WA / NW Tuner shop Resources - Page 2 - Lexus IS Forum
Closed Thread
post #16 of 61 (permalink) Old 04-09-2008, 10:05 PM
SEAHAWKS!!
IS3_FTW's Avatar
Quoted: 552 Post(s)
Originally Posted by chsamia View Post
Yeah I have the space it's outside though, I'll have beer and food just let me know or i can pay you.
I dont have any experience in this. BUt I am willing to help all that I can. I am going to upgrade my springs/shocks as well. But in a later time.
If you dont mind my company on learning, then I will be there.
Phil
2001 IS300
IS3_FTW is offline
post #17 of 61 (permalink) Old 04-09-2008, 10:11 PM
Patriot
Where is this suspension work going down? Is it coilovers or spring-a-lings?
Kito dyno cost?
Escort prices?
Donkey hoof?
jfsldkfjs;ljd?
2003 GGP IS300 manual
1986 BMW 325e
2007 Harley Davidson Nightster
XL1200N (1200cc)
Nicademus323 is offline
post #18 of 61 (permalink) Old 04-10-2008, 10:01 AM
Can you read...
I need someone to install my koni shocks and tien springs.
Kito dyno cost?
Thats why the info's up there. CALL THEM! If you don't have a phone, e-mail them. If you don't have a computer, use your special powers to solve crimes and bring justice to the corrupt streets of Seattle.
Escort prices?
What'd you say about my girlfriend!?!
Donkey hoof?
Do you smoke alot of crack?
jfsldkfjs;ljd?
Nevermind.
-Eric
"Dammit, where are my driving mocassins?!"
SOLD: '01 SY SRT 2.75
mixtnutz532 is offline
post #19 of 61 (permalink) Old 04-10-2008, 09:19 PM
SEAHAWKS!!
IS3_FTW's Avatar
Quoted: 552 Post(s)
I just got a Greddy EMU and PNP harness. Do I need a pro to install it, will I need to tune it right away?
I will be at the Dyno meet to get it all worked out
Phil
2001 IS300
IS3_FTW is offline
post #20 of 61 (permalink) Old 04-10-2008, 09:53 PM
You shouldnt need a pro to install it if you have basic wiring skills. Or save your wiring harness and just buy a plug and play harness from boomslang. Heres a link: Boomslang Fabrication - The Performance Wiring Specialists. I dont think You'll need a tune immediately. I'm not sure how e-manage operates but I don't think that it would change any outputs until you adjust them. Don't take my word for it though.
-Eric
post #21 of 61 (permalink) Old 04-10-2008, 09:55 PM
Wait. Didnt you already buy a PNP harness off another member? Why would you need a pro to install it? Its PNP. Just plug it in and secure the EMU under the dash.
-Eric
post #22 of 61 (permalink) Old 04-10-2008, 10:31 PM
SEAHAWKS!!
IS3_FTW's Avatar
Quoted: 552 Post(s)
I meant PNP, not PLP. I eduted it
I didnt know if I needed to tune it right away.
I am gonna do it myself, if the EMU doesnt need to be tuned after the install.
Thanks
Phil
2001 IS300
IS3_FTW is offline
post #23 of 61 (permalink) Old 04-11-2008, 12:45 AM
I dont remember everything that the Greddy units control but for the Apex'i fuel controller you could just install and go. All it does is take an input signal from stock sensors, adjust them with the tuned in settings, and send out the corrected signal to the stock ECU. So basically no tune means no adjustment, which means stock settings. I would assume that the E-manage works the same, atleast for its fuel control functions.
-Eric
post #24 of 61 (permalink) Old 04-11-2008, 12:56 AM
the hardest part installing the Emanage. is getting the plugs through the firewall. that was a bitch when i did it. and you dont have to tune it you can just leave everything at zero. or theres some base maps rolling around on isf.
2004 TCM SD
GOT SEAWEED?
IS300 chris is offline
post #25 of 61 (permalink) Old 04-11-2008, 01:16 AM
Did you have to cut a big ass hole to do that?
-Eric
post #26 of 61 (permalink) Old 04-11-2008, 01:52 AM
The EMU is the same as the other units, if you install it and leave it alone all the adjustments are zeroed out and you're just running at stock settings. If you get a PNP harness its as simple as matching plugs, otherwise its cutting and splicing in the wiring harness, which if you take your time and are careful shouldn't be hard, but does mess up your stock harness.
Cobra Project:
longnights is offline
post #27 of 61 (permalink) Old 04-11-2008, 02:09 AM
Eh... its a bit harder than you think. Splicing and soldering isnt hard... as long as you have enough wire to work with. The wiring harnes is kinda crammed in there and the wires get a little stiff and greasy from age. There wasnt alot of wire to work with and I kept getting hand cramps trying to hold the wires, solder, and soldering iron. Plus either the iron sucked or the wires werent very good at conducting heat because some just didnt want to melt the solder. The electrical tape around the wires from the factory was pretty dirty and not holding together well anymore. When I remove the fuel contoller I'm just going to resolder the harnes back together and get a boomslang extension harness to cut into instead of the actual OEM harness. I wish I had known about those in the firstplace. That would have saved alot of time and frustration.
-Eric
post #28 of 61 (permalink) Old 04-11-2008, 03:05 PM Thread Starter
748special's Avatar
I think we need a DIY install day. I'll be happy to set things up but I don't have any room to host it.
Anyone have a nice flat driveway & garage, and space for a couple more cars to park??
-For sale-
'02 IS300 - MSM, 5-speed w/Nav.
Eibach pro kit - Stoptech stage II kit - Turboeast Headers - Megan Y-pipe
748special is offline
post #29 of 61 (permalink) Old 04-11-2008, 03:12 PM
Auto Hobby Shop on base when I get back? lol
-Eric
post #30 of 61 (permalink) Old 04-11-2008, 04:08 PM Thread Starter
748special's Avatar
you know I'd drive up for that, that's where I did my suspension. Unless you want a bunch of IS'ers on your couch and floor I don't think anyone else will.
-For sale-
Closed Thread
  Lexus IS Forum > Regional Forums / All Together Now > West
Tuner shop in the M.I.A? Jemini South 8 10-19-2007 11:54 AM
Tuner Shop near Philly PHILLY'S IS300 North-East 6 05-20-2007 01:03 AM
seattle tuner shop 748special West 1 10-19-2006 03:21 AM
Tuner Shop In Milpitas CA JudeBaldo West 5 09-22-2006 01:18 PM
good tuner shop in MA L-tuner General Discussion 12 11-09-2003 02:13 PM
