2JZ-GTE Swap Manual - Page 4 - Lexus IS Forum
post #46 of 67 (permalink) Old 09-19-2012, 07:46 AM
Nice hook up
2003 TMC IS300 5 Speed..
Baker901 is offline
post #47 of 67 (permalink) Old 09-20-2012, 12:29 AM
nice write up! im knew here and was thinking about doing the swap. where could most of things be found at and bought? besides ebay
2JZSteven is offline
post #48 of 67 (permalink) Old 09-20-2012, 02:30 AM
You have alot of shops... Titanmotorsports, MVP motorsports, Tokensolutions, TH Motorsports etc...
KonThai is offline
post #49 of 67 (permalink) Old 12-19-2012, 09:54 AM
Can a supra ecu be used to run single or and aristo?
jinwoopark1992 is offline
post #50 of 67 (permalink) Old 01-22-2013, 08:59 PM
Good info.. Nice job
konaboi808 is offline
post #51 of 67 (permalink) Old 02-19-2013, 07:54 AM
I'm researching my swap, and one thing that I haven't found consistent information is on the OBD2 port.
in order to keep my car street legal I need to have a working OBD2 port. my first though was Supra 96+ harness and ECU, has this been done before ?
if there is no way to swap a 2jzgte and keeping the OBD2 port working, I'll have to be happy with a na-t with some piggyback. but rather have an OEM ecu control my engine.
Culpable04 is offline
post #52 of 67 (permalink) Old 07-26-2013, 11:26 PM
do the links still work? for the microsoft word download it says file is not found and the adobe one loads up half way or less and stops loading.
filthy_will is offline
post #53 of 67 (permalink) Old 09-11-2013, 04:36 PM
Sorry to bring back a dead thread but i need expertise. Got rid of my IS250 and im picking up an 03 IS300 with a manual on saturday. I already have a 2JZ-GTE on the way so ill be starting this swap in the next couple of weeks. You guys think a piggy back or stand alone ECU? and which brand? Ive used an AEM FIC in the past but i was hoping something a little easier as far as the wiring. Also excluding the downpipe can i make IS exhaust work or does it need to all be custom? Next is there a FMIC kit made for this swap or do i make one from a supra work? Finally im reading through the swap manual and can anyone point out the exact spots i need to grind/cut on the rear turbo so it doesnt hit the harness. Thanks in advance for the help!
Drewfus32 is offline
post #54 of 67 (permalink) Old 09-17-2013, 12:23 AM
^Ive been tryn to search that same question about the FMIC. Also wanna know. If I make my kit my self, what is a good size IC that will fit between the radiator and the crash bar.
post #55 of 67 (permalink) Old 10-21-2013, 05:15 PM
New to the is and can't give +rep yet so I have to show love in words. I will be studying the crap out of this guide and, as soon as the wife let's me, I'll join the swappers and get boosted!
ninjabutt is offline
post #56 of 67 (permalink) Old 11-09-2013, 07:57 PM
Hello, im looking for a turbo kit for my 03 is300. Where can i buy one?
Thank you
Felizer is offline
post #57 of 67 (permalink) Old 11-10-2013, 05:59 PM
wingzero's Avatar
Quoted: 17 Post(s)
Looking to do an Aristo swap?
Aristo Swap with IS ECU
Aristo Swap with Aristo ECU
wingzero is offline
post #58 of 67 (permalink) Old 12-13-2013, 06:36 AM
i swapped in an Aristo vvti and mine is already an 03 manual. I used my stock harness and extended the MAF wires to reach the TB side (driverside) and have my MAF as a blow through 18" from TB in I/C pipe by lower frame rail. I have full access of OBDII port and have passed TN emissions. Only wiring mod i did was clone the B2S2 and B2S1 to read with B1S2 and B1S1. I also used a spark plug non fouler on the B1S2 (under car) to space out the 2nd O2 that way it sees less exhaust flow thus thinking there is still a converter on it. Wideband reads 10.8 or lower under a load, the ECU WILL compensate up to 13 lbs safely, anything more and the ecu can't add enough and starts to run closer to 12.1. No CEL's unless i turn the boost up and run it to death. I have driven my IS on several trips and the stock twins have the TTC mod and are at 13-15 lbs. has been reliable and get 20-24 mpg for the past 2 years. I just recently went to the single set up, Apexi Neo, and boost controller. Now that its at 15lbs daily, with as much as 18% correction it still runs at 10.8 - 11.4 WOT under a load. Dyno numbers were very impressive for stock motor with bolt on's.
cashed350 is offline
post #59 of 67 (permalink) Old 12-13-2013, 06:45 AM
I need to add that most of this was with the stock tranny (w58) with lightened flywheel and 6 puck. No issues at all. When the single was added i went ahead and installed an R154 , new flywheel/clutch and had my front driveshaft modified to the Toyota truck front yolk at stock length. Truck yolks are the same spline count for the R154.
post #60 of 67 (permalink) Old 12-13-2013, 09:31 AM
Quoted: 16 Post(s)
What mods where done to the fuel system? return line on what looks like a factory regulator?
clean looking engine bay, you should make a build thread.
02 1C0 5spd
Megomaniac is offline
Current users viewing this Thread: 4 (0 members and 4 guests)
gte swap two ecu's and manual swap Vladisme Go Faster 4 06-04-2008 09:06 AM
Manual Swap shroominguy IS350 Owner's Forum 4 06-24-2006 08:50 AM
Manual Swap impossiblesrock General Discussion 7 06-20-2006 07:27 PM
eshift to manual swap glassdanse North-East 3 02-14-2005 09:51 PM
Manual Swap SlvrSportCrossforme SportCross Owner's Forum 11 10-19-2003 09:50 PM
