Nav Housing "Wiring Diagram" completed - Lexus IS Forum
post #1 of 16 (permalink) Old 04-27-2009, 02:33 AM Thread Starter
DB8
Hi all,
I would like to consolidate my wiring experience into a simple and easy to read diagram for all members. Thanks for all the help from our fellow member 3rdelement for all the great instructions.
Once completed, you will have a fully motorized housing with illumination. You can easily put in your GPS or any other eletronic equipment.
Cheers,
Here we go
DB8 is offline
post #2 of 16 (permalink) Old 04-28-2009, 10:39 AM
I hope this question isn't too simple ... but for a stock non-gps '03, where do the colored wires connected to M4 pins (diagram above) in the nav housing come from? Does the car come pre-wired? Thanks.
salsfamous is offline
post #3 of 16 (permalink) Old 04-28-2009, 12:27 PM
mtn
there is no pre-wiring for non-navi 1IS. You supply the wires yourself.
RIP My Black Onyx 2005
mtn is offline
post #4 of 16 (permalink) Old 04-28-2009, 12:34 PM
anybody know where I can get the female plug to match the male end of the nav housing? Trying to avoid any soldering to make this a clean install.
I looked at a few electronics store and they have nothing close since this looks like it's pretty custom and specific to Lexus. Is this something that you can go to a Lexus parts dept to ask for??
And of course thanks DB8 for putting all this together. +rep
'02 BO MT IS300: 03SD Grill | BP'ed | Joe-Z | Clear Sides | JDM Shorty | Dynamat | F-Sport Shift Knob | Chrome Rings/Clock Surround/Dash Dials | OEM Nav Mod | TRD CF Spoiler | HID fogs | CDD | TRD Oil Cap | L-tuned Sways | TRD Coils | 04+ Steering Wheel | CR Kai | LS430 Projectors | L-tuned Exhaust | C-Tuned Front | TRD Side Skirts | VIS Rear Skirt | L-Tuned Badges
turboa is offline
post #5 of 16 (permalink) Old 11-27-2009, 07:26 PM
for those wires that connect to M4 plug...do i really have to match the color when i go out and buy those wires? such as the power wire on M4...do i really have to buy a wire that is white or silver strip or a mixture color white and silver strip? thanks
TFIHS-E PGG 003SI 3002===>TSUAHXE 2 OVE YDDERG---EPIP-Y/REDAEH XBO---EKATNI UCE-TRS
IS300BKLYN is offline
post #6 of 16 (permalink) Old 10-20-2010, 05:27 AM
Old post Sry ,but does anyone kno if is possible to use the stock nav screen as a monitor to hook up to my aftermarket double din .try to use it just as a monitor
maximus227 is offline
post #7 of 16 (permalink) Old 05-20-2015, 12:44 AM
Quoted: 219 Post(s)
Sorry to bump this old thread, but I'm going to be doing this mod soon, and I'd like to see if anyone can clear up a couple questions. I have a 2003 that did not come with navigation. I am going to use an aftermarket screen in the OEM Nav housing and run a mirror image off my HU.
Since my car did not come with nav, I won't have the M4 plug coming from my car, but I still need to power my nav housing and screen. Do I just splice wires into the R2 plug and run them to the plug on the back of my nav housing as follows:
  • Pin1(R2 wire)>>Pin1(M4 nav side) Power
  • Pin2(R2)>>Pin13(M4) Illum+
  • Pin11(R2)>>Pin14(M4) ACC
  • Pin12(R2)>>Pin2(M4) Illum-
  • Pin20(R2>>Pin25(M4) Ground
When I'm done the back of my nav should look like the picture Twitched1 posted
AND the other end of the wires will be spliced to the wires in the R2 plug.
ALSO, do I get power for my screen from R2's Pin 11 or Pin 1? I would like my setup to function like the one in 3rdelement's video:
Originally Posted by Twitched1 View Post
**fyi**
from what i have done personally, you dont need to connect the (-) of the Illumination.
just the 4 wires for:
Illumination (+)
Ground
Power
Acc
connecting the negative Illumination from the board to the wire blows a fuse for Interior lights. i have been running for a while now with just the four wires without a hitch.
Can anyone confirm the statement above?
rvalero is offline
post #8 of 16 (permalink) Old 05-20-2015, 07:15 AM
Boosted Troll
Twitched1's Avatar
Depending on if you have one connector or two located on Tue back of the navi.
1 connector is no illumination (-). 2 connectors means you need it.
Also that picture is old. I now have pigtails I made for the rear of the navi. Which can have either setup and give power and ground to the screen from the pigtail. I have three of em if you want one lmk.
02 MSM W55 LSD FULLY BUILT NA-T
Carrillo Pro/Manley H Beam/ARP/ACL/PT6262-CEA/TT Gasket/BC 264's/BC Springs & Valves/Ferrea Seals/ETS IC/Tial WG and BOV/ PC'd all black/V-band 3" with Carbon Ti / :)
04 CRP EJ25 FXT not faster than ^^^^... yet
Supporting Vendors that support the community is just common sense
Twitched1 is offline
post #9 of 16 (permalink) Old 05-20-2015, 09:59 AM
Quoted: 219 Post(s)
My nav housing has 2 connectors, so I guess I need illum(-). If you have an extra pigtail, I'll definitely take one. Thanks! I'll send you a PM with my contact info. Do you know if I have to do anything with the second connector?
rvalero is offline
post #10 of 16 (permalink) Old 06-21-2015, 01:52 PM
Quoted: 7 Post(s)
Have to bump this once again. How does the nav know whether the housing is up or down if the're no position-switched power signal to it, just plain ACC?
peter99 is offline
post #11 of 16 (permalink) Old 06-21-2015, 06:02 PM
Boosted Troll
Twitched1's Avatar
The navi has a logic board attached to those connectors on the back. So it has the power (ehhh :-) ) to know when it needs to reopen when car is turned on depending on what selection is current when the car is powered off. That same selection is resumed when car is turned back on. Make sense?
mm71522 likes this.
post #12 of 16 (permalink) Old 06-21-2015, 06:18 PM
mm71522's Avatar
Quoted: 353 Post(s)
If you tilt the screen it will also remember it on start up
Mike
'02 AR IS300; M98 L-Tuned
TOKICO HP/TANABE NF210
ENKEI KOJIN 18X8.5+35/9.5+30
DIY: Nav+Aftermarket HU
DIY: Timing Belt
My Thread
mm71522 is offline
post #13 of 16 (permalink) Old 06-21-2015, 08:20 PM
Boosted Troll
Twitched1's Avatar
Correct ^^ ;-)
post #14 of 16 (permalink) Old 06-05-2019, 09:35 PM
=Do you still have this IS 300 Sat Nav...I want to buy it from you...Please email me at [email protected] or add me on Facebook at [email protected]. Thank you and I hope to hear from you soon as well.
Kamikaze_Super is offline
post #15 of 16 (permalink) Old 06-06-2019, 03:07 PM
Quoted: 340 Post(s)
Look at the date on the tread. Try Ebay etc. Or https://www.my.is/forums/f113/
Careful & Consistent
Wiring help: Nav housing install "PIC" DB8 Mobiletronics 12 03-08-2010 05:21 PM
