Comprehensive AR5 Swap Thread - Page 2 - Lexus IS Forum
 5Likes
post #16 of 141 (permalink) Old 02-15-2016, 08:36 PM Thread Starter
Quoted: 28 Post(s)
1. 85-87 land cruiser clutch master cylinder cmt-032. I have one new in box if your interested you can pm me.
2. shouldnt be hard just get a clutch disk for a solstice or Colorado, or call your clutch supplier and give them your specs.
3. Yes the 1jz/r154 bellhousing or refer to the part number above.
4. That is correct, the shift lever can be substituted with any w55 or w55 compatible aftermarket shifter.
Lastly, the Colorado is very different externally than the solstice transmission. The shifter cover plate pattern is not compatible with the jzx shifter plate. The output flange is also very different. As ek9b18 mentioned it could potentially work, but you will be creating more work for yourself.
13 J8A FR-S Series 10
01 DWP IS300 Sold
Curran is offline
post #17 of 141 (permalink) Old 02-15-2016, 10:50 PM
Originally Posted by Ek9B18 View Post
Looks like there's at least 5" or more difference between the shifter positions. I think you're making incorrect assumptions that are going to cost you some serious cash. You can see the colorado shifter connects right on top of the housing that the toyota housing extends. You can't mount the toyota adapter on the colorado housing too. Wrong number of bolts and wrong size.
Yeah seeing that as well. Just didn't have clear pictures to compare to at first, thanks!
Thanks! Does the GM throw out bearing need to be mounted upside down? You haven't mentioned anything about that but after reading through ExtremeFam07's thread he says it does.
SAM1990 is offline
post #18 of 141 (permalink) Old 02-16-2016, 07:16 AM
Quoted: 789 Post(s)
I have the GM TOB on my car. It's because my V8 adapter requires it. I'd much rather have a conventional external slave cylinder. I just like being able to actually see it operate and being able to replace it without dropping the tranny is a large plus.
Ek9B18 is online now
post #19 of 141 (permalink) Old 02-17-2016, 02:34 PM Thread Starter
Quoted: 28 Post(s)
I dont see any reason why that is neccesary unless there was some contact with the 1jz bellhousing. Probably best to ask him why he choose to do it that way. I personally do not recall any contact with the TOB and the 1jz bellhousing.
01 DWP IS300 Sold
Curran is offline
post #20 of 141 (permalink) Old 02-17-2016, 09:21 PM
I'll shoot him a PM. Would you happen to have the measurements for the crossmember, mainly the height from the tunnel to the lowest point of the crossmember?
SAM1990 is offline
post #21 of 141 (permalink) Old 02-20-2016, 08:32 AM
@Curran - when you used the Sequioa driveshaft, did you use the whole thing or just the front section?
SAM1990 is offline
post #22 of 141 (permalink) Old 02-20-2016, 08:54 AM
Quoted: 789 Post(s)
Probably the back 1/2 + the slip fitting. The AR-5 output shaft is really an oddball. That's the end that needs to change.
post #23 of 141 (permalink) Old 02-20-2016, 05:11 PM Thread Starter
Quoted: 28 Post(s)
I used the whole driveshaft, however the drive shaft was shortened. The fixed end matches the IS300 differential flange. The telescoping end was converted to a custom flange to mate to the AR5 transmission.
I Don't have that measurement, you can find those awesome crossmembers on a popular auction site.
01 DWP IS300 Sold
Curran is offline
post #24 of 141 (permalink) Old 02-23-2016, 08:28 AM
Quoted: 25 Post(s)
That's where I got mine!
Curran likes this.
2004 CWP IS300
AR5
dcharms is offline
post #25 of 141 (permalink) Old 03-06-2016, 06:37 PM
Quoted: 12 Post(s)
Hi. Thanks for the great info here. I'd love to do this but the funds are about dried up for the Lexus. I was curious about the cost before I look further into this and I got a good idea from what you posted.
So I created a Google Docs spreadsheet with options A-D and auto->manual info. There's still work to be done entering part numbers and cost of parts for the auto->manual.
https://docs.google.com/spreadsheets...it?usp=sharing
To keep this list accurate it's not open to editing unless you want to edit it @Curran let me know. All others 'File'->'Make a copy...'
jmooney5115 is offline
post #26 of 141 (permalink) Old 03-09-2016, 11:11 AM
Thanks for the spreadsheet. One item, GM Trans Bolts should be $6.60, not $660.
minivan81 is offline
post #27 of 141 (permalink) Old 03-09-2016, 12:33 PM Thread Starter
Quoted: 28 Post(s)
That additional information may be helpful to some, but also can be misleading. My total all in for the auto to manual conversion with the installation illustrated was $2600 all in. So your estimate of $3984 was a bit high.
01 DWP IS300 Sold
Curran is offline
post #28 of 141 (permalink) Old 03-09-2016, 01:01 PM
Quoted: 12 Post(s)
You're right. I've added a new tab and row for an OEM auto to manual swap.
Do you happen to have a list of part numbers or prices for the swap to include? I used the list of parts for your tutorial thread.
post #29 of 141 (permalink) Old 03-18-2016, 09:59 AM
Is it possible to just replace the AR-5/MA5 input shaft to the Toyota Supra/Chaser/Soarer R154 input shaft to have matching spline teeth and get an R154 type clutch ?
This would be an easier way to just reuse R154 clutches and parts onto the 2JZ, no ?
I would assume the tail of the AR-5/MA5 can not be converted to use the R154 type tail end, since nobody has mentioned it or attempted to do so.
It would make it easier to just get drive shafts available from DSS or DM.
In for replies, I'm looking into getting an Solstice AR-5/MA5 very soon
Sone Bone is offline
post #30 of 141 (permalink) Old 03-18-2016, 10:37 PM
So, i suppose it be possible to buy the jeep nv3550, then get the solstice tail housing, and jeep spline count to w55/58 diameter clutch? If so this would make the swap around 1k for me since I already bought a upgraded clutch kit for my whp.
airfed is offline
