Metra TYTO-01 No Sound in '04 IS300 - Lexus IS Forum
post #1 of 17 (permalink) Old 05-06-2014, 07:54 PM Thread Starter
I recently bought a Sony MEXN-5000BT to install in my 2004 IS300. I also bought a metra harness, so I could retain my stock speaker system. However, after I wired everything up, the Sony radio booted up, but NO sound was playing from any speakers at all. How can I fix this? I will post some pics later tonight or tomorrow.
is3hunnit is offline
post #2 of 17 (permalink) Old 05-06-2014, 08:30 PM
Quoted: 9 Post(s)
Did you adjust the gain on the Metra? Also double check your wiring, not sure if your oem amp is turning on.
My pix whoring thread
Johnnysks is offline
post #3 of 17 (permalink) Old 05-06-2014, 08:55 PM Thread Starter
I've followed the guide that was posted in this forum. I connected the amp wire was connected to a wire on the sony that was labeled "REM Out". I will try adjusting the gain on the tyto-01 later. i've checked the wiring several times and it's all right according to the guide.
post #4 of 17 (permalink) Old 05-08-2014, 01:07 AM
Did you ground the wire? When I first installed my sony HU I forgot to ground the wire and it had no sound.
04 Mercedes-benz CLK320
02 Crystal White Lexus is300
gloomybear is offline
post #5 of 17 (permalink) Old 05-08-2014, 03:23 AM
Quoted: 71 Post(s)
This happened to me when I first installed mine. Make sure to check ground and gain and if that's all good I would unplug connectors that go into Metra and wait a minute. Then plug the two connectors back into the Metra and try again. For some reason the Metra likes to go into protective mode with the first time use, at least that's what happened to me and a few others I've seen. Good luck.
01 IS300 - MSM - 240k mile high club
Currently in: snow mode
BRZ Differential w/ 4.1 -- K&N FIPK Intake -- CXRacing Coilovers -- IS350 18" Wheels -- Greddy Lip [RIP :(]
Hotchkis Sways -- OBX Shorty Headers -- Custom Magnaflow Catback
therock0720 is offline
post #6 of 17 (permalink) Old 05-11-2014, 07:12 AM
Whatever therock said should solve your problem. I've also had a problem where the speakers would work fine with the Metra harness one day, but on rare occasions when I start my car there would be no sound coming out. So, If you experience this, instead of going through the pain of removing everything in the center console just to disconnect the harness (I've done it like three plus times before finding a new approach.) Just go into your fuse box in your engine bay and take out the radio fuse to reset the power going to the HU.
Just my two cents
Madninja33 is offline
post #7 of 17 (permalink) Old 05-28-2014, 11:09 PM
Did you find the fix? About to undertake this in an 05.
Justin311 is offline
post #8 of 17 (permalink) Old 06-25-2014, 08:14 AM
I had the same problem, once I disconnected all the wires (metra harness) and re connected them, the sound kicked on. Like a member said, must have been in protective mode. Sounds great now with my JVC touchscreen and stock speakers.
Redlinerl20 is offline
post #9 of 17 (permalink) Old 07-18-2014, 11:12 PM
Is this an issue of the harness or the console? I'm about to grab a Pioneer touchscreen to install in my '02. BTW is crutchfield a reliable place to get electronics from?
25romeo is offline
post #10 of 17 (permalink) Old 07-19-2014, 08:45 AM
25Romeo...I think the issue was that I installed it incorrectly and it went into protected mode. Crutchfield is a great place to get a stereo. I buy from there,but you can find the same radio on ebay for about $100 less. I bought the wire harness off ebay, but crutchfield had it and the dash kit. Make sure you connect the wires the correct way or you may get engine noise through the radio.
post #11 of 17 (permalink) Old 07-24-2014, 09:26 PM
So this is getting frustrating. One day the radio will work and the next it will be off. Sometimes when Im driving the radio will turn on but that is pretty rare. Starting to get annoyed and might just install back my OEM radio.
Has anyone found a way to make this thing work?
flyfl1pguy99 is offline
post #12 of 17 (permalink) Old 07-24-2014, 10:17 PM
Quoted: 605 Post(s)
post #13 of 17 (permalink) Old 07-26-2014, 10:54 PM
another thing you want to do when installing TYTO-01 is to make sure you turn the volume all the way to the max on factory stereo before you unplug it from the car.
This is explained in the instructions included.
'14 NGP IS350 Fsport
'04 GGP Altezza'd out IS **past =[
plusONE +1
specONE is offline
post #14 of 17 (permalink) Old 07-27-2014, 05:32 PM
Radio work fine when i put the ignition on ACC, but if i turn it to on or start the car forget it. The radio will not work. . .
post #15 of 17 (permalink) Old 07-27-2014, 07:28 PM
Quoted: 605 Post(s)
I had that same problem with mine actually, got it all setup and it sounded great, then it was terrible when I started the car.
PacParts: Beat Sonic SLA-91AD
Metra TYTO-01 Harness in 01IS No Sound Issue el-guapin Mobiletronics 8 06-27-2012 08:16 AM
is this metra tyto-01? 00Sleeper00 Mobiletronics 6 01-30-2010 05:27 PM
eBay: Lexus IS300 Double DIN + Metra TYTO-01 Wiring Harness tsj Mobiletronics 2 09-14-2009 06:42 PM
