Crazy driveline vibration after AR5 conversion - Page 2 - Lexus IS Forum
 2Likes
post #16 of 46 (permalink) Old 07-17-2018, 07:57 AM Thread Starter
Quoted: 12 Post(s)
Update: I purchased and Installed the proper Curran crossmember, as well as a brand new mount.
I installed it yesterday, and noticed it seemed to change the height that the rear of the transmission sits it. I assumed this corrected the angle, or at least is a step in the right direction.
Unfortunately, I drove the car through the gears in the air, and the vibration still starts at 45mph and did not seem to change
My next step will be to remove the driveshaft and measure the angles, and start adding some washers to raise or lower it some more.
Regarding the above posts^
I have checked to make sure nothing is loose, and I agree that the problem is likely with the new parts, since it did not exist before.
If it comes down to it, I may actually consider getting that 2 piece driveshaft made, if that's what it takes to drive the car without the vibration.
Originally Posted by 03ThunderSport View Post
Which figs bushings did you install?
Both of those are installed
Originally Posted by polish man View Post
If you go with the curran mount be sure you have the bracket that bolts to the trans before the solstice rubber mount as its discontinued. Wouldve had to remove it to get the w55 mount on there
I have that bracket, but theres some bad news. I did the original install with friends help. After taking off that bracket, the w55 mount was slightly too narrow to fit.
While I was working on something else, without me knowing, one of them shaved down the actual transmission housing in order for the mount to fit.
I was pissed when I saw that he shaved the actual transmission, instead of the mount, but now there is nothing that can be done.
With the w55 on, it sat snug and did not make the trans jump around when shifting. Now when trying to mount the original bracket, it does not sit snug against the transmission, as there is a decent gap where they should be touching. I will try get a picture when I am down under the car again.
When shifting gears in the air, it seemed like the transmission jumped up and down a good bit, and I'm guessing that's the reason.
I will likely have to shave the trans a little more and add a washer, possibly a rubber washer. Aside from replacing the whole tailshaft housing on the trans, I am not sure what else I can do
'04 5mt MSM
ant_suds is offline
post #17 of 46 (permalink) Old 07-17-2018, 10:15 AM
Quoted: 17 Post(s)
thats how i did my trans mount didnt like the look of half the mount being used so made a bracket to cross top. Stock cross member slotted mounting holes a touch, aftermarket w55 mount
[IMG][/IMG]
polish man is offline
post #18 of 46 (permalink) Old 07-17-2018, 01:10 PM Thread Starter
Quoted: 12 Post(s)
[IMG][/IMG]
Sounds interesting, can you upload a different picture? That one is saying its a broken image
'04 5mt MSM
ant_suds is offline
post #19 of 46 (permalink) Old 07-17-2018, 03:08 PM
Quoted: 66 Post(s)
Had this exact same issue. My issue wasn't abated until I purchased a CV driveshaft from DSS. The solstice used a CV driveshaft too. DSS basically said they had too much trouble with a fixed transmission and fixed diff that they no longer would produce the type of shaft you're struggling with. The CV is smooth as butter..
I must have put on and taken off my 1 piece double u-joint with sliding joint about 50 times and even purchased a driveline analyzer machine off ebay. Check out my thread on the issue..
Ek9B18 likes this.
lessthanjakejohn is offline
post #20 of 46 (permalink) Old 07-17-2018, 05:40 PM Thread Starter
Quoted: 12 Post(s)
Here is my transmission with the new crossmember
You can see the gap I am referring to, between the transmission housing itself, and the bracket for the trans mount.
They arent shaved perfectly flat, so i might try to shave them enough to fit some 3/8" washers in there. Hopefully this can bring that part of the tailhousing to its original shape.
Interesting. I wonder why this is only an issue with some people's IS300s, but other people with the AR5 conversion have never had the problem.
Good to know that's another option. Does your diveshaft use a carrier bearing? Or is it still a 1 piece driveshaft?
ID:	120169   Click image for larger version
'04 5mt MSM
ant_suds is offline
post #21 of 46 (permalink) Old 07-17-2018, 05:54 PM
Quoted: 66 Post(s)
mine is a 1 piece 4" aluminum shaft rated at 500hp. they will make whatever you want though. It's like a german CV joint that mates to a porsche. They sent an adapter and I had to get it milled down to clear the shifter too. They said they updated their blueprints for future cars based on my experience but who knows.
cheapest option would be to have just modified the 2 piece stock driveshaft from the start
post #22 of 46 (permalink) Old 07-17-2018, 07:18 PM
Quoted: 790 Post(s)
Those bastards told me I couldn't get a CV on that end. Said it wasn't strong enough. Once I balanced my shaft, it worked fine up to 120 mph so, I'm not really sure why it didn't work for you. My V8 does place the transmission in a slightly different position I guess.
Plenty of other people have gotten this working without vibration using the drift motion setup. It's pretty close to the same as the DSS with adapter setup. It's not clear why it works for some people but not others.
Ant did you ever check runnout on the shaft and adapter?
Ek9B18 is online now
post #23 of 46 (permalink) Old 07-17-2018, 07:27 PM
Quoted: 66 Post(s)
the CV was a new thing for them. probably didn't have that part sourced at the time you asked.
I think my issue may have been runout from the local shop that shortened the shaft. When I measured it, it seemed like quite a bit but I don't really have much experience to tell how much is too much. That shop was too far away to go back though as I couldn't drive the car above 40mph lol.
post #24 of 46 (permalink) Old 07-17-2018, 07:35 PM
Quoted: 66 Post(s)
other things I noticed:
my low mileage AR5 has some play in the output shaft - maybe some AR5 transmissions are better than others in this regard.
the solstice transmission mount is super flexible. I bought another and filled it with poly window glue but haven't installed it yet.
I think in my situation these 3 things together caused the issue
post #25 of 46 (permalink) Old 07-18-2018, 10:05 AM
Quoted: 17 Post(s)
^output shaft can be snugged up just dont over do it
try that its workin on the desktop im using may have hit wrong link yesterday
post #26 of 46 (permalink) Old 07-27-2018, 05:28 PM Thread Starter
Quoted: 12 Post(s)
Well, with the crossmember in, there is only 0.2 degrees difference in driveline angle from the transmission output flange, and the differential flange. I think its safe to say the angle is no longer a factor.
While the car was on a lift, I put it on cruise control in 5th gear, to make the car continuously vibrate. The computer was confused and was constantly coming on and off the gas.
I noticed that the output shaft comes in and out with throttle input. Is this normal?
Here is a video:
https://youtu.be/ZnE038rF2_U
That is the next thing I want to check, but I don't have the means for that. When you say runout, are you talking about the flange face, like a brake rotor spinning in a bad wheel bearing? Or are you talking about the output shaft having some up and down play?
My AR5 was from LKQ and said to have 86k miles. It shifts beautifully, however before install I did notice that the output shaft had a tiny bit of play. I was told that amount of play is normal, and nothing to worry about.
I also noticed that the brand new (said to be OEM Pontiac) transmission mount was extremely flexible, and the transmission moves around a decent amount because of it. Those gaps where I mentioned putting washers, surprisingly create no play or movement, and the transmission is held secure there.
I may try filling it with polyurethane
'04 5mt MSM
ant_suds is offline
post #27 of 46 (permalink) Old 07-27-2018, 05:37 PM
Quoted: 66 Post(s)
you need to press TRAC OFF i think
Just search runout gauge on ebay. I already had one for my bicycle disc rotor but they are only like $25
post #28 of 46 (permalink) Old 07-27-2018, 05:40 PM
Quoted: 66 Post(s)
That W55 transmission mount looks way better than the GM one. I would try to poly fill the GM one next and see if that helps. That's a significant difference between polish_man's setup and ours.
post #29 of 46 (permalink) Old 07-27-2018, 09:04 PM
Quoted: 790 Post(s)
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Is the one I use. Was using it on my drill press the other day. Discovered that if you use the flutes into the bits you get a bunch of wobble but if you stick it farther in so it's just the round part, there's almost none.
Seems kind odd to me. I'd expect the CV joint to move in and out, not the output flange. I wonder how much thrust movement is acceptable? I can't find the end play specs.
I don't think much of how that guy used the exhaust for his magnetic mount.
post #30 of 46 (permalink) Old 07-31-2018, 08:22 AM Thread Starter
Quoted: 12 Post(s)
This is true. I had trac off, but I think the computer for cruise control was confused with the car being in the air, since the rear wheels were moving and the fronts were not.
I definitely want to try this, but I don't think this is related to the vibration, so I will wait until after I get this issue sorted out.
That's what I am trying to figure out. Is that kind of thrust movement at the output shaft considered normal? Or should I be looking into that as a potential culprit?
Apparently some people have issues with the nut holding the output flange onto the shaft backing out or getting loose. However its similar to an axle or something where one side of the nut gets punched into a little recess on the shaft, to prevent it from backing out, so I find that unlikely.
I would like to check that nut regardless, but I am unable to find the torque spec for it on any website, or using AllData. Anyone have any information on that? I don't want to just crank on the nut and end up destroying a bearing or something from over tightening a nut that was perfectly fine.
Its getting to the point where I might have to pay a transmission or drivetrain specialist to diagnose this. I would hate to spend the money, but I am unable to figure this out and am starting the school semester in less than 3 weeks, and am going to need my car in good working order.
'04 5mt MSM
ant_suds is offline
Comprehensive AR5 Swap Thread Curran Go Faster 140 05-26-2019 08:41 PM
