rehosted - 2 vids 600hp Evo video vs. - a lot of cars - - Page 3 - Lexus IS Forum
post #31 of 35 (permalink) Old 05-04-2005, 10:46 AM Thread Starter
^^ I don't know, - one of the turbo guys on here would probably know that kind of stuff.
slvrone is offline
post #32 of 35 (permalink) Old 05-04-2005, 10:54 AM
boosted_4door's Avatar
Turbo's all have different limits. Depening on the size of the turbo depicts how much boost and hp you can get out of it.
Watching these vids makes me wanna go out and smash on some evo's.
Current: '03 BMW M3
Recaro | VOLK TE37's | Stoptech | Rogue Engineering | SuperSprint | Meisterschaft | VF Supercharged | AST 4100's
Gone: '03 SRT Built IS300 (615rwhp @ 19psi pump gas)
boosted_4door is offline
post #33 of 35 (permalink) Old 05-04-2005, 01:01 PM
Originally Posted by 12:51
isn't it all relative to the size of the turbo? Which means Sam's 37 psi on what is more likely a larger turbo than that EVOs put out more?
Indeed. It's relative to quite a bit. I was ignoring the previous 35psi comment, as it's a bit of a blanket-statement... Unfortunately, there's a huge misconsception that boost equals power. On the stock twins, when people learned I ran 22-24lbs of boost, they'd step back in awe. I currently make more power at 15lbs of boost on my setup at the moment. Boost is only a measure of the restriction in the system (IE - Heads/cams/valves/piping/intercooler/etc) A stock longblock supra may make X hp at 30psi, change out the cams, and proceed to make that same X horsepower at 25psi or lower. It's a change in the efficiency of the motor.
While I'm on it... This "Stage 1/2/3/4/5" Bullsh*t needs to curl up and die. I understand that in the IS300 realm, it makes sense, as the manufactuers are limited, and all very similar in offerings. Within a particular like minded/like owning crowd, it makes sense... When a Honda/Chevy/Ford owner asks me what stage I'm running, it get's me a bit irked - Not that they're curious, just that they've been so unknowingly blindsided by this ricer mentality. *sigh* So much more informative - "A 71mm wheel turbo on a tubular mani". Even turbo genealogy (of sorts) is causing me grief. 60-1's, T78's, PT67's, etc... While it seems of late, the main stream tendencies with the people I run across are leaning towards Precisions, too many ways to skin the cat...
Either way, the boost a car is running does not determine how far parts will fly should the block let go. (While it does impact cylinder pressures, the boost level itself isn't a measure of this, without a measure of airflow for the particular setup.) The RPM would seem the more likely place to look out for flying parts (Clutch, flywheel, etc - Things that leave large holes in floorboards, hoods, and on unfortunate situations - people)
~Nick
I guess I'll have to put the beer down now... Just little things adding up to truly frustrate the hell out of me... The Evo bashing sounds like a good idea... I've still got some race gas in the Supra...
Cybercyde is offline
post #34 of 35 (permalink) Old 05-04-2005, 05:09 PM
Awesome Answer...+ rep.
12:51 is offline
post #35 of 35 (permalink) Old 05-04-2005, 07:22 PM
Thanks for reading it through and not taking it as an attack... I may be just a "tiny" bit sensitive about things like that happening lately... I seriously couldn't stop typing though... I think I hurt my keyboard...
OT - Found out my distributor cap slipped, and the vacuum advance unit on my Firebird siezed.... Apparently I was seeing 30+ degrees of timing advance... (So that's why it felt a little sluggish... )
  Lexus IS Forum > Off Topic > The Garage
