quoted: 10 Post(s)
Well finally got the block back from the machine shop Friday. I didn't get a chance to go by and see it until last night. While I was at the shop I took a few pictures of some other parts that came in. I am still looking for air filter suggestions. I plan to start filing rings for the pistons this weekend. I will also be replacing the valve seals.
The block
Pile O Parts
Equal length turbo manifold
Tail Blowoff valve
Tail Wastegate
Intake plenum
Flywheel
New tensioner to go with the timing belt
Turbo Oil Line Fittings
New Water Pump
New Oil Pump
3" downpipe
Turbo Blanket
New Condenser for AC
Poke_IS300, c1L and poland153 like this.
« 2jzgte swap | -
Current users viewing this Thread: 5 (1 members and 4 guests)
phistration
Boosted in AU... Finally. nymidas Go Faster 13 11-22-2010 05:43 AM
I'm finally boosted(pics) bigkahuna2187 Go Faster 40 02-01-2007 02:35 PM
Finally boosted!!!! Pics Inside. More to come. 2001_LeXuS_IS300_19 Showroom 21 10-08-2006 09:52 PM
Finally Boosted FiJeeBOi Go Faster 44 06-19-2006 01:58 PM
Finally Boosted: PICS Inside vvt-inside Go Faster 30 02-14-2005 07:12 PM
