Comprehensive AR5 Swap Thread - Page 4 - Lexus IS Forum
 5Likes
post #46 of 141 (permalink) Old 05-29-2016, 12:24 AM
i posted this in the other thread, hopefully i can get some answers here.
i really need help trying to find out what this vibration issue could be.
- it started happening right after the swap
- it happens at 65mph
- it can't be the driveshaft, it's the proper length and it's balanced
- it starts slowly, then abruptly stops at over 75mph
- differential vibrates a lot while it happens
what could it be? how can i diagnose what it could be?
we tried jacking up the transmission mount (currans) and it still happens regardless of how high it is.
choro-q is offline
post #47 of 141 (permalink) Old 05-30-2016, 01:02 AM Thread Starter
Quoted: 28 Post(s)
Can you please give all the details and maybe photos of your drive shaft you used.
The drive line angle is less than 1 degree so the mount or operating angle will not be your problem.
13 J8A FR-S Series 10
01 DWP IS300 Sold
Curran is offline
post #48 of 141 (permalink) Old 05-30-2016, 03:51 PM
How can I check for the drive line angles? I'll post pics of my driveshaft when I get back in town. What details do you need? My driveshaft is a single piece telescoping driveshaft, connected to the drift motion adapter. It's entirely custom
choro-q is offline
post #49 of 141 (permalink) Old 06-21-2016, 01:52 PM
Go buy digital angle finder from auto parts store or home improvement store.
Remove driveshaft.
Put angle finder flat against transmission output flange (or drift motion adapter) and see degree.
Put angle finder flat against differential input flange and see degree.
Raise/lower diff/transmission to make degrees the exact same or close as possible.
There are a ton of youtube videos and forum post on it, good luck.
airfed is offline
post #50 of 141 (permalink) Old 08-31-2016, 05:50 PM
hey guys, doing this swap in my 1jz swapped 67 mustang. loads of info that ive been lurking about to plan my swap.
i'm using option A, with the GM hydraulic TOB. anyone use the solstice slave or the colorado slave? i had a hard time getting the trans to come together, had about a quarter inch of clearance between the bell housing and the motor. im using a w58 pressure plate with the drift motion ar5 swap clutch disc, talked to aaron. good guy. i noticed someone else in another forum mentioned using the colorado slave, and maybe shimming it to get it to fit. anyone have experience with this? the colorado slave cylinder is cheaper too, plus it has a bleeder screw. something to look into.
automanic is offline
post #51 of 141 (permalink) Old 08-31-2016, 11:03 PM
Quoted: 789 Post(s)
I'm using a T56 TOB but my setup is unique and won't match yours. This sizing has to be exactly right. If your TOB is too long (which yours kinda sounds like). It might press on the PP even with no hydraulic pressure.
I'm really not sure how you'd measure it. I imagine the guy who made my kit used a cut-away bell housing so he could see engagement
Ek9B18 is online now
post #52 of 141 (permalink) Old 09-02-2016, 12:55 AM
luckily im using the oem toyota r154 to 1jz bell housing, so it has 2 huge cutouts in either side that i can actually fit my entire hand inside and grab all 5 fingers around the input shaft. ill be able to easilly get a measuring tool in there, if only i can find one small enough. my calipers are too long. i feel like i read somewhere that someone had to modify the solstice slave to work, ill look for that link to corroborate.
post #53 of 141 (permalink) Old 09-21-2016, 10:44 AM Thread Starter
Quoted: 28 Post(s)
Im going to start another Ar5 swap soon for my other sportcross. If anyone has specific questions about the swap that they are still unsure of, ask now and i will be sure to get some detailed pictures or any other information.
01 DWP IS300 Sold
Curran is offline
post #54 of 141 (permalink) Old 01-06-2017, 12:42 AM
sorry to necro this thread, but ever since i've done the swap i've been having a bad vibration issue.
well, whenever i shake my driveshaft, i can kind of see the output assembly move (the entire thing that the driftmotion adapter mounts up to, dunno what it's called) and i think that's the issue.
how much movement there is normal? none? a little? and is fixing it as simple as tightening a bolt there? or do i have to take out the trans and tear it apart to replace a worn bearing or seal of some sorts?
choro-q is offline
post #55 of 141 (permalink) Old 01-06-2017, 02:01 PM
Quoted: 789 Post(s)
The disk that bolts to the tail of the transmission should be bolted down tight and shouldn't move at all. If you're talking about the output shaft itself, that might indicate the tailshaft bushing is worn out.
I had a vibration > 80 MPH and getting the new driveshaft re-balanced pretty much fixed it.
What kind of mount setup are you using on the rear of the transmission?
post #56 of 141 (permalink) Old 01-06-2017, 03:14 PM
I'm using OEM mounts and bushings, as well with Curran's cross member.
My drive shaft is balanced, at least they told me.
Do you know how involved replacing the bushing is?
choro-q is offline
post #57 of 141 (permalink) Old 01-09-2017, 07:07 PM
My output shaft bolt is not tight, I don't know what to torque it down to but hopefully that's the source of my vibration issue.
choro-q is offline
post #58 of 141 (permalink) Old 01-10-2017, 07:54 PM
yep, it was my output shaft bolt. no more vibration.
choro-q is offline
post #59 of 141 (permalink) Old 01-17-2017, 02:20 PM
Quoted: 50 Post(s)
Can i still use my factory 5spd master cylinder and clutch lines?
02 GGP 234k on chassis
BD11A supercharger/dezod headers/greddy catback/bc264/hks cam gear. 285whp [email protected]
az989 is offline
post #60 of 141 (permalink) Old 01-18-2017, 09:58 AM
Quoted: 17 Post(s)
^if doin with all the r154 parts you can. only change i had to make was bending the small section of tubing at slave cylinder
polish man is offline
Current users viewing this Thread: 3 (0 members and 3 guests)
