Comprehensive AR5 Swap Thread - Page 6 - Lexus IS Forum
 5Likes
post #76 of 141 (permalink) Old 12-21-2017, 10:52 PM
Quoted: 66 Post(s)
omfg I'm such an idiot
fuckers sent me a 12 mm inner diameter pilot bearing and I didn't check the size before I put it on... Now I gotta take it out and find a new one quick!
Hope one of these bearing supply stores has what I need so I can get the transmission on tomorrow.
lessthanjakejohn is offline
post #77 of 141 (permalink) Old 12-22-2017, 06:10 AM
I was going through a list of transmissions for the solstice. can anyone elaborate on which transmission on the solstice. when i'm looking for the tranny locally i keep on finding these two.
MT, beam from tail housing to rear differential
MT, tail housing mounted to frame crossmember
which one is the right transmission?
s13silvia123 is offline
post #78 of 141 (permalink) Old 12-22-2017, 06:44 AM
Quoted: 66 Post(s)
that one is the right one, from the 06-mid 07 models
basically just mounts up with a crossmember between the tunnel. The other later one mounts to the differential and would need more fabrication.
post #79 of 141 (permalink) Old 12-22-2017, 09:01 AM
Quoted: 25 Post(s)
The correct transmissions are becoming pretty rare. The "without interim design change" trans is the one you want.
2004 CWP IS300
AR5
dcharms is offline
post #80 of 141 (permalink) Old 12-22-2017, 09:47 AM
Quoted: 147 Post(s)
Ive seen these offered as a manual transmission from a Polaris Slingshot, also.
Kris OK is online now
post #81 of 141 (permalink) Old 12-22-2017, 10:43 AM
Quoted: 66 Post(s)
k some $2 POS chinese bearing from fastenal is going in there.
post #82 of 141 (permalink) Old 02-20-2018, 12:13 PM
Quoted: 66 Post(s)
There are 5 or 6 of these on eBay for 600-800.
It's too bad there is no way to "flip" these cars. Now that I know how to do it all and have all the parts tracked down I could do the whole thing in a weekend including potential engine seals. The parts cost is just prohibitive. $4k.. ugh Taking a $3k craigslist automatic and putting a manual in it != 7k+my labor+profit
post #83 of 141 (permalink) Old 03-16-2018, 07:32 AM
Quoted: 66 Post(s)
AR-5 on an LSX.
So I if you search for LSX supra conversions you'll find people using an R154. It stands to reason that the AR-5 would also be compatible.
There's https://www.novak-adapt.com/catalog/...15/kit-gmax15/
And AdvanceAdapters.com | Engine & Transmission Conversion Adapters - Advance Adapters
post #84 of 141 (permalink) Old 03-17-2018, 02:42 PM
Quoted: 18 Post(s)
Where is everyone getting their shifter housings? Toyota part 3357022150? Anywhere in the US? Only found them in Europe and Japan.
RAJJis300 is offline
post #85 of 141 (permalink) Old 03-17-2018, 04:03 PM
Quoted: 147 Post(s)
Amyama trading co is where I found mine. Shipping can be expensive so try to order everything you will need.
post #86 of 141 (permalink) Old 03-17-2018, 04:21 PM
Quoted: 66 Post(s)
Too bad no one knows the part number to this piece. It was used on the ZOK solstice.
post #87 of 141 (permalink) Old 03-18-2018, 12:32 AM
Quoted: 147 Post(s)
What would that piece allow? So you could use a newer AR5 with the side mount?
post #88 of 141 (permalink) Old 03-18-2018, 07:22 AM
Quoted: 790 Post(s)
I was thinking the solution was to fab up a mount like this. If you could get the torque arm from the solstice it wouldn't be that hard to weld a mount bracket to it at some specific height. The GM part looks like a casting probably from aluminum.
I once looked into it, these brackets are as rare as hen's teeth. GM never made many of them in the first place.
Yes.
Ek9B18 is online now
post #89 of 141 (permalink) Old 03-18-2018, 09:45 AM
Quoted: 66 Post(s)
Yeah I don't think the part is possible to get. But it does give an idea for fab, but you're right it's a cast part.
If I ever needed another one I would probably just find a low mileage and swap my current tailshaft housing on to it.
post #90 of 141 (permalink) Old 03-18-2018, 10:12 AM
Quoted: 790 Post(s)
Yeah, I was thinking this is the way to go too. I was pondering AR-5 into Miata the other day. Miata already uses a torque arm. You'd just have to mate the Miata torque arm to the solstice one.
