Comprehensive AR5 Swap Thread - Page 8 - Lexus IS Forum
 5Likes
post #106 of 141 (permalink) Old 08-14-2018, 01:17 AM
I got all the parts for the Ar-5 tranny with driftmotion super single clutch kit the only thing I’m missing is the crossmember the tranny bracket i cant find it anywhere can i use the w55 crossmember?
Reda Jamal is offline
post #107 of 141 (permalink) Old 08-14-2018, 01:25 AM
Originally Posted by Reda Jamal View Post
I got all the parts for the Ar-5 tranny with driftmotion super single clutch kit the only thing Iím missing is the crossmember the tranny bracket i cant find it anywhere can i use the w55 crossmember?
post #108 of 141 (permalink) Old 08-14-2018, 07:40 AM
Quoted: 104 Post(s)
By bracket do you mean the actual transmission mount? Look to purchase a solstice one or a more recent Polaris Slingshot one. As far as the crossmember you can PM member Curran.
IS3TT
FRaCTioNaL is offline
post #109 of 141 (permalink) Old 08-14-2018, 09:16 AM
Quoted: 25 Post(s)
Curran is your man. Brandon made a really nice product...unsure if he is still selling it now though. I got mine from him on eBay.
2004 CWP IS300
AR5
dcharms is offline
post #110 of 141 (permalink) Old 08-14-2018, 01:50 PM
I couldnít find anything on ebay I heard other people say the auto crossmember would work is that true?
post #111 of 141 (permalink) Old 08-14-2018, 02:10 PM
Quoted: 104 Post(s)
PM him. He makes them in batches and puts them up in ebay. I would not know about the automatic transmission crossmember.
IS3TT
post #112 of 141 (permalink) Old 09-01-2018, 10:45 PM
Hey guys i got all the parts Iím only missing breather plug couldnít find it in the internet by any chance is there any part shop sells it
post #113 of 141 (permalink) Old 09-23-2018, 09:45 PM
Any ideas one the reverse wiers where it goes in aristo auto sensor and what about the speed sensor i have the auto sensor will it work ?
Thanks
post #114 of 141 (permalink) Old 09-23-2018, 11:21 PM
Quoted: 789 Post(s)
The reverse light wires are in the auto-transmission harness connection I believe. You need to pull the wires from the connector and wire them to the reverse switch in the tranny.
I think I used the auto sensor but it's been a couple years. The sensor that came with the transmission will work too though the pulses off the AR-5 don't really match the pulses the auto puts out.
post #115 of 141 (permalink) Old 10-20-2018, 05:11 PM
w58 heavy duty pressure plate action 6 puck
i really should of bought the kit...but i was impatient so now im looking for a pressure plate for ar5... using w58 components, i have the action 6 puck from driftmotion and a competitionclutch lightweight flywheel. will a w58 heavy duty pressure plate hold 500hp or should i just spend the money and use r154 components
ar51jzvvti is offline
post #116 of 141 (permalink) Old 10-21-2018, 12:11 AM
Quoted: 147 Post(s)
You kind of limit yourself to max HP of that amount -500- with the w58 setup. I use an ACT extreme PP and the highest rated full face clutch disc in mine. I think ACT said it would hold ~450tq. I’m running a BWs362sxe, ID1050x, and about 16psi, and I’ve never slipped the clutch. I did blow out my spark and had to go COP. I could probably turn the boost up, and slip the clutch but I am satisfied where it’s at. The only thing I want to do now is maybe a set of GSC S1 cams and springs, and I’ve got a flex fuel sensor I need to plumb in. I drive this thing daily, so 500hp is good for me.
TL;DR: If you ever plan on >500HP, I’d advise the r154 route, or a multiplate set up. Less than 500, W58 is sufficient.
Kris OK is online now
post #117 of 141 (permalink) Old 02-01-2019, 09:16 PM
Just finishing up my AR5 swap, but I have a question,
Did anyone else have their Driftmotion driveshaft flange contact the JZX110 shifter housing? 3 of the 4 corners clear, but the one corner makes contact on the housing. See attached picture. And yes that's tape keeping water out of my cabin.
Not a problem, I needed to pull the housing off to make more room for the flange adapter anyway.
Just curious as I don't think I read anywhere about the driveshaft making contact, only the flange adapter being close. My best guess is the flange barely passed QC and is just within the +/- size tolerance haha.
dexefcs is offline
post #118 of 141 (permalink) Old 02-01-2019, 09:37 PM
Quoted: 66 Post(s)
I didn't have that adapter but I had an issue with my adapter from DSS for my CV prop. It was just a generic GM adapter so it wasn't necessarily meant for this application unlike yours. I had it turned down by a shop.
I think I remember people on facebook complaining about the same type of interference though from the drift motion adapter.
lessthanjakejohn is offline
post #119 of 141 (permalink) Old 02-01-2019, 11:09 PM
Quoted: 104 Post(s)
No problem here. Same dm adapter.
IS3TT
post #120 of 141 (permalink) Old 02-02-2019, 01:21 AM
I have the sameً adopter i had to shave the drive shaft with a grinder a little bit just not to make it hit tho
