Hello All.
I know this has been covered many times before but I just wanted to document my journey to being boosted here. So bear with me as I indulge myself in my dream as it becomes a reality. My car is a 2003 IBP IS300 manual that I have owned since new. It currently has 166,000 miles on it. So my boosted project is going to be done in 3 stages. Motor, Turbo, Transmission. I will post my direction on each stage and if you guys have some meaningful input I am all ears. My goal is a 450hp, pump gas, daily driver with OEM reliability. So here it goes.
I will be rebuilding the GE that is in the car with the following parts
CP Pistons and rings
Eagle Rods
ACL bearings
OEM gasket set
Metal Head Gaset 1.6mm
New water pump
New timing/tensioner belt
ARP headbolt/studs
Machine work on block
Mishimoto radiator
Turbo
T4 GT35R
Tial BOV
FMIC with custom piping
Tbolt clamps
Injector set
Custom Intake manifold
Tial wastegate recirculated
Stainless steel downpipe
Stainless steel midpipe
Fuel line/regulator/ walbro pump
oil line/feed and drain
AEM wideband
Greddy Profec boost controller
Transmission
I would love to do the AR5 swap but the threads are too difficult to understand exactly what is needed. If someone could chime in here I would greatly appreciate it.
If not I have an R154 on standby.
Eagle Rods
ACL bearings
OEM gasket set
New water pump
ARP headbolt/studs
Mishimoto radiator
Turbo
T4 GT35R
Tial BOV
Tbolt clamps
Injector set
AEM wideband
Transmission
