420whp, was expecting more? - Lexus IS Forum
 3Likes
post #1 of 34 (permalink) Old 11-24-2017, 11:24 PM Thread Starter
Quoted: 14 Post(s)
So my car is being tuned right now. The tuner can't get more than 420whp at 20psi.
Spec:
-6262 Precision Turbo
-850cc injectors
-FMIC (SRT)
-ECU Master
-Returned fuel system w/ Aeromotive regulator
-NA-T VVTi w/ GTE rod and pistons, ARP studs and GTE headgasket
-Stock head
-Stock intake Manifold
Tuner thinking the cams are the bottle neck. HP falls off rapidly after 5700rpm. Any input would be appreciated. I was expecting around the 500whp area on pump. To be fair it is a low reading dyno.
Sniper512 is offline
post #2 of 34 (permalink) Old 11-25-2017, 12:07 AM
Quoted: 38 Post(s)
Charts? Data logs?
el_jefe is offline
post #3 of 34 (permalink) Old 11-25-2017, 06:43 AM
Quoted: 321 Post(s)
Would love to see your dyno graph. Plus maps. Post if you can.
post #4 of 34 (permalink) Old 11-25-2017, 08:23 AM Thread Starter
Quoted: 14 Post(s)
I will try and upload what I have
post #5 of 34 (permalink) Old 11-25-2017, 08:24 AM Thread Starter
Quoted: 14 Post(s)
https://ibb.co/mYzH06
This is all I have for now. Car is still at the shop.
post #6 of 34 (permalink) Old 11-25-2017, 12:26 PM
Quoted: 321 Post(s)
Can not tell for sure without your maps. But if things are right there. I would say the AR on the turbo is why it is topped off there. Should be real fun though as quick as it cones up.
Relk likes this.
post #7 of 34 (permalink) Old 11-25-2017, 02:50 PM Thread Starter
Quoted: 14 Post(s)
OK. Yes that makes sense on the turbo size. Bigger I go and a retune.
post #8 of 34 (permalink) Old 11-26-2017, 07:00 AM
Quoted: 321 Post(s)
Sort of. The AR you have is .59 I think. If it was like .82 the power would peak latter in the RPM. But yeah a larger would change the aspects.
post #9 of 34 (permalink) Old 11-26-2017, 12:12 PM Thread Starter
Quoted: 14 Post(s)
You think a turbo like an S366 or a 6766 would make the difference to push to 500whp on my current setup? Just trying to get to 500whp before it comes home from the tuners without having to do the intake and cams there. I can do those this winter myself. Are the stock cams and intake that restrictive that they could be holding me back? I have seen multiple builds on stock head and intake over 500whp.
post #10 of 34 (permalink) Old 11-26-2017, 02:40 PM
Quoted: 321 Post(s)
Those turbos should be fine. Stock stuff is not that bad. You would benefit from better cams and intake and throttle body. But you don't need them to meet your goal.
post #11 of 34 (permalink) Old 11-29-2017, 08:39 PM
Virgin Magnet
somguy2u's Avatar
Quoted: 72 Post(s)
500whp is about right for what you are have. stock throttle is a bottleneck. it's not really the throttle but the plenum. the cams are not the bottleneck. a .59 ar on 62 would un out of breath high rpm at 500whp. midrange response i am sure is awesome though. I run a t04z with a .70a/r hot side and LOVE the midrange -but even it runs out of breath on the top end. similar set-up. i got s few more horse power out of it.
not sure what you were expecting; this is not a car that you slap a turbo on and make 1,452,937 hp
TUI
Motorsports
Own the dream
LC SSI 006
SWTEA Talon
somguy2u is offline
post #12 of 34 (permalink) Old 11-29-2017, 10:00 PM
Quoted: 209 Post(s)
I see you're running a ECU Master, from what I heard their standalone is not a good unit. The ECU Master piggyback is decent, but I haven't heard positive things about their standalone.
My buddy's Aristo swapped GS300 was running 14psi on stock turbos and made about 330rwhp. When he switched over to a AEM v2 with the exact same setup he was able to hit 390rwhp. I also heard from my drifter friends at the professional level the ECU Master standalone just doesn't compare to a AEM or ProEFI. Guys would run the exact same setup on their cars except for the ECU and the ECU Master made less power every single time.
blkaltezza is offline
post #13 of 34 (permalink) Old 12-01-2017, 11:38 AM
Precision's site says the default outlet on the 6262 is .63ar - which as previously stated is going to start running out of steam up top. it also has a 2.5" outlet which IMHO you should be shooting for 3" for any 2JZ FI motor looking for >400whp. I do not agree that the cams are the issue at this point. Also as previously stated the stock intake manifold can be a small hindrance but it helps with down low torque.
If you have the option, I would go with the .82ar 3" V-Band outlet.
JeffIS is offline
post #14 of 34 (permalink) Old 12-04-2017, 06:45 PM Thread Starter
Quoted: 14 Post(s)
Awesome thanks for all the help. I ordered a S366SXE .88 a/r Do you think that can push to 500whp keeping the rest the same? If not BC 264 vvti cams and a GTE FFIM welded to my GE lower runners is in the future as well.
post #15 of 34 (permalink) Old 12-04-2017, 06:52 PM Thread Starter
Quoted: 14 Post(s)
Interesting. I have heard a lot of great things about ECUMaster EMU. Lots of cars making big power. Was the Aristo same tuner and dyno under same conditions? Seems odd as all the ECU's mentioned give the tuner the same controls over vvti, timing and fuel. ECU is not the limiting factor in this case. No knock at all just a physical bottleneck with power dropping off with lack of flow.
