Links to Automotive Calculators and Converters - Lexus IS Forum
post #1 of 1 (permalink) Old 04-13-2007, 04:21 PM Thread Starter
Tuner friendly.
Automotive Converters and Calculators
CSG's Online Calculator - General Math
Airflow Calculator
Angle Calculator And Converter
Annual Gas Cost Approximation Calculator
Atmospheric Conversions
Boost Fuel Pressure Conversion Calculator
Carburetor CFM Calculator
Car Cost Comparison Calculator
Celsius and Fahrenheit Conversion Details
Coolant Percentage Calculator
Cubic Inch, Milliliter and Liter Converter
Degrees To Compass Designation Calculator
Density Altitude Calculator
Dielectric Constants Of Various Materials Table
Differential Gear Ratio Calculator
Distances Between Longitude And Latitude Points
Engine Compression Distance Calculator
Engine Compression Ratio Calculator
Engine Cubic Inch/CC Displacement Calculator
Engine Displacement Calculator
Engine RPM Calculator
Fleet Gas Savings Calculator
Flow Rate Converter
Fuel Consumption (Metric) Calculator
Fuel Injector Flow Rate Calculator
Fuel Mileage (US) Calculator
Fuel Injector Volume Rating Conversion Calculator
Fuel Volume Calculator
Gas Oil Mixture Ratio Calculator
Gasoline Volume Conversion
GPS Latitude and Longitude Converter
Grade Percent Incline And Downgrade Calculator
Grade Percent Incline And Downgrade Calculator (Metric)
Dynamic Head Calculator
Highway Crosswind Calculator
Horsepower Gain From Additional Blower Pressure
Highway Hourly Fuel Consumption Calculator
Kilometer Nautical And Statute Mile Converter
LA Traffic News Live Real-Time Updates
Simulated LED Digital Clock
Simulated LED Digital Countdown Timer
Simulated LED Combination Digital Countdown Timer and Clock
Local Time Zone Calculator
Metric Capable Calculators, Converters and Tables
Mileage Compensation Calculator
Minutes, Seconds And Decimal Degrees Calculator
Model Car Life Size Scale Calculator
Model Car Scale Converter
Monthly Display Perpetual Calendar
Oblong Cylindrical Tank Volume Calculator
Octane Information And Calculator
Oil Change Time Calculator
Ohm's Law Calculations With Power
Parallel Capacitance Calculator
Parallel Resistance Calculator
Percentage Proportion Calculator
Piston Speed Calculator
Potential Engine Speed Calculator
Pump PSI Calculator
R134a Refrigerant Pressure Temperature Calculator
Ratio Proportion Calculator
Relative HP Calculator With Dew Point Factors
Relative HP Calculator With Humidity Factors
Resistor Color Code Table And Calculator
Ring Gear - Pinion Gear Ratio Calculator
Actual Speed Change From Ring Gear And Pinion Change Calculator
Road Mapping Scale Converter
Screw Sizes and Conversions Table
Series Resistance Calculator
Speed And Velocity Converter
Speedometer Calibration Calculator And Information
Speed Potential Calculator For Ring Gear And Pinion Changes
Sunrise, Sunset and Twilight Lunar Calculator
Surface Area Calculator
Surface Navigation/Position Calculators
Temperature Converter
Time Addition & Subtraction of Days, Hours, Minutes and Seconds
Time Designation Converter
Original And After Market Tire Information Calculator
Tire Diameter And Circumference Calculator
Tire Size Calculator
Truck Hourly Fuel Consumption Calculator
Light Truck Tire Information Calculator
Unit Time Converter
Units Converter Table
Time Zone Converter
Time, Speed and Distance Calculator
A Different Approach To Time Zone Calculations
Vehicle Potential Speed Calculator
Vehicle Stopping Distance Calculator
Vehicle Stopping Distance and Time Information
Vertical Climb Index Calculator
Vertical Climb Metric Index Calculator
Wheel And Tire Motion Calculator
Will show boobs for rep.
Me_1 is offline
Closed Thread
  Lexus IS Forum > Off Topic > The Garage
Catalytic Converters DA JOKER Go Faster 2 03-19-2006 10:11 PM
Torque Converters LikWid696 Go Fast Stuff 11 11-23-2005 05:46 PM
F/I and torque converters, few q's... xencloud Go Fast Stuff 2 10-27-2003 05:22 PM
Catylitic Converters nrkht General Discussion 0 10-08-2003 12:13 AM
T/C Converters and auto trans's IS300GTE Go Fast Stuff 7 04-04-2002 11:06 AM
