Aristo 2JZ-GTE VVTi Swap Doc - Page 6 - Lexus IS Forum
 3Likes
post #76 of 795 (permalink) Old 01-24-2008, 11:41 PM
IS_BoostByPsi's Avatar
Umm, I just look at the ignition coils for both my aristo and my IS, and they are the same. they both have the same number and everything on them.
I thought the gte's came with individual coil packs with no wasted spark?
Why do they look the same? Are the aristos wasted spark also?
IS_BoostByPsi is offline
post #77 of 795 (permalink) Old 01-24-2008, 11:52 PM
TeCKis300's Avatar
Yup. Makes you wonder y everyone thinks they need more spark for <400hp huh? Those very same wasted spark coilpacks work just dandy with a .44gap.
Car sold to a good new home!
TeCKis300 is offline
post #78 of 795 (permalink) Old 01-25-2008, 06:18 AM
Yeah, identical. I have a set of usdm GTE coil packs that I'll be adapting over from the GE...wired in wasted spark they still make a + diff.
Are you guys oem usdm Supra plugs?
mikkellucci is offline
post #79 of 795 (permalink) Old 01-25-2008, 07:26 AM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
You may also want to buy a new set of wires for the spark plugs from Toyota. they aren't that expensive like 30 bucks i think and just for piece of mind that they are new.
Looking to do an Aristo swap?
Aristo Swap with IS ECU
Aristo Swap with Aristo ECU
wingzero is offline
post #80 of 795 (permalink) Old 01-25-2008, 10:09 AM
Well I guess I will have to add the USDM coilpacks to the list.
post #81 of 795 (permalink) Old 01-25-2008, 11:15 AM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
Yes i used Supra plugs, Denso IK20's I believe er 24's
wingzero is offline
post #82 of 795 (permalink) Old 01-25-2008, 11:16 AM
GTE coilpacks are often $200ish on supraforums.. You will need x 3 clips from Toyota as well: 90980-11246.
I havent mounted mine on the GTE head yet but it should be fairly simple. On the GE you have to trim the rubber boots, make a mouting bracket and grind the s* out of the TB for clearance.
Wiring the coilpacks is easy....Wasted spark, obviously one IGN channel will be powering up two coil packs. You just tap and extend a new harness from your stock one for both coil + and coil - wires on the new coilpack. Cylinders are paired #1-6, # 5-2, and #3-4 like all inline6's.
Thanks to TonyTheTiger for sharing the info....
post #83 of 795 (permalink) Old 01-25-2008, 02:01 PM
I guess. Now I am contemplating keeping the twins, but my rear turbo is eff'd and I need a new one. Mike if you dont use yours let me know I might need the rear one, I cant decide if I want to go single or stay twin with the ttc mod. Plus I have no idea how to set up the twins to operate at ttc or wire the vaccume hoses. If I keep them i will have one of the local supra guys or slorice to help me.
post #84 of 795 (permalink) Old 01-25-2008, 02:10 PM
Quoted: 26 Post(s)
Yeah, that was cool of Tony to post up real numbers from doing the coil swap. Its also good to know our OE igniter transistors are good for the extra current draw.
Props Tony, and dude I've cried before about wanting to see an OE like turbo setup. Teckis has come in close with the TT swap, but his pipes are shiny, plus his new heat shield. Your intake scheme and still using the engine cover. Damn man, props.
BlackSportD is offline
post #85 of 795 (permalink) Old 01-25-2008, 02:26 PM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
Well how much power do you want to make? If your looking for big power, ditch the twins now. If you just want 400ish, you can keep them. It is more of a hassle to keep them in there, but it looks SOOOOO damn cool once it's in!!
wingzero is offline
post #86 of 795 (permalink) Old 01-25-2008, 02:30 PM
Quoted: 26 Post(s)
^^ IMO a good twin swap, or like how Tonythetiger did his single, would have even a WELL TRAINED cop think its OE unless he's a fellow IS'er haha.
Being here in SoCal, I'm growing away from the bling bling engine bay stuff, and the clean but obviously modified look also, and wanting a "sir, it came from the factory like that" look haha.
post #87 of 795 (permalink) Old 01-25-2008, 02:35 PM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
that's what am going for. Although the 2 shiny IC pipes don't help I want to take her back to Lexus and complain...."uhh yeah there is a loud spooling sound coming from my engine, can you guys take a look at it and tell me what the deal is?" LMAO!!!
wingzero is offline
post #88 of 795 (permalink) Old 01-25-2008, 03:45 PM
400 is good. But I am not sure about the clearance. I know I have to modify a few thing which isnt a problem. Idk , I am torn ha ha.
post #89 of 795 (permalink) Old 01-25-2008, 03:54 PM
TeCKis300's Avatar
Just for you BlacksportD, my engine cover should be almost done this weekend. It's lime green! Finally getting to the little bits and pieces. j/k...it's black
I took the car a couple months ago into Lexus to get my A/C recharged. The techs there were all and converged around the car for quite awhile. I'm sure they all wanted to be the lucky A/C guy and fondle the car.
post #90 of 795 (permalink) Old 01-25-2008, 04:08 PM
Sweet. I need to get a new cam gear cover, mine came cracked. I email kinway but they need the part number and I cannot seem to find it.
Edit: did you guys keep the pressure tank or w/e on the intake side under the intake manifold? seems useless but i dont want to get rid of it if i keep twins.
Aristo 2JZ-GTE VVTi General Information Thread wingzero Go Faster 92 03-09-2011 10:05 PM
2JZ GTE Aristo swap! xtreme_IS300 Go Faster 60 09-14-2010 01:07 PM
what is the average price for a GTE VVTI aristo swap? theclassic32 Go Faster 28 11-25-2009 05:02 PM
GTE Swap | Aristo VVTi or Non-VVTi? sean05 Go Faster 4 09-15-2008 03:22 PM
Aristo 2JZ-GTE VVT-i swap questions bradleyjpyle Go Faster 1 06-23-2008 06:05 PM
