Filthy Build - Page 3 - Lexus IS Forum
 36Likes
post #31 of 55 (permalink) Old 12-15-2016, 09:28 PM Thread Starter
Quoted: 14 Post(s)
Originally Posted by whatthe View Post
Yikes! Nothing came inside passenger compartment at least?
Looks like some good progress since that tragic event...
No luckily not. Was pretty scary doing 140kph and the trans tries to hit the ground. The shifter actually bruised the palm of my hand when the clutch hit the bell housing.
Sniper512 is offline
post #32 of 55 (permalink) Old 12-16-2016, 04:34 PM
Quoted: 36 Post(s)
That's nightmare level, it could have been way worse than that.
xXInsanePowerXx is offline
post #33 of 55 (permalink) Old 12-16-2016, 11:14 PM Thread Starter
Quoted: 14 Post(s)
Finally got my Dyno sheet! This was at 15psi. On the street I hit 20psi, but for some reason I was only seeing 15.
post #34 of 55 (permalink) Old 12-17-2016, 06:28 PM
Quoted: 195 Post(s)
great numbers
VEHEMENCE is offline
post #35 of 55 (permalink) Old 12-18-2016, 08:30 AM
Solid build and great looking power through the RPM's! What size turbo is this with? Whatever is it, it has nice early spool, must be fun to drive!
ColonelShots is offline
post #36 of 55 (permalink) Old 12-18-2016, 10:17 AM Thread Starter
Quoted: 14 Post(s)
It's the SRT spec'd Precision turbo from the SRT 2.75 kit. Not sure of it's exact specs, but she spools good and hits hard. I am assuming its a 60+mm maybe a 6262.
post #37 of 55 (permalink) Old 12-21-2016, 08:41 PM
The SRT kit comes with a 6266 - 62mm compressor side 66mm turbine side. I'm looking at getting a BW turbo of similar size because I'm looking for moderate power with quick spool - very similar to your set up. Absolutely amazing you are running 15-20 psi with that nice early spool. Got to love the 2JZ!
Sniper512 likes this.
post #38 of 55 (permalink) Old 12-31-2016, 07:00 AM Thread Starter
Quoted: 14 Post(s)
Thanks! I figured it was around there.
post #39 of 55 (permalink) Old 01-02-2017, 10:19 AM
Quoted: 167 Post(s)
You should ask them for a print out without the solid fill color and the torque + power scaled the same. Looks like two runs, but you can really only see the one run because of the solid fill and then can't quite follow hp+torque either because of the shading. I guess it's 275 ft lbs at 3500rpms and then it hits pretty hard after that? Definite big improvement over stock.
Sometimes dynos don't load the car up the same as the street, depends on gear they used, plus lack of airflow and you'll see less boost. I wouldn't be surprised to see more power on the road from it.
whatthe is offline
post #40 of 55 (permalink) Old 01-02-2017, 11:17 AM Thread Starter
Quoted: 14 Post(s)
Ya she hits nice and hard around 3500rpm. This was a 4th gear pull. I am going back for more fine tuning in the spring and will get a better graph going. They also had ideas for helping the car see 20psi on the dyno. Hopefully we can sort that out at the next go around. There were definitely issues around load. Brake-boosting actually netted me lower numbers as well.
post #41 of 55 (permalink) Old 04-15-2018, 11:08 AM Thread Starter
Quoted: 14 Post(s)
Update from over the winter. Borgwarner S366sxe, BC 264 cams, ABS delete, ECU Master EMU, returned fuel system, 450lph pump, aeromotive FPR, Full paint correction with ceramic coating. Goes on the dyno next week and will post up video and dyno numbers. Car will be coming back soon and black powder will be going on all the plumbing as well as black couplers, Compressor side of the turbo is going the candy red on the valve covers and the exhaust side of turbo is ceramic coated and will be getting a blanket.
ID:	117921   Click image for larger version
ID:	117929   Click image for larger version
ID:	117937   Click image for larger version
post #42 of 55 (permalink) Old 04-15-2018, 11:15 AM Thread Starter
Quoted: 14 Post(s)
A few more pics.
ID:	117961   Click image for larger version
ID:	117969   Click image for larger version
ID:	117977   Click image for larger version
ID:	117993   Click image for larger version
ID:	118001   Click image for larger version
TobiasSing, toneekay and Arzon like this.
post #43 of 55 (permalink) Old 05-10-2018, 08:09 PM Thread Starter
Quoted: 14 Post(s)
Well she did good! Not bad for 19psi on 91 octane.
Here's the video
https://www.facebook.com/713595782/v.../?id=713595782
tony9189 and toneekay like this.
post #44 of 55 (permalink) Old 10-05-2018, 09:48 PM Thread Starter
Quoted: 14 Post(s)
Got some new shoes for lexi!
2002 IS300 528whp @ 18psi
2009 Taco
2006 4 Runner
Insta @boosted512
post #45 of 55 (permalink) Old 10-06-2018, 06:27 AM
Quoted: 359 Post(s)
Those look great! What brand and model etc.. Details please.
Really filthy & Gross - AC Cabin Pollen filter mjdart General Discussion 15 07-30-2002 07:06 PM
